SOURCE: Fax Confirmation on a Canon MP830
To print a TX (transmission) report after each fax sent:
1. Press the Copy button if that light is not already lit
2. Press the Menu button
3. Press the Right arrow to get to "Maintenance / settings"
4. Press the OK button
5. Press the Right arrow to get to "Device settings"
6. Press the OK button
7. (You should be at FAX SETTINGS) Press the OK button again
8. Press the down arrow to get to "TX settings"
9. Press the OK button
10. Press the down arrow to get to "TX report"
11. Press the OK button
11. Press the down arrow to get to "Print for each TX"
12. Press the OK button
(You can have the machine print the first page of the fax with the report if desired)
13. Press Stop / Reset
SOURCE: Canon ImageClass MF6590
Press the plus or minus sign to get to the "Report Settings" then press ok.
Under report settings select "TX Reports"
then set "Output" to YES
under that set "report with TX image" to ON
This will give you a confirmation with the image of you fax. Here is the manual, info on pg. 251
http://gdlp01.cwss.com/gds/0300000953/MF6500_BASIC_en_us_R.pdf
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Memory Full Canon i-sensys Fax L120
try this
press "menu" and then "#" button, go to service mode. Select the "clear data function". and select "memory clear"
