Question about Samsung HT-X20 Home Cinema 600W Theater System
The system goes into Sleep mode every 5 minutes and just before going into the sleep mode,''protection Error'' flases on the screen
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 70 Answers
Unfortunately, the unit is not going into "Sleep mode".
The PROTECTION error actually means that the unit is overheating.
The unit shuts itself off to avoid further damage.
Try to make sure that no other device is below the unit. Also make sure the unit has adequate ventilation on the back of it.
If not, call 1-800-7267864 and let them set up a repair order for the unit.
Posted on Jun 30, 2009
Won't go into sleep mode
Which operating system ?
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work.
This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation.
Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money!
Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow.
The Shut Down menu appears.
Point at "Sleep" and click on this option.
Your Windows 7 computer goes into sleep mode.
Wake your computer from sleep mode by jiggling the mouse.
There may be a delay of a few seconds before your hardware powers on.
All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode.
Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time.
Click "Start" and select "Control Panel." Click "System and Security."
Click "Power Options."
A menu opens.
Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode.
If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Your Computer in sleep mode
First, save all of your work. Information in computer memory is not saved while your computer is on standby.
From the Start menu, select Settings, then Control Panel, then Power Management.
Click Standby Beside When I Push the Power Button.
Push the Power button.
Automatically Putting Your Computer on Standby
Save all work before leaving your computer.
From the Start menu, select Settings, then Control Panel.
Double-click Power Management.
Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks.
Click OK. Your computer will go on standby according to the schedule you have entered.
Putting Your Computer in Hibernation
Double-click Power Settings.
Click on the Advanced tab.
At the When I Push the Power Button On My Computer screen, click Hibernate.
Click the Power button.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
LCD monitor turn to sleep mode
Does it turn off or go to sleep? If it turns off , there may be a setting that needs to be reset or reprogrammed. If it goes to sleep because of inactivity, just move mouse to awaken it
Sep 27, 2012 | Vocopro Ltv-5 LCD Display System
How do I turn off the sleep mode on my monitor?
Control panel Power options adjust time for monitor time to sleep you can adjust 5 minutes to never the option available same can be done for hard disk. This is necessary as even monitor is active and when hard disk goes to sleep you may end up in same situation
Alternatively you can activate screen saver by
right click on desktop, settings screen saver choose screen saver set time to activate screen saver.
Sep 03, 2011 | Computers & Internet
Hello, We have just transferred our AWA DVD 5.1 Home Theatre System for improved sound to our television from our home theatre projector. I was wondering if there is any way of turning off the sleep mode...
Just go into the device sleeper mode and now used the romte pushes the SLEEP button on the remote a few times to make sure the SLEEP mode timer it is to be turn off.This problems should be solved.
May 09, 2011 | Televison & Video
HOW DO I TURN OFF THE SLEEP MODE ON MY PRINTER BROTHER MFC 7420
Setting the Sleep Time reduces power consumption by turning off the fuser inside the MFC while it is idle. You can choose how long the MFC is idle (from 00 to 99 minutes) before it goes into sleep mode. The timer is automatically reset when the MFC receives a Fax or PC data or makes a copy. The factory setting is 05 minutes.
To turn Sleep Mode off press Menu/Set, 1, 6, 2. Then use the dial pad to enter the length of time the MFC is idle before it goes into sleep mode, in this case 00 so it wouldn't go to Sleep mode at all. Press Stop/Exit.
Feb 04, 2011 | Brother Office Equipment & Supplies
I am unable to access the internet from sleep mode Can only get on internet from shut down mode
Three possible causes of sleep mode. first, an extensive screensaver with password lock prevents display. A condition that is observable as a blankscreen also known as sleep mode. Second, a computer power saver settings that shutsdown during idleness. Third, An improper shut down of the computer would have caused a sleep mode to save the system data files.
Restoring the computer to regular functionalioty
First solving predictable sleep mode settings
1. A movement of mouse pointer across the screen should reestablish unprotected password modes
a. password protected sleep mode would display an promp message requiring key code soon after the mouse pointer has changed direction
sloving unpredictable sleep mode settings
1.A computer power saver, screen saver, or splash screen displays prevnting programs acess would require manually powering off the computer system.
a. A manual power back on of the system should restore to program functionality mode
important notes
1. contact expert technical assistance
Dec 20, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
Blank screen after monitor sleep just blue flashing light
First of all you can change the Power Settings in Control Panel. You can configure as you need. I mean after how much wait it should go for sleep n all.
If it takes 5 min. to wakeup that means you have so many applications running that system cannot manage or RAM is small.
The final solution just remove the Display drivers and reinstall it.
After removing please restart the system once to proceed further
Aug 03, 2009 | HP Pavilion dv9000z Notebook
Protection Error
maybe the audio amplifier IC´s are in bad conditions and need to be replaced
Jun 30, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Monitor going to sleep
Please look at the video card of your computer,did you set it correctly?
Apr 01, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Aspire one with windows XP. Won't turn back on while in sleep mod
I've had spotty luck with Windows and sleep or hibernate modes. I would suggest just disabling sleep/hibernate mode. The options can be found under the control panel under power options. While turning off the sleep mode won't help your battery life, if you ask me, it beats having to power off the laptop by pulling the battery out. If you don't want to turn it off, you can try adjusting the amount of time it lets pass before it goes to slee.
Mar 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
Samsung HT-X20 Home Cinema 600W Theater System Logo
414 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
