I found the solution.
Take in accunt that I'm a total newbie on Linux boxes.
1 - Previous to any change, following RH deployment guide, I backed up the network config on a file called "network-config-10.1.1.5" with:
"system-config-network-cmd -e > /root/network-config-10.1.1.5"
2 - After the Server refuses to complete boot sequence, I rebooted the server and entered on interactive mode pressing "I" just after RHEL splash.
3 - Then I accept all options with "Y" but "Bring up interface bond0".
Then hit "C" to complete boot sequence.
4 - Login normally as root and revert the changes with:
"system-config-network-cmd -i -c -f /root/network-config-10.1.1.5"
DSX-1 interface. Pinouts for each of the RJ-48C jacks are RCV to the DSX-1 from the span on pins 1 and 2, .... DSX-1 Drop. RJ-48 C, terminal blocks. Power Supply Options ... HiGAINMINI SHELF. INPUT: WITH PS 100/120 VAC. 1.0A 50/60 Hz
You need to configure the modem for it to allow game hosting. Enable NAT/GAMING setting of your modem. You can do so by pulling its interface and configure the settings from there. The interface of the modem can be pulled up by typing the default gateway of the modem in the address bar of a browser.
You have downloaded the game that is not supported by your mobile. Thats why you are receiving this message . For example : Certain games can work in java interface , some works under different interface . Check before downloading whether that game is supported by your model. Don't download any game from free website . They can damage your phone .
There could be a number of reasons your interface is failing. Have you tried to restart the device? Unplug everything, let it sit for a few moments and then start it all up again. That should do the trick.
This happens when you have a dirty psp game loaded, perhaps it needs cleaning? It can also happen if somehow the system files have become corrupted, if this is the case you must reinstall the PSP software or try updating it by connecting to the internet with your psp and going to the update function.
firstly check your charger may it bring current, if it bring current then open your cellphone you will see charging port interface try to clean it, after these courple it and test it.
