Question about Samsung Digimax S630 Digital Camera
Camera not working
My camera turns on briefly then it beep a few time and shuts off. the battery is fine. Also the lens is stuck out.
  • 2 more comments
  • grantgator Nov 13, 2007
    My green light comes on for a half secong then nothing. Also lens is stuck in extended position. I've tried fresh batteries alkaline and NiMH with no difference.
  • rob555 Nov 16, 2007
    Me too. Same exact problem, and this is the second camera. I already returned the first one fr the same reason. It is basicaly unusable.
  • Terri Bates
    Terri Bates Dec 15, 2007
    I got my camera today, setup the setup menus, and had started to check out the features when the low battery warning came up. So I replaced the batteries and tried to turn the camera on but now all I get is the green light comes on for 3 seconds, goes off and approx. 5 seconds later the light flashes on, then off and the camera beeps 3 times, and nothing after that. I went out and bought brand new batteries that were industrial strength and tried those with the same results.
  • Anonymous Dec 17, 2007
    s 630 & 730 my samsung has same problem good tv's pos. camera's
  • 75 Answers
Remove battery for a minute and insert it again.
There is a Battery Type setting in the Menu of your camera.
Do the following:
- Press Menu/ Ok button
- Go to Set Up 2
- Scroll down to Battery Type
Two options under Battery Type:
- Alkaline- if you are using non- rechargeable battery
- NiMH- if you are using rechargeable battery
Posted on Nov 30, 2007
Camera Stuck with lens out. Beeps
I dropped the camera on the table a couple of times, twisted the front of it. Suddenly the lens retracted into the camera, the beeping quit, and now I can take pictures again. The Samsung website is horrible.
Jun 03, 2009 | Samsung Digimax S630 Digital Camera
Polaroid i735 Camera won't turn on. Lens stuck.
I had the same problem, and fixed it by wiggling the lens a little, when turning it on.
After a few tries, it finally wiggled free, and the lens retracted.
Jul 05, 2008 | Polaroid I533P Digital Camera
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Sumsung digimax
get a butter knife or any thin object like that and use it to push out the lens and turning it on at the same time you will hear a clicking noise which is normal once completely out, use your hand with a gentle but firm presure move it form left to right
and then hopefully it should work after that
x
Jan 14, 2008 | Samsung Digimax S500 Digital Camera
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Dec 14, 2007 | Samsung Digimax S500 Digital Camera
Jammed camera
A temporary fix to power up is to press the menu and power button at the same time. When the lens is extended and it beeps, on my camera , the lens is *stuck* Give it a gentle tug , then try the power button again
Oct 19, 2007 | Samsung Digimax S800 Digital Camera
Samsung camera power-on problem and beeping
same problem! camera HAD been dropped....carefully pull up with a gentle twist on the 'tilted ' side.
thanks for the tip! camera works fine!!
Oct 05, 2007 | Samsung Digimax S630 Digital Camera
Camera beeps 3 times the shuts off
OMG! so i read all these suggestions and nothing worked or i was just confused..tried the tapping thing but didnt work..so i finally just kept twisting the lens and pushing it in and out..it doesnt really move but i was angry and hoping this was doing something..i turn my camera back on a IT WORKIN AGAIN:) im so happy becuz i was so pissed that i had to buy another camera but i suggest trying this method if the table tapping dont work..OH and my lens didnt look crooked at all so if urs look straight and stilling doing stupid beep thing ,,,try this!
Aug 24, 2007 | Samsung Digimax S500 Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
Lens is stuck so Camera does not turn on
The battery packs in these units dont have a very long "shelf life" meaning when you charge the battery you need to use it within a few days or it will loose charge. Have you tried a fresh charged battery? They are very power hungry devices and the more advanced they get the more power they need. How old is this unit? how many charges have you put on the pack? it may be time for a second pack. An emergency backup pack good power is key nowdays.
Apr 03, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Samsung Digimax S630 Digital Camera Logo
59 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
