Question about Dishwashers
Broken handle on Maytag dishwasher #MDB6650AWW
  • 172 Answers
SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Posted on Oct 30, 2008
SOURCE: dishwaher will not fill
is the float switch stuck in the up position?either soap built up or some other object may be stuck under it.
Posted on Nov 04, 2008
huuum
  • 750 Answers
SOURCE: Maytag dishwasher MDB7600AWW handle
Welcome
At the site below is the diagram for the door latch and assembly.
You can order there too!
W10130694 HANDLE, LATCH (WHT) (Series: 10) In-Stock $ 16.75 99003347 LATCH ASSEMBLY (Series: 10) In-Stock $ 21.80
http://www.pcappliancerepair.com/model-display.php
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Dec 25, 2008
  • 11 Answers
SOURCE: maytag mdb6650aww dishwasher is dead.
Well the most probable reason is that the wiring connectors located at the bottom of the dishwasher behind the toe panel were wired wrong and have shorted out or burned off, the next thing to look at is the control panel. (not control board, the actual panel with the buttons) you can take apart and check to make sure the ribbon cable is still connected, but most likely will be one of those two problems, If you need to get down and really dirty the next step would be to start taking voltage readings.
Posted on Jan 15, 2009
SOURCE: The handle on my Maytag Quiet series 100
I had the same problem with my QS 100. I disconnected power first via the breaker then removed the 11 screws. I couldn't loosen the two electrical connections, but the door pulled far enough away to inspect the handle mechanism. The plastic handle fell out of whole handle assembly rather easily because two molded plastic pins protuding from either side had broken off and were loose inside. There was also a pair of molded plastic v-shaped forks right on the panel to hold the handle assembly and these were damaged but they just to seem to act as guides only (as the handle assembly is held in by two of the screws that were removed). Replacing the v-shaped forks would require a whole new door which I am NOT doing. It looks like I can a replacement handle in the same color with new pins (I am reading they may now be metal) for about ##15. Pretty easy to disassemble and inspect, only about 15 minutes.
Posted on Dec 02, 2009
DISHWASHER WILL NOT TURN ON WHEN I PUSH THE BUTTON. i CHECKED POWER TO THE UNIT AND IT'S GOOD.
Are you certain the door is closing at the switch,. if not, inspect the close door switch real well.
IS there any water in the bottom -- perhaps it may be clogged and refuses to call for more water (i.e. turn on).
Best regards,
Ck
Dec 03, 2011 | Maytag Dishwasher
MDB6650AWW - How can I remove the spin arms and filter to clean them?
The best option is to go to this diagram and see the knobs holding the wash arms in position. Items 2 and 33.
Hope this helps. Best to take photos on the way so that you know how to fix them back in. Just in case.
Nov 26, 2010 | Maytag Dishwashers
Maytag Dishwasher - MDB6650AWW wont fill after initial fill
sounds like a bad module control. let me know if this helps with a 4 thumbs up post
Feb 27, 2010 | Dishwashers
Door lach/handle plastic pins have broken off and two pronge ears attached to door that hold handle in place have also broken off. This is a Maytag Model MDB5600AWW dishwasher.
handle was redesigned with a metal rod through the attachment points to prevent breaking. the handle and latch comes as a complete assembly (you don't have to put it together).
Jan 09, 2010 | Maytag Dishwashers
Maytag dishwasher model #MDB6650AWW no lights on the conrol panel Door switch has power.
if the door switch has power and you cant get the dishwasher to do anything then you will need a new control.. ..
Feb 20, 2009 | Maytag Dishwashers
Broken maytag door latch assembly Maytag quiet series 300: the latch is not working, door is closed and cannot open, seems something snapped inside, how can I open the door ? and change the broken part ?
To open this latch, the handle works as a lever to push inward when you push up on the handle. If your handle if broken, it has probably ceased to work as a lever (the pivot pins have likely broken). You want to push in on the handle to open the latch, ideally toward the bottom of the handle opening. Once you get the latch open, you'll likely want to order a replacement (here is one source : http://www.repairclinic.com/PartDetail/Door-Latch/W10130694/1266678 ). Remember to turn off the power to the dishwasher, and you'll need a star head driver to remove the screws from the inside of the door to access and replace the latch.
Andrew
Nov 17, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishwaher will not fill
Nov 03, 2008 | Dishwashers
Hi olabrk,
Mike Anderson
Oct 30, 2008 | Maytag 24 in. MDB7650AWS Built-in...
Maytag MDB6650AWW will not fill
My Maytag MDB6650AWW dishwasher would not fill. The lights on the panel were on when I tried the wash cycle. I tested the water valve but no voltage was found during the cycle. I thought it may be the timer/control circuit. I traced the power from the door switch and found no power going to the float switch leg. I found two wires completely cut through (one going to the Water Valve) and three others partially sliced.
Nov 03, 2007 | Maytag 24 in. MDB7650AWS Built-in...
Dishwashers Logo
151 people viewed this question
Top Dishwashers Experts
Owen Barnes
