Question about HP Photosmart C4180 All-In-One InkJet Printer
HP Photosmart C4180 part identification
The printer gives message "print cartridge access door is open" on LCD. Door closes snugly and there is no obvious blockage in the cartridge bay. I think I have identified a possible source of the problem. I have removed the casing to the left of the bay and I have found a loose piece of plastic that looks like a lever or latch, see pictures here: http://www.flickr.com/photos/auroraeclipse1/3674844107/in/set-72157620771071022/
I would be grateful if anyone could identify the item, and where it belongs, as I would like to get the printer working again.
  • 15 more comments
  • cm2009 Jun 30, 2009
    I have added a photo of the printer to the photo stream, can you tell me where it fits?
    can anyone tell me where the part fits?
    no unfortunately the message on the LCD, as above, appears.
    is there anyone who can tell me where this part fits in relation to the fuser assembly
    neither of the last 2 links offered show where the lever/latch can be re-located.
    as the latch has become separated, I want to re-attach it. do you know where the latch is attached to the sensor with reference to my photograph ?
    does anyone have hands-on experience with repairing HP printers?
    thanks nLinked, unfortunately the design isn't close enough to the machine I have to help, but that's the sort of picture I need to relocate the latch.
    thanks MNfisherman, what you say makes sense, but there is no place to attach a spring on the bottom of the door panel, and no sign of damage there, would another photo help?
  • cm2009 Jul 01, 2009
    emissionwiz in most cases, and with this kind of fault, I would agree with you that a new one would be purchased, but not this time.
    does anyone have a picture, or pictures, of the inside of the HP C4180?
  • cm2009 Jul 02, 2009
    the message about the cartridge bay door only appeared after I had removed the casing and so I think the latch was dislodged by me in the original opening of the casing. So I do not think any sensor has been damaged, just that the latch has been dislodged.
    What I need is a picture of the inside of a C4180 in order to put it back in place.
    As nobody seems to have one available, then I'll just say thanks to one and all for your time and suggestions.
  • cm2009 Jul 04, 2009
    as before, the lid is off the machine the printer paper path is free of any paper, and paper can be passed through it manually without any obstruction.
    the displaced latch is the problem, where does it fit?
  • cm2009 Jul 05, 2009
    hi kamal1984
    would it be possible for you to provide a picture of this please?
    thanks
    cm2009
    thanks Golu_fixya, the picture I need is with the printer's lid removed
    cm2009
    Hi pcmania, thanks for the Printertech site details. Unfortunately it only deals with HP Laser printers. It is s good site, but I'll just have to see if anyone out there knows of something similar for inkjet machines.
    cm 2009
  • cm2009 Jul 07, 2009
    xptareq2000, it sounds like you have seen where the latch fits, please could you describe this more clearly, thank you cm2009
    President:
  • HP Master
  • 1,447 Answers
Yes it is door switch liver please jum other device or make a substitue switch
thanks
Posted on Jul 05, 2009
  • 3 more comments
  • Sazeed Computer
    Sazeed Computer Jul 05, 2009
    it insert position and superglu pest here then solve your problem
  • Sazeed Computer
    Sazeed Computer Jul 07, 2009
    it is not possible for you because you are not a technician. it solve defferent technic
  • Sazeed Computer
    it is fit printer left side your right side
  • Sazeed Computer
    Sazeed Computer Aug 28, 2009
    yes it is door lock switch lever please se it position and assemble again then solve your problem
  • Sazeed Computer
    Sazeed Computer Sep 02, 2009
    Dear sir it is cartridge lock guide .Its function is cartridge lock after change or assembling cartridge,please insert properly then is ready
    Sergeant:
  • 213 Answers
Hello sir this isthe video all about your printer hope this helps you
or just try this sir if this helps you don't forget to rate it sir regards golu_fixya
    President:
  • 1,383 Answers
Yes i check this part it is connection of roller and fuser aseembely .it is used to give support to spring,
Posted on Jul 04, 2009
    President:
  • 942 Answers
Hi,, so you have already open the cover, check it correctly if there another paper hang on then remove it, then after that try to put your cover correctly, then reset your printer with in 30 min to drain the stored current
Goodluck!!!
