Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try. One problem might be that the hole the steam comes out of is clogged. To remedy this, take a Q-tip and insert it into the steam hole. Be sure to use a pair of pliers to insert the Q-tip just incase steam does come out. You do not want to get burned to the ensuing steam. If clearing the steam hole does not work try creating a solution of water and vinegar to flush through your steam mop. The vinegar should be able to break-down any substances preventing your mop from building steam.
Attached is a video showing you how to try each of these solutions:
https://www.youtube.com/watch?v=Vz8OvV30sHM
You can purchase direct your replacement shark steam mop pads from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=shark+steam+mop
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
SOURCE: Euro-pro shark steam cleanercs618hd
I am looking for an operator's manual for the Euro-Pro Schar SC-505 Handheld Steam Cleaner.
Any ideas?
SOURCE: Euro-Pro Shark hand held steam cleaner model #sc618hd
Your heater in the cleaner is either plugged or has quit working, make sure you are getting a good ground for the cleaner. you may want to check the ground pin on the cord and make sure it is not loose or broken.
SOURCE: shark steam mop has water, but there is no steam....
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may
not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
SOURCE: Shark steam mop is spilling water out and not steaming.
Empty tank and fill with bottled spring water...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
heatman101
SOURCE: Shark S3101 Steam Mop won't produce steam
You have to use distilled water in the steam mop. regular water clogs it up and causes it not to work.
