Question about Abit VA-20 Motherboard
I hav an abit va-20 motherboard that does not want to display anything. i tried changing the cpu but nothing happens. i even removed the ram just to check if it beeps but still nothing happens. i took another board that supports the same cpu(amd)and now the other one does not want to display.the other board ia a gigabyte7vm400am-rz
    President:
  • 948 Answers
Are you saying you have tried your processor in two known good motherboards and neither board will work with your processor?
Either your processor is bad or it does not work in those motherboards.
Posted on Jun 30, 2009
Asrock G31M-S No Display/Booting
First of all, check if there are any inflated capacitors, if there is even one- ditch MBO, other capacitors will soon follow. If no inflated capacitors proceed with these diagnostic steps: 1/ disconnect all peripherials (DVD, HDD, card reader...), leave only MBO, PSU and RAM (and CPU of course); if nothing happens 2/remove CMOS battery (CR2032) for 20-30 sec with power cord disconected from computer, that will reset BIOS; 3/ take out RAM sticks, then, if you have more than one stick, try with each stick separately (it might be faulty RAM); 4/power on MBO without any RAM-if speaker is present it should give BEEP signals; 5/ try with different PSU, many power supplies are faulty even when they do give power to MBO.
If nothing of above does not help than you have faulty MBO, because CPUs are so rare to fail that in my 10 years of experience in PC service I had 3-4 fried CPU-s, and even that was because costumer tried to clean PC, removed CPU cooler and than incorrectly placed it back or didn't put thermal paste afterwards. asrock-g31m-s-no-display-booting-yuc33qzjuwfqgyyin4u45syc-4-0.jpg
Dec 18, 2014 | Asrock Computers & Internet
Need a bios update free download for abit va 20 motherboard
Try this download:
http://www.helpdrivers.com/motherboards/Abit/Socket_A/VA-20/
I don`t like to download such files from unautorized sites.
This is at your own risk !!!!!!!!!
But the Abit homepage is not working properly:
http://abit.ws/page/en/download/download_driver.php@pFUN_KEY=9000&pTITLE_IMG=_2Fdownload_2Fimages_2Fdownload.html
Good luck
Nov 24, 2012 | Abit Computers & Internet
Cpu fan running but the mother board does not respond
Remove/disconnect everything (Ram, Cables, Power Supply, Battery, Processor, Pci cards, Display cards if there's one, etc.) from the motherboard, and after while, reconnect/put them on the motherboard again. Make sure you correctly installed the Ram and it's working. Also don't forget to connect both the power supply cables (20 pins connector and 4 pins connector) to the board. Now reboot your system, can you hear anything (beeps)? If this doesn't help, your nearest culprit to the problem is Display card. Good luck
May 21, 2010 | MSI K8MM-V Motherboard
When I turn on the computer it starts to beep every four or five seconds; it doesn't even turn on the screen. The display at the motherboard is "04". What does it mean? There was nothing wrong with my...
This is do with a device failure it can be the RAM of your system , Try swapping the RAM and if you find two RAM in your system remove one to check the error.
Kindly send me your valuable feedback.
Jan 16, 2010 | Abit KV8 Pro Motherboard
Where can I get a manual for the Abit VA-20 motherboard?
nodevice.com
eserviceinfo.com
servicemanuals.com
That's where I look for service manuals. Also, try finding torrents I find them there a lot too.
Oct 09, 2009 | Abit VA-20 Motherboard
Changed cpu on an abit va-10 mb but the fsb stays at 266
Unless the mobo is compliant with a front side bus speed of 333mhz, the cpu you have will only run at 266mhz max, in other words the cpu will down-clock to the 266mhz bus clock and therfore run more slowly. check with the mbo handbook, or on CMOS tosee if yoy can change the fsb setting. ask for more help if needed.Can you give me the full code of the mobo ?
Nov 29, 2008 | Abit VA-10 333MHz FSB VIA VT8378 Chipset...
Nothing Happens...period
Did you install the 8 brass needed stand-off's & screwed the board down. Nothing underneth the board can touch the case back. I don't see a mention of the 24Pin power cable to ATX1. Check the cmos jumper pg.1-6 of the manual. It should be on Pin 1&2, & not 2&3. Check Red switch on PSU make sure it is set to 115v. You have memory. I gather 1 Dimm but if you have 2 pull one & try. Try the other dimm slot. The last thing I can think of would be the three wire CPU fan & thermal grease over the CPU & God forbid a broken pin somewhere on the CPU.
Good hunting & best hopes.
Feb 14, 2008 | Abit LG-95Z Motherboard
No beeping, no video displayed.
hi, The beep test is notrmally done with the small speaker attached to the computer internally, there could be a problem with the RAM installation check the RAM compatablity with the mother board, give me further details of the make and model of the mother board and RAM , i will try to help you.
Jun 30, 2007 | Abit LG-95Z Motherboard
Abit VA-20 Motherboard Logo
83 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
