2 yr old polaroid tv won't turn on leave on 10 min. plug and unplug then sound comes on leave on 10 minutes plug if polaroid comes up picture will come up.
  • 261 Answers
There is a slight possibility that the ballast is going out, because after a while you do get the image, and the Tv is not that old, which I'm guessing you haven't replaced the l;amp yet, because it's not even time to do it, unless you the Tv is on for a great amount of hours, if so replace the lamp first.
Posted on Jun 30, 2009
When you switch the TV set on, the picture comes up for a second or two then the set turns it's self off onto standby
It sounds like you have a power / short issue. You will probably have to get it looked at and serviced, but you could try plugging it into another power outlet in the house, but first leave it unplugged for about 10 min.
Chris
Aug 15, 2011 | Computers & Internet
Samsungh LA40B530 No picture but sound
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync, but if otherwise then
The ysus board is the most common reason.
you can try websites on ebay.com to buy parts for replacement...
Aug 03, 2010 | Samsung LA40B530 40 in. HD-Ready TV
My television powers and lose picture 10-15 min later
You may have either failing 24vdc power supply due to bad DC filter caps, loose solder joints, or failing backlight inverter board. Those are the two areas you need to check out.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 24, 2010 | Polaroid TDX-03211C LCD TV
32" LCD HDTV Sceptre model x32, blue led but no pic or sound !
Having the same problem. Took it to a repair shop and they say it is some capacitors and the power supply... Which seems kinda hinky to me... I would think one or the other would be the problem, not both at the same time.
Apr 06, 2010 | Sceptre X32GV-Komodo 32 in. LCD Television
Looking to buy a Polaroid TDA-03211C the needs repair
I have a 3 year old TV with the same problem as shema_ross.
Aug 16, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid flat screen LCD tv went out
sounds like your powersupply just went out on you tv this will need to be replaced
May 12, 2009 | Televison & Video
Buzzing and poor recption
I wish I had a solution--My DVD picture and sound is fine, but it takes about 30-40 minutes to get any kind of picture but it is broken--not clear at all - and the sound is all garbled, totally stops for seconds to minutes a a time. It is only a little over a yr old. I finally isconnectexd today and am going back to my cheap-o but dependable tv.
Aug 08, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Philips 51PP9100D/37
try unpluging the set again for 5 minutes, if no help go into the menue and make sure that tha speakers are turned on. also try turning up the volume
Oct 19, 2007 | Philips 43PP9202 43" Rear Projection...
Mitsubishi 10 yr old rear projection
Well, there is no lamp or simple part you can unplug and plug in. I have seen a couple of those sets with that symptom recently and it is caused by a faulty 9 volt regulator on the small signal board. This is not an easy part to change and the repair should absolutely be handled by a tech experienced in Mitsubishi projection sets.
Aug 09, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
