Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I have had error message 3802 come up many times. I re installed the cartage holder and now black in will not print. What do I do? The printed used to work fine
  • 4 Answers
Im getting this same error, i suggest turning to the kodak 5*00 troubleshooting for advise, they use the same print mechanism
it seems that 3802 is related to a blocked or dirty print head... try taking it out and wiping it softly with tissue (dont apply too much pressure, and stroke only along the lines, not across them)
this seemed to do the trick for me.
the 5 series kodaks used to respond well to a 92% ethanol solution being used to clean them, if you need to do that, just make sure its dried off before putting it back in the printer
Posted on Jul 02, 2009
  • Onyx N Jul 02, 2009
    if i wasnt clear btw, the "cartridge holder" you spoke of, is in fact the kodaks print heads.
    if the printer sits turned off or unused for a long period of time, they can become clogged, this would cause that error, and also those symptoms
    if your wary of cleaning them yourself, try turning the printer off and on, then using "clean printheads" in the maintainence section of the menu's. -i wasnt able to do this myself, as it kept wanting to set up the "new print head"
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
I have message "Cartridge Error". I have established that the colour cartridge seems to be faulty. It is old and only replaced once because I do not actually need colour, use mainly black printing onl
Hi and welcome to fixya
You can print black pages with the color cartage. HOW ? just when you select the size of the paper A4 then ther is an option of colored printing or black if you have ink in the color cartage then it can be done that you can print black pages with that cartage
thanks hope that will be helpful
Dec 08, 2012 | HP Officejet 5610 All-In-One InkJet...
Error 3802 comes up. Tried switching off and re-starting. Menu comes up ok but when I try & print or copy, error message re-appears! Help
Found the answer to the problem on the Kodak support site.
Changed the black print cartridge.
Thanks for your help anyway...........
Feb 04, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
The dont know how to switch the ink cartages
The large black ink cartridge is used for printing text and other general black printing. The small black cartridge is used when printing graphics and other fine details. Each cartridge feeds to a different part of the print head, which is used for different purposes.
May 27, 2009 | Canon PIXMA iP3600 Photo Printer
Check print cartridge error
Set the properties to print on HP paper. This usually solves the problems
Mar 09, 2009 | HP DeskJet 3745 Printer
My Canon i860 just can't print out black words, it's frustrating
pull the ink cartage back out to see if a clear film is not on the cartage??? Check the area by cleaning the ink cartage with rubbing alchole, and also the area that the ink cartage goes into. Use a cotton ball the clean these area with.
Jan 31, 2009 | Canon i860 InkJet Photo Printer
Try pushing it gently using some pressure. I had the same problem and it got solved using a little push.
Aug 27, 2008 | HP PSC 1210 All-In-One InkJet Printer
Kodak 5300 first said error 3802 now says print head missing or loose
I got the same Problem as listed above. This is the way how I was able to solve it:
  • Remove the color and black ink cartridges and the printhead. (the 5300 Printhead can be removed by pressing a button on top of the carriage and a slight pull --> for better instructions use this official Kodak PDF)
  • Try to clean the printhead and the carriage with a slighty wet cloth from ink. CAUTION!: better not touch the green electronic chip! Be carefull while cleaning.
  • Reinstall the printhead and the ink cartridges.
  • If the printer detects a 'new' printhead just do a calibration and your are done. If not try to print a test page.
Hope this solves the Problem. Best wishes
May 20, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Automatic Allignment Problem
Your balck ink printhead is clogged with buit up ink. Manually clean it with cotton buds and proper cleaning solution, right doen where cartridge sits and the contact area the ink part of cartrigde contacts. Try printing now. Did you reset ink levels too?
Aug 27, 2007 | Lexmark P6250 All-In-One InkJet Photo...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
1,171 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
