Question about Linksys WRT160N Wireless Router
My internet explorer keeps locking up on both computers hooked to the router
  • Bradley Ward
    Bradley Ward May 11, 2010
    Do you have the security set up on the router? If so, the settings there may be the problem.
  • 496 Answers
Try another web browser and see if that helps i recomend firefox i havent had any problems with it :)
Posted on Oct 01, 2009
    Problem Solver:
  • 6 Answers
Probably a stupid question but have you tried a Firmware upgrade?
Posted on Sep 09, 2009
2 Suggested Answers
govinda123
  • 2263 Answers
SOURCE: Internet Explorer cant bring up web page when the
MAke sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Jan 14, 2010
I have just purchased a belkin enhanced wireless usb adapter N 150, i have managed to install the software and and connect to my router, the signal strength is strong, but when clicking on to internet...
Take an Ethernet cable, and connect one of the LAN ports on the router to the network-port on your computer. If you cannot get Internet access, then it is the router that is the problem, namely, that the 'WAN' side of the router has not connected to the Internet.
Oct 19, 2010 | Belkin (F5D7230-4) Router (587009)
Internet Explorer cant bring up web page when the wireless router is hooked up. It will when the computer is hooked up directly. The computer says that is connected to the wireless router but IE still cant...
Jan 14, 2010 | NetGear RangeMax WPN824 Router
I checked my firewall. All cords are connected properly. The same
When using a router with your internet connection (cable, dsl modem etc.) hooked directly to the routers data port it will use the roughter's dhcp to assign ip addresses to other computer on the network. If you have your internet connection hooked directly to a computer and are using internet connect sharing then you must disable the dhcp service on the roughter because the internet connect sharing has its own dhcp and it will assign all the ip addresses. to get into the roughter's setup you open a browser (internet explorer, mozilla etc.) and type 192.168.1.1
Aug 22, 2009 | Linksys Wireless-G Broadband Router
Hook up router and can't access internet from wired computer.
Sometimes the modem-computer-router not "sync" together.
Try this.
1-hook the computer to modem. Internet yes? good.
2-hook the computer to router and check you IP. If it like 192.168.1.2,
the router's DHCP is working.
3-reset router to default setting.
turn off all and turn on modem, router, computer.
keep me posted.
Jul 06, 2009 | Belkin (F5D7231-4) Wireless Router
Router problem
Hi .
First who is your service provider?
Can you connect to the internet if you directly hook your modem to your computer.
1>If so connect your Modem to your router on the colour code slot on the router which says modem
2>Connect a cable from the router to your computer
3>The lan light on the router should be turned on
4>Check wether your lan says connected . To check that click start-> control pannel -> network connections
5>If it says connected try internet explorer settings
6>If it says limited or no connectivity
Click start ->run -> cmd->ipconfig
7>It should say ip address as : 169.254.x.x.
8>If so type ipconfig/release
9>It shoul say ip address: 0.0.0.0
10>Type ipconfig/renew on command promt
12>Disable and enable lan
Let me know if this helped and also if you dont what kind of messages you get .
Mar 02, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
How to lock a linksy box? A technician installed my wifi router together with our local dsl, but then we forgot install a password to make sure that not anyone can just hook up to my router, wihtout me...
you need to log into the router go to internet explorer window and type in 192.168.1.1 go to the security tab or wireless tab and setup a wep or wpa key now remember (WRITE DOWN) this code because any of your computers that you want to use with wifi you have to go in and enter this password in order to connect to the network
Feb 05, 2009 | Linksys Wireless-G Broadband Router
ATT/SBC gateway router....
Take the ethernet cable from modem to PC and hook it into the router(modem to router)...run another ethernet cable from the router back to that PC(router to PC). All you machines should be fine then.
Jan 25, 2009 | 2wire 2700HG-B Router (2700HGB)
WPN824 intermittent reception problems -
that means the router is not configured properly. try to use the setup wizard that comes with the router. reset the router first by pressing the reset button for 30 seconds then run the setup wizard thriough the internet explorer browser of the pc.
Aug 18, 2008 | NetGear RangeMax WPN824 Router
Cannot complete downloads
when you say that everything works when the router is NOT hooked up to the PC, does that mean that you have the DSL modem connected directly to the computer?
then, when you hook up the router, you're connecting it BETWEEN the DSL modem and your computer?
You probably need to log in to your router and set it up to connect through the DSL modem to the internet: it may not do it automatically.
is this computer running windows XP?
if so, go to control panel, then network connections.
if you double click on the local area connection, and go to the support tab, it should list something like this:
Address type: assigned by DHCP
IP address: 10.0.1.100
Default gateway: 10.0.1.1
Try opening internet explorer, and typing in the numbers it lists for default gateway.  hopefully, that will bring up the configuration screen for your router.
Mar 26, 2008 | Computers & Internet
Blitzz Router
Ah, you can no longer use the modem or the Blitzz screen to connect to your Internet connection. You'll need to patch another Ethernet cord from the router to your Ethernet port on your computer and it should automatically connect. If you still get prompted to dial, open up Internet Explorer and ignore any prompts to dial and then click Tools, then Internet Options, then click the Connections tab at the top, then click the selection to Never Dial a Connection. Confirm your choice by clicking OK and then try browsing the Internet like usual.
Aug 30, 2007 | Blitzz Technology BWA711 (B3WL000900)...
Linksys WRT160N Wireless Router  Logo
157 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