Regards
PCmania
Posted on Jul 02, 2009
  • Neciforo Llanto Jul 05, 2009
    Hi
    Try to visit the two site below its all about printer error
    http://www.printertechs.com
    http://www.printertechs.com/tech/error-c...
    If you printer is Brother visit the site below
    http://welcome.solutions.brother.com/bsc...
    Good luck !!!
    Regards
    PCmania
  • 530 Answers
Actually friend there is a problem in your printer that needs to be replace but just try this because we encountered a such and it works with this: 1. remove and firmly put back the power cable. 2. reset the software of the printer. download it free from www.CSutility.com 3.re install the printer driver. and if still it doesn't work sad to say you need to replace the printer.
Posted on Jul 01, 2009
    Top Expert:
  • HP Master
  • 79,865 Answers
There is a sensor that tells the on board processor that the printer door is open, it is either defective or the circuit it sends this info to is defective, the thing is with these printers it is more expensive to fix them than to just get another one, have seen this over and over, you may disagree right now but the end of this scenario will be u buying a new unit when u conpare the repair codet with a new one that is problem a better machine, it's up to u. i show the cost of a new one at about $150.00
Posted on Jun 30, 2009
It does look like a lever used for the sensor. I was going to describe it, but I have just managed to find a document with pictures that might help better. Although its for a similar printer, the theory should be the same. You might be able to get it back in place under the sensor area. The document I found his here.
Hope I have been of some help in locating the missing piece's area.
Best regards
nLinked
  • Anonymous Jun 30, 2009
    Sorry forgot to say, if you go down to Step 3 and 4 on the document at the bottom, it shows the lever in place and when it's missing. You may be able to fit it back in.
    Regards
    nLinked
  • 11,896 Answers
The latch is attached to a sensor inside. Either the sensor has a short or open circuit, or there is a fault with the printer's firmware
  • Nate Stansfield
    Nate Stansfield Jun 30, 2009
    The latch has a spring that attaches to the bottom of the door panel. The tension of the spring tells the printer whether the door is open or not.
    President:
  • 987 Answers
  • Sibananda Jul 05, 2009
    Follow the steps below until the issue is resolved. All of the following steps might not be necessary to resolve the issue.
    Step one
    • With
      the unit still powered on, open Cartridge Access Door and look for any
      foreign debris. Remove any foreign material that may be obstructing the
      seating of the access door.
    • Close access door.
    • If the issue is not resolved, continue to the next step.
    Step two
    • Open the Cartridge Access Door again.
    • Slowly close the access door while listening for an audible click of the switch.
    • If the issue is resolved, you do not need to continue with the rest of the instructions on this page.
    • If the issue is not resolved, and/or there is no audible click, continue to the next step.
    Step three
    • Open the Cartridge Access Door and look into the mid-chassis opening to see if the metal lever is present.
    • If the metal lever is missing, then it cannot properly trigger the switch and the sensor is faulty. Continue to the next step.
    Figure 3: Metal lever present
    Figure 4: Metal lever missing
    Step four
    If you have completed all of the steps listed above and are still experiencing a problem, service the HP All-in-One.
  • 749 Answers
Does the printer work without it, if not what does it do?
    Sergeant:
  • 173 Answers
It si near fuer asembely spring
It is used with spring with fuser assembly.
Ink door open meassage
Open cartridge access door, observe left side door switch located, manually operate it feel weather its working or not, close door & check.. not rectified, insert peace of paper in it. check...
Feb 02, 2012 | HP Photosmart C6180 All-In-One InkJet...
