Question about Goodman GMS90703BXA Heater
No heat, trouble shooting light has continious flash.
Can anyone help? Gas furnace will ignite but won't stay lit. I thought it was the flame sensor, but I replaced it and still not working? Could the be a circuit board problem? If so how can I be sure? Goodman GMPN 120-5 my goodman will ignite the burners but they will blow out.it will cycle a few times then shut down.please help.
  • 42 Answers
There is a vacuum sensor on most units tied from the exhaust gas fan to the sensor. Does the unit try to start? If the unit's exhaust fails to pull the switch it will turn off after about 30-45 sec after starting. "IT" thinks it's not exhausting and stops to keep from overheating. Do you have this exhaust fan and rubber hose to sensor? Can you see if that fan is turning on start?
Posted on Nov 10, 2007
2 Suggested Answers
SOURCE: No heat, trouble shooting light has continious flash.
Try replacing the filter. Low air flow will allow the furnace to overheat. Sounds like a simple answer. Wish I had tried it before buying a flame sensor and controller. Live and learn I guess.
Posted on Jan 02, 2007
I've got good flame replaced Powerpile pilot won&#t stay lit
The flame sensor is not producing enough volts to hold the gas valve open for the pilot light. Make sure the SIDE of the pilot flame is touching the sensor. If it in engulfed by the flame it won't work right.
Jan 01, 2016 | Cozy Heating & Cooling
My York furnace sometimes doesn't completely ignite
A noisy inducer probably is headed for replacement.
The igniter can produce a healthy glow and still be defective. Mine had to be replaced with a new, improved one.
The thermocouple could be defective even though it seems to open the gas valve when it should.
The heat sensor in the bonnet could be defective. That controls main blower operation.
The heat exchanger could be cracked.
Jan 10, 2014 | Heating & Cooling
Goodman furnace Model GDS80703AXBB -fan comes on then igniter light comes on, then burners turn on but shut off right away and wont stay lit. Now igniter light wont come on so burners not coming on at...
Sounds like either the flame sensor is not working.
The sequence for starting the furnace is:
1. extraction fan on
2. pressure sensor (for fan)
3. ignitor (spark or glow plug) comes on
4. gas valve opens up
5. ignition of flame
6. flame sensor (or temperature sensor)
7. plenum temp. sensor
8. main fan starts
It is most likely that the flame sensor is dirty or gone,
or (and I hope not), the module is gone and needs to
be replaced.
Sep 10, 2017 | Heating & Cooling
Goodman furnace gmh95090cxac wont stay lit keeps clicking will lite then clicks back off what would be the problem
Hello, if the burners light but do not stay on for more than 10 seconds, I would clean the flame sensor. The flame sensor is a metal rod that is on the opposite side of the Igniter, sometimes it gets coated by oxidation and does not sense the burner flame and shuts the Furnace down. To clean to kill power to tje furnace, remove flame sensor and clean with a steel wool, then reinstall and start Furnce back up. If this does not work then most likely the Igniter is too weak to ignite the gas and will have ro be replaced.
Oct 29, 2012 | Heating & Cooling
I have a gas furnace that won't stay running. It
Sounds like its the pressure switch try jumping it out some times you can fool it into working
Mar 05, 2012 | Heating & Cooling
Furnace goes on red light stays on exhaust fan for heat chamber goes on gas igniter comes on but soon as gas comes on furnace kicks off have to shut off power for furnace for it to reycyckle but same...
Check your filter to make sure it is not plugged. If it is plugged - replace with filter recommended for your furnace. Every manufacture recommends you have your furnace checked and cleaned on an anual basis to keep itrunning safely and at it's top efficiency. If the filter is plugged or the blower wheel plugged, the furnace will shut itself off. Make sure all registers are uncovered - suppply and return registers.
Jan 03, 2011 | Heating & Cooling
Pilot light will stay lit Lennox G8D2-82
You may need to replace the Thermocoupler. It screws into the gas regulator and the sensor end is set in the flame of the pilot light. You can get one at any appliance parts store. The Thermocoupler simply feels the heat of the pilot light and sends a very small amount of voltage to the gas switch that opens when your thermostat calls for heat. If the pilot light isnt lit, no voltage from the sensor and no gas can be released by the regulator.
Anyone can replace one. Just find the tip that sits in the the pilot flame when you try to ignite the pilot light. Follow it down to the regulator and unscrew it. There is no gas involved. It is Ultra Low Voltage. No danger.
Be sure to turn off the power to the unit before you begin removal. Take it to the parts store along with your furnace brand and model number. If you see any identifiers on the regulator, note them and take them with. When you replace it be sure to have the sensor end up in the flame of the pilot.
Sep 29, 2009 | Heating & Cooling
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Jan 06, 2009 | Heating & Cooling
Ruud Achiver series Furnace issue
Sounds like it may be a bad flame sensor. After the ignition, the flame sensor needs to send 24v back to the gas valve to indicate the the ignition took place. If it does not do this, the gas will shut of as a safety precaution. The flame sensor can often be cleaned up with a piece of sandcloth to fix this problem, or it may be replaced.
Dec 14, 2008 | Ruud Heating & Cooling
Nov 16, 2006 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
394 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
