SOURCE: F3E0
F3 means the oven temp sensor has failed E0 means it failed open If you have a test meter i can tell you the resistance at room temp is 1100ohms. otherwise call for service Hope this helps PLEASE rate my solution Thnks...
SOURCE: F2E1, F3E0 Error Codes
Believe it or not, but on my Whirlpool Estate (Model: TES400PXHQ0)....after reading about this error, I looked at the sensor, and I noticed it was touching the metal on the inside of my oven. I moved the sensor away just by pulling on it to the center of the hole that was cut out for it, plugged the oven in....and didnt get a code at all....not even the PF code. So, I tried the oven out....expecting for it to beep at any second, and it didnt!!!!
So, in conclusion.....I guess by the sensor touching the metal on the inside, it couldnt get an accurate reading, so the computer threw out the infamous F3E0 error.
I've had this oven for 4 months and always had to stare at the F3E0 display (it was donated to me). Thanks for all who had done the research on this to point me in the right direction, as Whirlpool wanted someone to come out at $60 just to come out, then $80/hr!
Thanks again
~Luke
SOURCE: f3e0 error
may need more info.what sequince happens before this error occurs.does any other function operate correctly.
