Most likely there is a raised spot on the cutting deck preventing the tensioner to return. Best thing to do is turn the tractor off engage the blades disengage them and see if you can move the tensioner. If it feels like it is catching on something you will have to grind the deck a little on the groove that is catching.
Your blades engage with a cable and the cable somewhere is bunched up. You will probably need a new cable.
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
SOURCE: The blade engage lever on my 42
Get a can of penatating oil and spray the pivot point of the idler arm on the deck. That's the one that moves back and forth when you lift the blade engagement lever.
SOURCE: Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
SOURCE: I have a Craftsman LT2000 tractor and I've had a
the pulley that the disingage spring is hooked to sounds like its freezing up it may need some oil put on it to make it slide easier
SOURCE: Blades will not disengage
the brakes on the deck belt not working belt to tight or deck not fully disengaging
