Question about Dell E173FP 17" LCD Flat Panel Monitor
Dell LCD TV powers on and after a few minutes shuts off by itself
I have a 2306C dell lcd tv, it has been turning itself off several times while i was watching it. I was told that it was a transistor, that makes the unit think it is hot and shuts it off. I was also told that it was not in the power supply. If anyone knows which transistor is causing the tv to turn off, i could repair it myself. I need location number so that i can find the part that is bad and the part number. any help will be greatly appreciated.
Thank you,
Mr. Lorenzo
  • 138 Answers
Re: Dell LCD TV powers on and after a few minutes shuts...
Ok, this is the way how to examine where the problem is. You have to check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see something moving, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken. If you cannot see. I would say that there are some problems with the inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or dark spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Feb 07, 2008
0 characters
3 Points
Dell ST2210 suddenly will not power on. Tried different power cord, outlet, unplugging everything but the power cord and still nothing.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | Dell Computer Monitors
St2410b no display
When the following conditions, namely the need to replace the LCD inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
Aug 22, 2013 | Dell E173FP 17" LCD Flat Panel Monitor
I have a Dell E197fpb LCD Monitor With Display Shutdown Problem. I have replaced the capacitors wit no luck. When I turn on the monitor it stays on for several seconds and displays fine. Then it shuts...
You may have bad lamps assembly problem, I use a set of test lamp to verify what I am working on to find out if it is the lamp problem or the inverter/power supply problem.
How are the voltages when the backlights stop working?
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Sep 25, 2011 | Dell E197FP LCD Monitor
Dell model no 2606c flat screen tv worked fine, one day next time
check graphics card on machine with another monitor.. and plug this monitor in another pc.
Jul 18, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Dell LCD TV won't turn on
check the cable who comes from the cpu
May 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor image flashes off and on
Sounds like you've done all the trouble shooting. If you just need that extra nudge, I would agree... it sounds like you'll be needing to shop for a new monitor.
Jun 29, 2008 | Dell E153FP 15" LCD Monitor
Problem with dell lcd monitor
Frt. Power button control board shorted. Part# 715L1153-1A
Apr 29, 2008 | Dell E173FP 17" LCD Monitor
Black screen on LCD Monitor
There should be an problem with your power card or please change your monitor immedietely...
Jan 01, 2008 | AOC LM729 17" LCD Monitor
Black Screen on W1700 LCD TV
As i said early ther should be an problem with your power card or ram...please upgrade it...
Dec 31, 2007 | AOC LM729 17" LCD Monitor
Dell 151fp is slow to get going, fine otherwise
You dell e151fp lcd monitor may have a bad/weak capacitor on power section(primary and secondary). Just change the buldge capacitor and use the Dick Smith ESR Meter to check the capacitor esr value. If you not sure all the above, you may go to this site to get the list of bad component on dell e151fp lcd monitor. Please visit here
Sep 08, 2007 | Dell E151FP 15" Flat Panel LCD Monitor
Dell E173FP 17" LCD Flat Panel Monitor Logo
85 people viewed this question
Top Dell Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Are you a Dell Computer Monitor Expert? Answer questions, earn points and help others
