Question about RCA HD50LPW42 50" Rear Projection HDTV
HD50lpw42 rear projection tv. Once tv is on for a while it shuts off. Suspected fan problems, I placed a floor fan behinde tv, a few min later tv comes back on. Could it just be the fan or could it be something more. Thanks for your help!
    Problem Solver:
  • 3 Answers
Make sure your filter screens are kept clear.
Protect Components from Overheating
• Don’t block ventilation holes on any of the components. Arrange the components so that air can circulate freely.
• Don’t stack components.
• If you place components in a stand, make sure you allow adequate ventilation.
• If you connect an audio receiver or amplifier, place it on the top shelf so the heated air from it won’t flow around
other components.
Hope this helps!. Otherwise in your owners manual, under troubleshooting it states:
TV turns off while playing
• Sleep Timer, Wake-up Timer, or Watch feature may have been activated. Go to page 45 or 69 for instructions.
• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then turn on again. If this
happens frequently, the voltage in your house may be abnormally high or low.
• The sleep timer may be set.
• Unplug. Wait five minutes. Plug in again.
Hope this help you out.
Posted on Jun 30, 2009
RCA P56950 Powers on then 10 mins later powers off, repeats cycle. Then channel display in TV changes by itself
may be some thing is stuct on the controt pannel power button or others check. try this it may work
Jun 04, 2012 | RCA P56950 56" Rear Projection Television
I have a RCA HD50LPW42, Rear Projection tv and my bulb went out after two years is that a good amount of time for the bulb to last. also I want to know about the fan. Does the fan only come on when the tv...
2 years is normal, I`ve seen some fail in 12-15 months, fans run when cabinet interior is hot, they are controlled by temp sensors located inside the set, video-tek
Jun 04, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
TV comes on fine but after about 10 min the picture freaks out.
color wheel needs replacement. You can get a new replacement at the following link.
http://servicemanuals.vstore.ca/
Apr 02, 2009 | RCA HD44LPW165 44" Rear Projection HDTV
Tv shuts itself off
Look for the computer processor inside the TV. It needs to be cleaned. A can of compressed air will work. The processor is overheating and causing the tv to shut off. Look for the small fan that is supposed to keep the processor cool then remove the dust.
Oct 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
HL-S5687 DLp tv
your keeping a part that is warming up and shuts down your shutdown that protects the tv from burning up... cooler... to find this you might need a hair dryer or a can of freeze mist.
I believe the left side is your high-voltage section.
you can also let it warm-up without the fan .. let it shut down and feel parts with set unplugged to see what is running hot.
Need info on fan for RCA HD50LPW42 TV
Thats a DLP and those fans are noisy. Most of those fans are special and I don't think I can recommend a dealer but you can Google Electronic Parts and pick one. They will need the Model Numbers as well as the Chassis number. There is no guarentee it will be any quiter for very long. You might check with some local TV shops and see if any of them have a good used one. DLP's go bad all the time and many times it's the light engine and the fans are realitively new.
Oct 14, 2008 | RCA HD50LPW42 50" Rear Projection HDTV
Powering off and on
reheat the board.....this could happen that the tv board will get heat after a few minutes then the loosen suspected part will totaly open.
Mar 15, 2007 | Proscan PS52650 52" Rear Projection...
RCA HD50LPW42 50" Rear Projection HDTV Logo
143 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
