Dell P1500 Laser Printer
Problem for Dell P1500 Laser Printer
By fesander on Jun 30, 2009
This P1500 Dell Printer does not feed ONE sheet at a time. It sends multiple sheets of blanks included with the prints ordered. How do I fix this multiple feed printer problem?
Best Solution
posted on Jul 30, 2009
Very Helpful)
Nitrotrike
Rank: Guru
Rating: 88%, 842 votes
You need to replace the separation pad. This printer is made by Lexmark, so parts are available through many vendors. The part number for the pad is 56P0691. You can google the part number to find a vendor closest to you for the best shipping charges. It is relatively easy to replace. Good luck.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Aug 28, 2009
Not Rated)
lasertltech
Rank: Guru  Computer Hardware  Expert
Rating: 90%, 24 votes
these printer have what is known as a seperator pad it is a little cork square it is located right under the pick wheel this wheel will need cleaned and the seperator pad repllaced. i would suggest that if the printer is 2 years old clean all of the rubber paper feed rollers with a rag sprayed with cfc contact cleaner
Was this helpful?
Yes
No
Popular Solutions for Dell P1500 Laser Printer
Questions and Unsolved Problems for Dell P1500 Laser Printer
Do you recommend Dell P1500 Laser Printer?
Answer
Answer
I download the drivers however when I go to add a printer wizard it does not install the printer
Answer
computer will not recognize the printer, I have down loaded the drivers from a number of sites and... (More)
Answer
I have a dell MFP Laser 3115cn printer that is putting a vertical yellow stripe on the left side of... (More)
Answer
Printer is on - need to print paper fan turns on acts like it is going to take paper and all lights... (More)
Answer
Dell P1500 Laser Printer - fan turns on acts like it is going to print and all lights start... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
