Question about Motorola Talkabout T5700 AA (22 Channels) 2-Way Radio
One radio doesn't transmit voice
Radios are brand new and charged overnight.
One radio does everything it's supposed to, the other receives great, transmits "call signal" great but does not transmit voice at all.
I've checked all settings and they appear to be identical. Did I miss something?
  • Anonymous Dec 01, 2007
    One radio doesnt transmit, need help!
  • 27 Answers
I think there defective. I'd return them.
Posted on Nov 15, 2007
I have a pair of wrist watch freetalker walkie talkie. One works fine, calls the other and transmits perfectly well. The other however does not appear to join in. It receives the voice message from the...
Odd that it calls itself. I suspect a weak battery on the no transmit unit. Radios require a lot of power to transmit and little to receive. Even if the charger says charged, it is more often the battery than not. If you have the walkie hooked up to the transformer and try talking on it (not recommended) it still could be the battery. Other issues: liquid damage, dropped, etc.
Feb 22, 2015 | Radio Communications
Kenwood tk 3102 and autocom
moz-screenshot-1.jpgmoz-screenshot-2.jpgPlease use the link to get the manual:
http://inform3.kenwoodusa.com/Manuals/USA_LMR%5CTK-2100-3100_B62-0950-30.pdf
good luck......................
May 17, 2008 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Radio will not send
It is possible your Code for transmit is different than your Code for receive. Cobra makes so many models, you are not giving enough information. Also, Transmit takes a LOT of power, so even if everything is setup, if your batts are weak or old, the radio will receive, but not transmit. Also check your antenna, make sure it is tight and NEVER transmit without an antenna. Yes, all lights will work even with old batteries.
Nov 10, 2013 | Cobra Radio Communications
Got a connex 3300HP has a ranger board and chipset won't modulate recieves fine keys up relay clicks needle doesn't move no voice either cant find schematics
You may have a dead meter.
Modulation is audio's affect on swing wattage or pep. Notice that needle moving more with your voice.
Dead key or carrier wattage is without your voice enhancing the power only with mic keyed.
I can only assume that the chipset you are referring to is an ic chip audio or pll which must be working if you are receiving audio.
Check your mic cord................ transmit and modulation and even your receive volume can be affected by the cord/mic plug solder joints or broken wires here.
http://www.cbtricks.com/radios/galaxy/dx33hp2/graphics/dx_33hp2_sch.pdf this is a similar radio the General Lee, Connex 3300hp and Galaxy hp2 share boards i believe dont hold me to that thou.
Aug 20, 2011 | Connex 3300 240-Channels Base CB Radio
I can't get the radios to communicate with eachother, they have power and chirp when I press the talk button but nothing is being received.??? They look like the EM1000 model of Motorola radios. The FCC...
These are multi-channel FRS / GMRS radios. In order to receive transmitted signals from the other radio, they both must be set to the same Channel and the same Interference Eliminator Code. One without the other will keep audio from being heard on the receiving radio.
I suspect you need to refresh yourself with the radio's controls and settings. If you have lost the manual, you can get a copy free of charge from Motorola You'll need a free program called Adobe Reader to view it.
Once you have everything - look at the right hand side of page 1 for "Talking and Listening" followed by "Menu Options" to set the radios up correctly. Keep in mind that if VOX is selected, and there is sound near both radios, they both will transmit at the same time - since the radios receive OR transmit at any given time, no audio will be heard from either.
Please rate this reply if helpful & good luck!
Aug 18, 2010 | Motorola EM1000R Two Way Radio
Stops working when I try to transmit.
problem may be the button loose connection to the main board...we can fix these radios. cb shop temple, tx on yahoo search. The button is connected in so it controls both sections.
Aug 03, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
Won't transmit
First I would check the interference code on both radios to see if it is set the same. It is possible you have one set to zero and the other set to another number. This would cause the problem you describe. The interference eliminator is designed to block out transmissions from radios whose settings do not match it.
If all your settings are identical, and you have only 2 radios, it is not possible to tell which one has the problem. You either have one with no transmit or one with no receive. The only way to tell which you have is to get a 3rd radio involved, set to the same settings.
Sep 06, 2008 | Motorola FV200AA GMRS/FRS 2-Way Radio...
Motorola T5420 Transmit Problem
Here are some troubleshooting thoughts:
1. Is your battery indicator showing at least 2-3 bars? (Battery Note: Your rechargeable batteries may fail due to setting without use for a long period of time. They need replaced every 12-14 months usually. A good tip is to charge them once a month to keep the chemical in the battery active.)
2. Check to see your Qt noise filter is shut off. Refer to page 22 of the owners manual. It is possible you have some radios set to Y and others to N. To assure good communications you should set all of them to N.
3. With your radios set to interference code zero, place your radios one at a time in scan mode, while you transmit/talk on one individual radio. See if any of the radios receive. Do this with each radio individually to see if you are transmitting at all. NOTE: This test will determine if you have any ability to transmit. If you do not receive any sound on the 3 radios setting in scan mode, the individual radio you are testing will not transmit.
Aug 25, 2008 | Motorola Talkabout T5420 (14 Channels)...
Staying keyed up after button release
I have never seen this problem before, check if the VOX is activated, this could cause to transmit the radio, but the voice must be transmited. check if the Accesory connector is not dirty, clogged or damaged
Feb 08, 2007 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout T5700 AA (22 Channels) 2-Way Radio Logo
287 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
