Question about Frigidaire FEB27S5A Electric Single Oven
I have a frigidaire model cfeb786jgb3 error
I have a frigidaire model cfeb786jgb3 wall oven error code f1 keeps
popping during the cooking cycle and had to be reset.
  • 56 Answers
F1 is a watchdog on the control board
replace control
Posted on Jun 30, 2009
Oven beeps and show F1 and F3 while trying to cook or even 2hrs after cooking.
F1 code is a "EOC (Electronic Oven Control) failure" Replace your oven control
F3 code is a bad oven sensor the sensor should have a ohm reading of 1100 at room temp. Replace your oven sensor as well.
Dec 06, 2010 | Frigidaire 30" Built-In Single Electric...
Error code -F1- and broken glass door in lower oven
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
@$#Y^T
Apr 19, 2010 | GE Profile JTP56 Electric Double Oven
Keep getting F1 error code (constant beep) on my GE profile oven.
%#$TEF
Mar 18, 2010 | GE Profile JTP56 Electric Double Oven
Model FEB24s5abb wall oven has a F1 code. What
F0 & F1 EOC (Electronic Oven Control) failure Replace
Mar 01, 2010 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
F1 fault code Frigidaire electric range
Hi, you stated that you cooked a meal that produced some humidity inside the oven. this is the cause of the F-1 code. the humid conditions that were present at the time, caused the EOC(electronic Oven Control) to short. you will need to replace this control board at this time. it has failed.
May 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Wolf Double Oven
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Mar 26, 2009 | Wolf Range WKGD-2 Gas Double Oven
What does the error code F1 indicate, on a Wolf Oven?
Mar 24, 2009 | Ovens
Frigidaire gas wall oven clock unit sometimes says F1 and beeps.
F-1 is USUALLY a touch pad error, it thiniks something is stuck. The sensor error code is F-3.
Mar 17, 2009 | Frigidaire 24" Built-In Single Gas Wall...
Range control panal flashes F1, oven no longer works.
$%^TG
Jan 14, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire during cleaning F1 error,
F1 means its your electronic control and it will probably cost you the same amount to get this problem fixed again. The part is usually $350 plus.
Nov 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire FEB27S5A Electric Single Oven Logo
893 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
