Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Husqavarna engine pulley?
I am trying to remove the engine pulley from my Husqavarna YTH2148. I tried using a puller with no success. I am grinding the pulley shaft down to the keyway to try to get it to let go. Is it normal for these pulleys to be that tough to get off? Any suggestions?
The reason I am trying to remove the engine pulley is because it isn't lined up with the idler pulley under the tractor and the belt is rubbing itself in two.
I bought the tractor used and they said that they installed a new electric clutch. So I thought that maybe they installed the pulley upside down.
Now, I'm not sure. I bought a new engine pulley but one end looks like it is made for a 1.25" shaft and the other end is for the 1" shaft that's on the engine.
Do you know if there is an adapter piece that fits between the engine pulley and the electric clutch?
Thank you so much for you help.
  • frog_123 Jul 17, 2009
    Yes. But it doesn't show how the drive pulley attaches to the electric clutch.
  • 11 Answers
Do you have a manual for the tractor?
Posted on Jul 17, 2009
I'm trying to remove a harmonic balancer. I've got to the point of taking it off. The pulley remover is placed. But the bolt when completely down only turns the balancer. How to fix please
Are you using a gear puller or an actual harmonic bal. puller? You can use air tools(carefully), or to hold the balancer/pulley still, use a chain wrench with an old belt wrapped around to prevent damage. I would not recommend a 2 or 3 jaw type gear puller.
Oct 17, 2015 | 1996 Buick LeSabre
How do I remove the crankshaft pulley
which engine?
the fsm covers that, its free to read.
old post.
ZJ jeep 93
4.0L fsm verbatim, buy a puller, or make one, or use a huge gear puller, at edges of pulley, or use a slam hammer, rad out and grill out. or?
May 29, 2014 | 1993 Jeep Grand Cherokee
Remove crankshaft pulley
Use a puller that screws into the crank & has
jaws that fit the pulley spokes
Have to buy the correct tools (puller & installer)
Check out the tools avail online to see what is needed
Try You Tube Video to watch something
Sep 16, 2013 | 1998 Buick Park Avenue
Removing harmonic balancer
First, you have to loosen the crank pulley center bolt. Best way is with an impact gun-bolt is very tight. If you have to use a breaker bar to loosen the bolt, you will have to devise a way to hold the crankshaft from turning backward while loosening it. One method is to remove the starter and wedge a piece of wood against the flywheel, preventing it from turning, while you are loosening the center bolt.
From the beginning: raise and block the side of car that the front of engine is towards. Remove the wheel and the inner fender splash shield. Remove the belts. Remove negative battery terminal, remove starter. Wedge the flywheel so it won't turn backward. Loosen and remove the center bolt. Some harmonic balancers will slide right off the crankshaft now, some are on very tight, if you can't wiggle it, tap it, and get it to move, then buy an inexpensive harmonic balancer removal puller, just a few bucks, easy to use, will save balancer from trying to hammer it off. All you need is enough room to mount up the puller to the balancer, and get the balancer moving off the crank.
Some engine lay outs there isn't enough room: then you really have to get creative, either lowering engine enough to get to pulley, or raising engine out. But most engines are positioned where the crank pulley can come off easily, with enough room to get the puller on.
The pulley may have a woodruff key in a slot on the crankshaft, and a corresponding notch on the pulley, for proper positioning of the pulley to crank. Don't lose the woodruff key.
Sep 01, 2013 | Pontiac Trans Sport Cars & Trucks
Why is it hard to get balancer pulley off 98 neon? Tried a pulley puller and impact. Still no luck. What should I do?
Did you take out the center bolt? You have to remove the center bolt, then use a harmonic balancer puller. Not the two or three armed pulley puller, but a harmonic balancer pulley puller-the pullers with jaws that hook around the outside of pulley can ruin a harmonic balancer.
Use the impact gun to remove the center bolt. You won't need an impact gun to remove the balancer pulley. The balancer puller will take it right off the crankshaft, no problem.
Jul 23, 2013 | Cars & Trucks
How to use a harmonic balanced puller on a 94 Buick lasabre
Hi, it is easiest if you set the brake, jack up the car, put in a jack stand for support, and remove the wheel and splash shield to access the pulley. If you have a manual transmission, put it in a high gear and set the brake. If you have an automatic transmission, you will need to lock the engine with something, best done at the flywheel/flexplate. If there is no access panel to the flexplate, remove the starter for access. With the engine locked, remove the main pulley bolt. Use 3 quarter inch bolts to attach the puller to the pulley and tighten the puller slowly to extract the pulley. Please let me know if you have questions, and thanks for using FixYa.
Lock the flywheel:
Attach the puller and tighten bolt to remove pulley.
Jan 16, 2011 | 1994 Buick LeSabre
I am having trouble removing the crank pulley on a buddy's 2003 Hyindai Tiburon. I got the one middle bolt removed and I tried using my claw type puller and as I was cranking on that the cam timing...
There is such a thing as a crankshaft pulley puller. Timing belt should not come off if only the pully not the sproket is being removed. Most autoparts stores carry these
Jan 10, 2011 | Hyundai Tiburon Cars & Trucks
I need to know how to remove the crankshaft sprocket( pulley) from my 2002 chrysler 300M 3.5 engine I have tried everything I know and it won,t budge. Is there some secret to removing it.
A vibration damper puller is required to remove the pulley/damper assembly. You may be able to borrow one from autozone. Let me know if you have more questions and thanks for using FixYa.
Dec 21, 2010 | Chrysler 300M Cars & Trucks
My idler pulley is making a squeaky light grinding niose.
Any Auto Parts store or even a Wallmart may have a WD 40. I would first try to spray this behind or right where you see the Axel of this Idle pulley.
Unfortunately it may be getting old and dried out.
If you have any grease or even - sounds funny - Vaseline - try smearing this on where the Axel meet's the round pulley.
Blessings,
A/V Guy
Nov 19, 2009 | 1998 Nissan Maxima
1997 Bonneville - can't remove crankshaft pulley
You need a three jaw puller to remove the balancer. After you remove the center bolt the puller hooks into the three holes in the balancer.
Jun 08, 2009 | 1997 Pontiac Bonneville
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
306 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
