Question about Hannstar I-Inc TW-191D Monitor
No sound! My monitor had sound, now nothing I do gets me any audio. I see others have also complained of the same issue. Do I need a new cable?
Why would you want to use the audio from the monitor? it's terrible, just buy some speakers FFS.
Posted on Jul 06, 2009
Ok so the issue is that after i have ran a hdmi cable from reciever to monitor, and 2 hdmi inputs (dvd and video2) into the reciever where im running a ps3 into the video2 port and foxtel/satellite tuner...
Try this, although recivers have video pass through, it is not the best option for video to your monitor. Depending on what you have for input/output on your TV/monitor, and, if you can, you should run all your video components directly to TV via(best)HDMI(video and sound) or, component and digital optical(best) or RCA, Then run digital optical out from you TV out to receiver in. You can use your monitors menu to chosse what you view and only have the onr input to you reciever. ASll you have to do then is go through you recievers menu to get the audio. Less connections less hassle. In other words, you would run your sat tuner to tv inputsat or cable, then dvd to dvd, PS3 to video 1 etc., on TV/monitor, then the single audio output to reciever.
Dave
Jul 03, 2011 | Audio Players & Recorders
Sound no longer comes out of monitor. I believe nothing is muted. I replaced cable between monitor and desktop. Any suggestions.
You didn't provide a model for your Envision monitor, so I can provide specifics - but here's a few things to try: (1) Start an audio program on the computer (mp3, CD audio, movie, etc. (2) Disconnect the audio patch cable from the computer's speaker jack and plug in stereo headphones. Adjust the volume on the computer's audio control panel to set the volume. If you're not receiving any sound - make sure you're plugged into the speaker jack (this is often the green jack). If you now hear sound, continue to (3). If you are unable to hear any sounds - your problem is INSIDE the computer. More on this later. Continue to the next step. (3) Disconnect the headphones and try the audio patch cable between the computer and monitor again. Make sure you're using a stereo cable - it has 2 individual contact points on the plugs - mono cables have just two. Pay close attention to the jacks if more than one are offered on the monitor (some monitors have power output jacks, etc.). Select the "LINE IN" or "SPEAKER IN" jack on the monitor. Be sure the plugs are firmly seated into the jacks on both the monitor and computer. (4) Check the menu settings of the monitor to make sure that the speakers are enabled (or not disabled as the case may be).
if you were unable to hear audio in step (2) above, there is a problem with the audio circuit in the computer. Some things to check are: Is there a volume knob on the sound card that is turned to minimum? Are (all) the correct drivers installed for the sound card in control panel? Is the sound card enabled? Does the sound card have a problem indicated by an "x" or "!" on the icon in control panel? Many times, "uninstalling" the device in control panel and the "scanning for changes" to reinstall will solve the problem. Other times, it is an output device issue: Have you selected "Speakers" as the output (not HDMI or Digital Audio).
If still unable to get sound working, provide the Envision model number along with computer name & model or the sound card name and model. If the sound is built into the motherboard, provide the mother board name and model. With that info, it will be easier to get the info you need.
Hopefully, you got the sound working with the tips I provided above. Please rate my reply. Thanks.
May 23, 2011 | Envision Computers & Internet
How do i get sound?
You will need an audio cable, cable with mini stereo headphone plug at both ends.
One end will go into the PC Audio line out (Green jack), the other end will go into the monitor audio line input jack (green jack).
Set the volume level on the monitor about 1/2 way up first, the volume control panel on the PC about 1/2 up also (wave, cd, etc 1/2 way also).
Then play some sound and adjust each level as needed.
Dec 24, 2010 | ViewSonic VA1912wb Monitor
Hi , I own a viewsonic LCD monitor model va1912w. My system has Windows XP. There is no sound from the monitor even after connecting the sound cable from CPU to monitor's audio jack. I have already...
http://www.viewsonic.com/support/downloads/drivers/?prod_name=1912
Try the above link for Vista or XP drivers which may be used with Windows 7 in some cases.
The va1912wb came up when I searched under 1912.
This driver is available directly from the viewsonic.com site.
Uninstall the other driver if possible.
Aug 08, 2010 | ViewSonic VA1912w 19" LCD Monitor
How can I download free audio driver for microtek c593? Please help me, thanks.
Monitor does not need sound driver, just think of it as nothing more than powered PC speakers mounted inside monitor case. You need correct sound card driver in the PC to get sound.
Testing monitor speakers: use an MP3 player to feed to monitor audio line input (Green jack) using audio cable with mini stereo male phone jack at both ends (try Radio Shack) , set the volume on the monitor half way. If you get the sound OK, then the problem is in the PC setup.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 28, 2010 | Microtek C593 15" Flat Panel LCD Monitor
How do I get sound from my new Samsung monitor. Everything works fine.
Here is the user manual: http://www.retrevo.com/support/Samsung-215TW-Monitors-manual/id/278ag702/t/2/
Just get an audio cable with mini stereo phone plugs at both ends, attach one end to the PC audio line out jack (Green), the other end just goes to monitor audio line in jack (green).
Apr 01, 2010 | Samsung 215TW SyncMaster 21" LCD Monitor
My new monitor w/HDMI cable replaced my old one which had a serial cable and now my external speakers do not work ever since. Also, i have 1 onboard sound card and 1 external card. Could they be...
I doubt that there is a "conflict" between the new monitor and your audio-system.
Check that Windows has not "muted" the audio-output,
or that the slider is not set to "minimum" volume.
Check that the audio-connector from the speakers is connected to the GREEN socket on (one of) your audio-cards.
Try connecting the speakers to the headphone-output of an iPod,
to see if the speakers work (they might be quite quiet) at all.
Dec 02, 2009 | Intel Motherboard
Cannot get sound to work. Until recently we used
I am presuming your monitor has built in speakers you wanting to use. If so you need a male 3.5mm to male 3.5mm cable. Connect on end into to audio in of the monitor and the other to the green audio out socket ont he pc.
If im wrong in assuming that, leave a comment and i'll get back to you.
Nov 23, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
I have acer al1917w A monitor but no sound
There is no sound driver, they are speakers, they work off of the audio output jack on the back of your PC, on the motherboard. If you have the sound drivers installed for the motherboard, and no sound, then you have plugged the monitor audio cable into the wrong jack on the PC, or you have the settings wrong just as MIKE said above.
Jan 09, 2009 | Acer AL1917W LCD Monitor
No sound when on pc mode
Check if your PC can play audio on some other speakers or headphone. If yes, check your monitor audio cable connections. If no something's wrong with your PC audio drivers. Try re-installing them or could be a hardware issue with your PC. Get it checked.
Sep 29, 2007 | Samsung SyncMaster 940MW 19" LCD Monitor
Hannstar I-Inc TW-191D Monitor Logo
Top Hannstar Computers & Internet Experts
 Russ Hill
Russ Hill
memman
memman
Level 1 Expert
Are you a Hannstar Computer and Internet Expert? Answer questions, earn points and help others
