Question about Sony Cyber-shot DSC-S700 Digital Camera
Computer does not acknowledge the camera when connected via usb
It did work at one time. I suspect the camera usb connection is broken... any advice?
    President:
  • 942 Answers
In that case try to use other usb cable, the n plug it directly to the usb port of your motherboard at the back of your cpu casing, try to use all the port, if they did not work, now you can use now a card reader, put your memory card to the card reader then plug it on the mothernoard usb port
Posted on Jun 30, 2009
Panasonic DMC-155 camera no longer uploads photos to PC
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Jun 02, 2013 | Panasonic Lumix DMC-FS5 Digital Camera
I plug in the usb cable but nothing opens up I was downloading my pictures to my labtop, it froze so after disconnecting the usb cable, reconnecting, the sound acknowledges the connection, but nothing...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jul 04, 2010 | Canon IXUS 960 IS Digital Camera
My camera says 'Connecting to PC' all the time when I turn it on even if it is not connected to PC. I think it has got confused as the last time I used the camera was to take photos off it and it may have...
Connect the camera to your PC. Turn it on. Wait till the PC 'acknowledges' the camera. Then disconnect it via 'remove USB-device safely'-function.
If this doesn't work. try resetting the camera with the reset button you'll find under the connections hatch.
Jun 14, 2010 | Nikon D40x Digital Camera
PowerShot A85 Digital Camera: when I connect my camera (canon powershot a85) to ...
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
May 16, 2010 | Canon PowerShot A85 Digital Camera
Unable to download pictures
In the short term you can take the memory card out and use a card reader - at least that will let you see the pictures.
Mar 21, 2010 | Canon PowerShot A85 Digital Camera
Does not recognize camera plugged in to usb
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jul 17, 2009 | Samsung S860 Digital Camera
My computer wont recognise my FinePix A610 camera
Suggest that you go tp my computer as the answer above has suggested and attempt to open drive(memory chip) in the camera and download. If not suggest removing the memory chip from the camera and try accessing via Walmart or other stores photo Kiosk.
Suggest opening Fin-pix first before connecting camera.
Through fine-pix search for camera as if it was an external drive. Hope this helps?
May 24, 2017 | Fuji Finepix A610 Digital Camera
Laptop doesn't acknowledge canon a460 camera when connected
Aug 05, 2008 | Canon PowerShot A460 Digital Camera
Can't get out of USB mode
You most likely need to change a setting called USB Connect under main settings 1.
Page 67 of http://pdf.crse.com/manuals/3208400121.pdf
Default is auto
I suspect it is set to mass storage and is causing your hassle
Mar 04, 2017 | Sony Cyber-shot DSC-W200 Digital Camera
COMPUTER WONT ACknowledge camera
Dec 22, 2007 | Pentax Optio 50 Digital Camera
Sony Cyber-shot  DSC-S700 Digital Camera Logo
111 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
