Question about Canon NP 7130 Black and White Copier
When i turn on the copier it is stuck on 10 copies and a light flashes to the left of the copy number. I don't have a manual. I don't know what the flashing light means.
  • 149 Answers
If the light is a red light with a flash shape then the machine probably has a jam. Look for jams and once you have cleared any jams switch the machine off and then on again. It could be the toner light if there are about six red dots - in this case you need to add toner.
Posted on Jul 06, 2009
Upper left led flashing don't know why. Looking for manual
Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
Aug 04, 2011 | Uniden Cordless Phone
Don't know how to change paper size on LED screen
what is the model
but at model **3 **6
you can try this:
1- press key drawer & copy together for more 5 seconds
2- when all lamps flashing press {drawer} till the drawer you want to setup
3- then press {copy} till the {other} lamp flashing - "the last one" see the number on the LED screen
4- change the LED screen number "13" to "20" for LT size
Jun 28, 2011 | Toshiba Office Equipment & Supplies
Do u know what fuses n what relays run to the tailights my brake lights wont turn on brake swith isnt stuck and bulbs are good 1999 mercury cougar
The fuse for the stop lamps is located in the passenger compatment fuse panel (see picture of location below) The fuse you are looking for will be in the number 24 position (see picture of layout below). this should be in your owners manual if you have one. If you don't have an owners manual and would liike a copy, you can email me at csautomotivecars@att.net with your make, model and year and I will be happy to email you a copy at no charge to you. i hope this helps and good lick.
Jun 01, 2011 | 1999 Mercury Cougar
My alarm light and copy light are flashing and the display says error code 6A00 I have tried turning the machine and computer off and then rebooting , but it didn't solve the problem
I had this error (6A00) on a MP760 after a couple of months of not using it.
I switched it off, opened the lid and manually slid the cartridge-tray to the left.
Then I used a piece of tissue to clean the base-pad where the heads are stored. It turned out to be stuck in a kind of upward position and somehow the mechanism that moves the tray is released so nothing happens when you switch on the printer.
Touching it snapped it loose. Remove all ink residue, move the tray back to its most right position and close everything.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Canon PIXMA MP830 All-In-One InkJet...
When I try to make a copy the machine make a screeching noise and a blank copy comes out.
Leave the lid up when you make the copy and see if the light bar moves from left to right when copying. Check the scanner lock knob under the left hand side where the papers come out. Make sure it is not locked. Sometimes the scanners get stuck a lot and can cause blank copies. If it is stuck then you just have to remove the glass and then clean and lubricate the steel bar at the back that the whole unit rides back and forth on. Once that is doene it should work fine. Make sure to manually run the scanner bar out and back a few times so that you can get the whole rail lubricated. Do all this with the power turned off.
Good Luck and Thank You for using Fixya.
If I helped, please let me know via a testimonial today!
Oct 08, 2010 | Sharp AL 1631 Copier
After replacing the drum cartridge the copier still wont copy and the drum light is still on.
To reset the drum light on your AL1000 press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
Sep 21, 2010 | Sharp AL-1000 Copier
Copier is Canon PC 720 Copier turns on, but makes
You said you unplugged your copier, did you unplug it for 10 to 15 minutes before plugging it back in, plug it into a differed
outlet that you know works and plug it directly into a wall outlet instead of a power strip. Check to see if your copier reaches stand-by mode then make a test sheet.
If this does not work then you have probably have an internal processing component which requires attention.
Apr 02, 2017 | Koutech Systems PC720 (IO-PC720) (IOPC720)...
Sharp al1631 copier doesn't work after replacing new drum
Press the following keys in sequence and as fast as possible. Clear, exposure mode (far left key), clear, exposure mode. In other words...clear, far left, clear, far left. The display should go blank if this is done properly. If so then enter 24 as if you were going to make 24 copies, then press print. You should get flashing 000. then enter 7 as if you were making 7 copies, then press print. Should get flashing zero's.
Hit clear a few times and there you go!
Here it is in a line:
"C",far left, "C", far left, 24,print,7,print, CCC or turn machine off then on.
Good Luck
Oct 21, 2009 | Sharp AL 1631 Copier
Canon NP 7130 Black and White Copier Logo
155 people viewed this question
old marine
old marine
