Question about Kenmore HE2 Plus Front Load Washer
F-22 Error HE5T Front Load - the machine stopped during a load and will not allow me to open the door. Has an F-22 Error. Even pressing stop twice and unplugging machine, the door still will not open.
  • 15,935 Answers
This is an indication of a door latch failure and/or interconnecting wiring problem. The first step in troubleshooting the problem is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of your washing machine. Sometimes these error codes are erroneous and can be easily cleared by resetting the CCU. If the error code reappears following a CCU reset, then you have a genuine problem. In addition, if the door latch remains locked following this procedure, there is a manual release you can use to open the door. Follow these steps:
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with a 2 x 4, it makes access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
If you still have the error code displayed, inspect the door latch mechanism for any broken, loose, or missing components. Next, open the top panel of the washer by removing the three screws in the rear of the washer that hold the panel in place. With the screws removed, the panel will slide back, then off. Locate the door latch on the right hand side behind the front panel. Inspect the wiring harness from the door latch to the to CCU. The CCU is located directly behind the wash tub in the top rear of the washer. Make sure all the connectors are snug and not loose or broken. In the majority of cases, a persistent error is a failed door latch. If all these preliminary checks are unsuccessful, replace the door latch. Follow these steps:
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
NOTE: Another method is to access behind the front panel from the top with the top panel removed. Either method works, but I have found that going through the front offers better access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
I load the clothes into the washing machine, I turn it on select cycle and the door locks and will NOT unlock. The door will however unlock after the cycle is finished.
Not sure if you're unable to open the door AFTER you stop the cycle. That may be normal operation as a safety measure (won't open until after your cycle has completed). However, if your model DOES allow for opening the door during cycle operations then your electronic door lock may be defective.
Mar 08, 2011 | LG WM-2277HW Front Load Washer
Washer does not spin and displays an LE error
LE is lock error..This most commonly means that the interlock is faulty...This is component which stops the door from opening during wash, and allows power to the machine when the door is shut..Replacement probably needed..Not a big job...Good luck....Nomess
May 22, 2010 | LG WM-2277HW Front Load Washer
Door won't open
If you can drop down drain hose to floor level then drain into bucket this will allow you to open the door . Sounds like coin in the pump /remove the filter and clean check pump blades are free...Good luck
Apr 28, 2010 | Whirlpool GHW9100L Front Load Washer
I'm getting an F26 code on a Kenmore Elite he5t front load washer
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore F-28 error - door locked can't get in
Unplug the machine.
Wait 15 seconds.
Plug machine back in.
Press and hold the Power button until the lights come on.
Press and hold Start.
When you hear a click, press Stop.
Open door.
You still have an F-28 issue but you can at least get your clothes now.
Hope this helps.
Jun 09, 2009 | Kenmore HE2 Plus Front Load Washer
Model GHW910PWO shuts down during the rinse,spin cycle
First, pressing cancel twice should clear the error code and it should restart when you press start. Then you can press cancel to stop the whole thing This should also unlock it. Unplugging it for a long while may also clear the code and unlock the door, not sure.
the F-9 says it is an overflow condition and may need to be serviced. The F-11 says there is a serial communication error.This might be the case if the pump is running overtime due to clogging.
 See  http://appliancejunk.com/forums/index.php?topic=1785.0
To check if the filter is clogged, open the front panel, put a bucket in front of the unit, unseat the rubber feet holding in the white plug,  pull the white plug out so when you unscrew it, any water will run into the bucket, then unscrew it and clean the filter. screw the filter back in, set the white plug back into the unit, being sure to secure it with the rubber feet.
As for it stopping, you may be filling it too heavy and the motor stopped if it over heated?
Apr 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Shows "LE" in display.
"LE" error means the motor has overloaded. There is no way to fix this yourself. You will probably need a new motor. Call for an engineer.
Jan 20, 2008 | LG WM-1480FHD Front Load Washer
Washer stopped during cycle
cleanlaundry If your washer is less then a year old do nothing and call the manufacturer ASAP. It is under warranty for one year. Gendos...post back
Mar 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
82 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