C4480 74xl
>Remove print cartridges, >Switch off the machine..>Remove power socket>Wait 10 to 15 mts, >Clean the cartridge & printer contacts. >Switch on the machine wait till message appears for the cartridges>Insert mono cartridge close the access door, check for the message>Insert color cartridge close the access door, check for the message> no error message.. diagnoses end> any error during the cartridge loading replace particular cartridge
Dec 27, 2011 | HP Photosmart C4480 All-In-One InkJet...
How do i fix a cartridge jam?
Hi andmary,
While using the HP Photosmart C4180, the printer may display error messages. These messages alert you, as the printer's user, to any problems affecting the printer's performance. The printer can display the message "Carriage Blocked" on the printer's display screen, stopping any current print jobs and preventing you from printing anything until you resolve the problem. The error message can be caused by an actual obstruction, such as a stuck piece of paper, keeping the cartridge carriage from moving freely inside the printer. Sometimes the error is a result of a software error.
Instructions:
1. Turn off the printer, wait 15 seconds, then turn it back on. Press the "Setup" button on the control panel, then use the arrows to highlight "Print Report" and press the "Ok" button to print a self-test page.
2. Remove all the loose paper from the printer's input tray. Turn off the printer and open the back door by depressing the tab on the left side.
3. Pull out any stuck paper, being sure to turn the rollers to check for small pieces of paper. Close the back door and open the printer's front door.
4. Remove any stuck paper from the printer. Move the cartridge carriage from the left to the right side of the machine, removing anything that stops the carriage's movement.
5. Push down on each cartridge, then pull each one out of its slot. Replace the cartridges in their slots, then push forward on them until they each click into place.
6. Plug the printer back in and turn it on, then unplug the printer's power cord from the back of the machine and the electrical outlet. After at least 15 seconds, plug the power cord back in and turn the printer back on. If the problem persists, take the printer to a repair shop.
Hope this helps.
Thank you for using Fixya!
Sep 24, 2011 | HP Photosmart C4280 Aio Printer
HP Photosmart C4180 message "Scanner
Try resetting the printer:
Reset the printer
-Disconnect the Universal Serial Bus (USB) cable from the back of the printer, but leave the printer turned on.
-Open the cover of the printer and remove the print cartridges.
-Close the cover and wait for the Insert Ink Cartridges message.
-Disconnect the power cord from the back of the printer and wait for one minute.
-Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
-Open the cover and reinsert the print cartridges.
-Close the cover. If prompted, print a calibration page.
-Reconnect the USB cable, and try to print a print job from the computer.
Hope that helps!
Feb 07, 2011 | HP Photosmart C4180 All-In-One InkJet...
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
H P Photosmart C4180 All-in-One Printer - Scanner - Copier--no go.
Go to the printer SETUP button. Select the TOOLS option, then pressed OK. First, select the CLEAN PRINT CARTRIDGES option. Wait until it finishes. Second, select the ALIGN PRINT CARTRIDGES, under same TOOLS menu.Wait until this finishes and let me know if this cleared the wrong message.
Jul 30, 2008 | Office Equipment & Supplies
Printer won't print color only black and white
Reinsert the color cartridge. Give print command for page. Open Preferences in print window. Open the Color tab. Click on Print in Color. (It may have been set for black only.) Try printing.
May 23, 2008 | HP PhotoSmart C4180 All-in-One Color...
hi,
i think you are getting a false paper jam.
> try this.
> unplug the power chord from the printer
> open the rear access door
> check whether there is any paper or any bit of paper stuck inside
> if so remove it
> if not, clean the rollers
> now plug the power chord
> check whether you are getting the message
> if you are getting try below
> open the front door so that you will get full access to the cartridges
> now move the cartridges manually from right to left several times
> check again
> if still you are having the problem
> service the unit
Mar 15, 2008 | HP PhotoSmart C4180 All-in-One Color...
HP Photosmart C4180 All-In-One InkJet Printer Logo
284 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
