Question about Garmin zumo 550 GPS Receiver
Why can't I get adequate volume when listening to xm radio using a multi-media wire and with blue tooth disabled
  • 3 Answers
First off make sure that you go into your systems settings and turn the volume up for all the items connected to the Zumo, then you need to buy a gold tip double headed male patch cord from Best Buy, make sure it is a real good patch cable if not you will get lousy sound from the Zumo.
Posted on Jul 02, 2009
  • renod68 Jul 13, 2009
    Hello the problem is not really a problem only a setting that we sometimes forget to check, after powering up the unit push and release the [] square button on the Zumo 550 until you see the volume adjuster which is several green lines over to the right side and across the screen from top to buttom, then just push the + sign button to turn up the volume, it's that simple, no need to spend more money on expensive gold tip patch cords unless you just want to. God Luck and God Bless.
My wifi will not work unless my blue tooth is enabled, every time i turn bluetooth off my wifi goes off
it may be a faulty radio connection. Wires may be crossed where disabling the power to 1 affects to other. will need phone replaced. Make sure to mention blue tooth malfunction otherwise you'll have to pay for it.
Jan 04, 2014 | HTC Inspire 4G Smartphone
The signal will be fine for a while, then I get a "no signal" message...I usually get this after the radio has been on for a time
Hello
Please send me the model number of your Sirus Satellite Radio, and let me know whether can I place a solution before you. Ok.
Apr 02, 2011 | Sirius Satellite Radio Receiver
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
My xm plays extremely loud thru my car stereo.no matter what i set the volume at.it is either off when volume is set to zero or loud at any other setting.changing the output level on the xm receiver does...
Are you playing it directly thru your FM antenna connection, or using the RCA jacks? You have to set the FM modulator level. It is also possible that you have a new FM radio with a type of ALC that will raise the lever regardless, but your regular car radio volume control should work. do not wire this directly to a power amp, as you won't have the control that you need. Good luck, let me know more.
Apr 01, 2010 | Terk XM Commander Satellite Radio Receiver
When i plug my xm player in it gets stuck on media
Mine got stuck like that too. For a while it was possible to hold down the volume button and the mode button at the same time and it would unlock. But now that doesn't work. The Delphi tech support guy said I need to do a firmware update, but that isn't working either.
Oct 05, 2009 | Delphi SKYFi3 XM Radio Receiver
How do I set the clock on my Ranger professional with Blue Tooth
Press dimmer switch 3 sec, then when first two digits (hour( of clock flashes set hour using Phone Volume switches. Press dimmer again to set minutes, then when done press Dimmer once more to activate the clock. It displays in military configuration (e.g., 1:30 PM will read as 1330 Hrs) See user manual page 8
Jul 14, 2009 | Ranger TR-966 CB Radio
XM Radio online use problem
Yeah use sirius radio service. Prolly a reason that it isn't running it anymore because Xm and Sirius merged company's. So Sirius is the same as Xm now.
Jan 09, 2009 | Audio Players & Recorders
I want to listen to the radio while using Garmin nuvi 750
Hi, go to Tools, Volume, then select FM Trans and switch it on. Tune your car radio to a wavelength which has no signal, just background static noise, note the wavelength and adjust the Nuvi screen to the same wavelength.
Dec 30, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
My delphi xm is frozen
Hold the up volume button and the mode button at the same time. I have to do it almost every day. This is only a problem when using the car kit. No problem at all when using with portable kit or home kit.
Dec 18, 2008 | Delphi SKYFi3 XM Radio Receiver
MyFi FM Modulator Stopped Working?
hi there..there are few ways on installing xm into your car..you can use the FM Modulation that you're doing before..it goes like this...make sure that you're xm radio is turn off( with all the wirings unplug).....then, you just have to go on a blank channel(e.g 90.1) on your car radio...afterwhich, turn on your xm radio and go to MENU....and look for FM settings...and select the same frequency you have into your car radio...and just have to wait for 5 to 8 secs and you should be getting the prev. channels.....
IF: you're only getting prev. channels such as 1, 130 etc...you just have to call xm to send a refresh signal OR you can go to www.refresh.xmradio.com if you want to save more time...just type in your 8 digit radio I.D....
IF:
you're not getting the FM settings.....you just have to click the MENU and select the 'default settings/factory settings' then turn off/on your radio to save the changes...
i'm sure it'll work nowq at this time....Godbless!
Aug 23, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Garmin zumo 550 GPS Receiver Logo
256 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
