Question about RCA D52W19 52" Rear Projection Television
POSSESSED THE MENU SCREEN KEEPS POPPING UP AND THE VOLUME GOES UP AND DOWN
  • 1030 Answers
SOURCE: tv problem
i have encounterd this problem a few times in the shop.. i resolved the issue by replaceing the front control panel pcb. i had one instance of a bad ir sensor causing the problem
Posted on Jan 04, 2008
nick_helpap
  • 334 Answers
SOURCE: RCA projection TV
are buton on remote sticking or on tv it self clean controler tap on button
Posted on Oct 07, 2008
video-tek
  • 150 Answers
SOURCE: menu screen appears constantly, volume decreases by itself
Hi, common issue with rca sets, you need to replace the tact switches on the front control board. If your not good at soldering / un-soldering you may be able to still purchase the whole control board, call a local tv shop with the complete model # and chassis # of your set and they can give you price & availability, video-tek
Posted on Jun 02, 2009
  • 556 Answers
SOURCE: i have a rca 52 inch projection tv and the menu
Your front panel buttons need to be replaced. They are sticking or are shorted.
Posted on Sep 11, 2009
  • 1039 Answers
SOURCE: the main menu keeps popping up and the volume goes
One or more of the function buttons on the front of the tv are bad. Replace them.
Posted on Nov 01, 2009
On my technika TV menu screen keeps popping up,how can i stop this?
problem seems to be solved,i altered the auto time feature and it settled down
thanks for replying
Bob Hawksby
Mar 31, 2014 | Audio Players & Recorders
I purchased my Norcent computer monitor four years ago. Now, the sub-menu Contrast/Brightness selection keeps popping up on my screen. So, I have to either push the #1 button to Exit or the #2 Adjust...
It seems to be a hardware issue with the buttons. They are stuck or the rubber cushion under the button has gone bad. That's the reason they are getting pressed automatically. You may take to a local store for a small repair.
Regards,
Shrey
Jun 04, 2011 | Norcent Technologies LM-965W 19" LCD...
RCA HDTV Monitor; menu popping up and volume going down
The small signal board needs replacement. You can get replacement small signal boards from www.tvrepairworld.com
Jun 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
The volume menu on my hp w2207 monitor keeps popping up and the volume on that menu auto-decreases down to 0. This does not bother me because the volume still works fin, since i dont use the monitor to...
Sounds like one of the buttons on the monitor is sticking physically. Try:
  • checking the buttons for dirt that might be holding it in
  • cleaning the buttons with a soft brush
Apr 15, 2010 | HP 22" Widescreen Flat Panel TFT LCD HD...
The main menu keeps popping up and the volume goes up and down.
Nov 01, 2009 | RCA R52WH76 Television
Volume goes down to 0 and the menu goes on and off.
A bad connection on the small signal board may be the problem! Have a Tech check this connection, it may be to tight due to the heat shrink tube. Have them peel it back to reduce the strain! Should work then!
Sep 11, 2009 | Philips 32PFL6704D 32 in. LCD TV
My volume menu from monitor pops up, volume auto-decreases
Was something spilled on the volume key? Sounds like it is stuck... you can use a fine toothpick and plain water to "scrub" around the key, there may be some buildup that inhitbits the key from "unpressing".
Hope this helps!
-- RT
Sep 02, 2009 | HP w2207 Monitor
My menu keeps popping up tv and my volume dont work
Most of the time this is caused by one or more of the front panel buttons being bad. I would have all of them replaced.
Jul 16, 2009 | Televison & Video
Volume & Menu screen flipping out
Replace all of your contact switches on front panel board power/off/on vol- vol+ ch- ch+.
Jan 05, 2009 | RCA HD52W66 Projection Television
RCA projection TV
Oct 07, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W19 52" Rear Projection Television Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
