Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
I have a canon MP140 but the printer dont work anymore.
After replacing the cartridges the printer gives me a blinking code E3 on the display. Also the LED with the blitz sign in a triangle colours yellow.
When I open the cover to replace the cartridges, these don't go to the left side of the printer anymore.
How can i solve this problem, pls help me.
    President:
  • 2,306 Answers
E 3 is telling you that there is paper or something still in the paper path. You need to clear the jam, if there is nothing in the path, there is a defective sensor which requires a shop repair.
Posted on Jun 30, 2009
Error 19
Hi there-
Below are a list of the error codes for this model.
E16-E19 = Failed to scan head alignment sheet.
You can find this information at http://www.usa.canon.com/cusa/home
CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
[Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Nov 29, 2013 | Canon PIXMA MP150 All-In-One InkJet...
How to fix error 24 for mp 160????
Hi
This is a purge unit error hence you need to check and make sure the purge unit is working fine. If not you need to clean it.
THE PURGE UNIT IS THE ONE ON THE RIGHT SIDE WHERE THE CARTREIDGE RESTS WHEN YOU TURN OFF THE PRINTER.
And at the same keep the below mentioned error list for your future use.
CANON MP140, MP145, MP150, MP160 ERROR CODES RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E3-3 = Paper jam
E4 = No ink
Direct Printing
E29 = EEPROM error
Jul 31, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Error code E3 with no paper jam
it is problem your printer can not feed paper properly or problem paper feed sensor please try to resum button press when occard this E3 signal or clean sensor or claugth
Nov 21, 2009 | Computers & Internet
My canon mp140 keep on flashing E and then 2 whats the problem
e2 is no paper, E3 is paper jam, E4 is no ink, E5, wrong ink, E8 waste ink absorber full
Jun 24, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My roller dont take in the paper
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error. The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix. When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Jun 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP140 error code E
Replace with genuine cartridges is the best policy.
Sep 21, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
E3 in my canon mp140 can u help me?
There this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 09, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
Apr 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon PIXMA MP140 error code E 2
error E 2 => The machine is out of paper. / Paper does not feed.
Reload paper in the Auto Sheet Feeder and press the Black or Color button.
Feb 29, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
362 people viewed this question
old marine
old marine
