Question about Dell Inspiron 6400 Notebook
No monitor computer starts up, dell progs load, window prog load and then the screen goes black. i can hear the desktop being loaded but the screen is black and i can't get to the settings to see if i can fix the monitor. tried safe mode but with no luck.
  • wcornwell1 Jun 30, 2009
    thanks heavyvice,
    no battery, (haven't had one for a long time) can not see the desktop to get into the settings to restore. everything loads correctly. monitor goes down when desktop is loading. any other way around besides reinstall of windows xp? i really don't want to have to go through all that again. drivers @ dell site maybe?
  • 374 Answers
1) UNPLUG THE LAPTOP
2) REMOVE THE BATTERY
3) HOLD DOWN THE POWER BUTTON FOR ABOUT 30 SECONDS TO 2 MINUTES
4) THEN PUT THE BATTERY BACK IN or DON'T
5) START IT UP...
After that when the system starts you can do the system restore START--ALL PROGRAMS--ACCESSORIES--SYSTEM TOOLS--SYSTEM RESTORE.Hope that will do. Otherwise you can re-install windows if you have a Windows CD.That will definitely solve the problem.There might be problems with VGA Resolution [if you have used the laptop with some other monitor or TV] or driver. For installing Windows Do Google Search.
Posted on Jun 30, 2009
  • Fardin Ahmed
    Fardin Ahmed Jul 01, 2009
    Try removing any components attached to the laptop...make it light.If you can,try removing the keyboard wires and the screen wires [attach another monitor] from inside,1 by 1,n you can check what basically is wrong.I don't think there's anything else you can do then Re-Installing windows.There could've been more option if Windows could load properly but in your case there r not many options left.
Why is my dell inspiron 531s stuck on black screen with input not supported message?
Start pc in safe mode and try to change resolution.
Then update the graphics driver.
May 06, 2014 | Dell Inspiron 531s Desktop Computer
Black screen right after dell logo
start tapping f8 after you boot the machine, when given the boot menu, try to load safe mode, and see if it loads. if it does, then you need to do a system restore back to before you got the black screen. more than likely windows loaded an updated driver that disagrees with your system. try that and let me know what happens :)
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 25, 2012 | Dell Studio One 19 PC Desktop
My Dell monitor goes to sleep right after windows xp starts to load and it won't come on after that. my computer is still running but the monitor is a sleep. I have hit f8 and f12 with nothing happening....
Go into safe mode
Under settings, control panel, power options set "turn off monitor to never
reboot
I think this is not a sleep problem but the incorrect monitor settings were set. This will cause the screen to go black when the OS comes up. Boot in safe mode and change the display settings
to 640x480
OR
in safe mode, delete your monitor. When you reboot it will load a default monitor and you should be OK
Oct 13, 2010 | Dell XPS 410 PC Desktop
Dell 922 all in one printer will not scan
Have you setup computer to chat too printer.?
Uninstall printer prog, restart poota/ load dvd setup. stay with poota while loading, it will ask you questions, not many but if you miss a click then that could be why the prog is failing to start. Continue to finish, clicking positive replies.
Nov 14, 2009 | Dell 922 All-In-One InkJet Printer
Hi i am having problem installing my Lexma panda webcam to my dell computer what do i do
Firstly, Remove the installation thru Control Panel->Add/Remove Progs. Secondly, Reboot the laptop. Thirdly, Install the drivers from the CD Fourthly, Reboot. Fifthly, Connect the webcam and allow Windows to detect it and load its drivers. Sixthly, Run its prog and use it.
Nov 05, 2009 | Computers & Internet
Monitor does not work, computer starts up, dell prompts load, windows prompts load then screen goes black. i can hear everything loading but no display.
connect an external monitor on your machine and check if display is ok on the external monitor. if yes, try to re-install your video driver and check if display is ok on your laptop.
if both doesnt have display (external monitor and laptop's display) i suspected your lcd display is faulty.
Jun 30, 2009 | Dell Inspiron 6400 Notebook
Blank monitor
To resolve the problem,do the following step,
1. Power on the system
2. At dell logo screen before windows xp starts to load tap on the F8 key slowly 5 to 8 times
3. Select safe mode
4 Hit enter on the next screen and logon using the administrator or your name
5. Do the system restore, when you have logged on, this would return your system back to the date when it was working fine
6. To system restore
click start>all programs>accessories>system tools >system restore
Thanks
proton
Oct 11, 2008 | Dell Dimension 2400 PC Desktop
No Signal when desktop wants to load
It does not hate that monitor. I believe the problem is in the settings on your video. Your monitor cannot display them. You will most likely need to start your computer in safe mode and change the display settings on your video card or, alternatively, download updated video drivers. Also, if you can't get Windows to start in normal or safe mode, one of the options you get when you press F8 on startup is to start in VGA mode. That will get you in so you can tweak your settings, which are probably set to a resolution too high for your monitor.
Sep 11, 2008 | ViewSonic VA1916w LCD Monitor
Dell Inspiron 6400 Notebook Logo
104 people viewed this question
Alun Cox
