I am trying to load the drivers, toolbox etc for s Canoscan Lide 30 flatbed scanner. I don't have the disk. Found drivers on Canon's web site and they loaded but I can't get them to function. Should I use different drivers? A different approach?
Did you restart your computer after you downloaded your drivers and software? Did you select the correct operating system? Make sure the USB cable is plugged into the computer and the scanner...Open the toolbox and click scan or save and check to see if the scanner makes any noise or lights up...If you are using Windows XP then make sure you have downloaded the "TWAIN" driver and the "WIA" driver (two seperate downloads)
hi i hav one lide 20 model scanner how can i install it if u provide me it's setup , it s very...
(More)
hi i hav one lide 20 model scanner how can i install it if u provide me it's setup , it s very helpfull for me
Error message on Canon scanner -there is a twain error, device might not be connected. I am using...
(More)
Error message on Canon scanner -there is a twain error, device might not be connected. I am using Windows 7 Home Premium recently upgraded from Vista Home Premium. What do I need to do to be able to use scanner LiDE30/N1240U? Thanks
