Question about Garmin nuvi 255W GPS Receiver
Charging a garmin nuvi 255w
Need to know how long to charge with usb or with ac charger? thanks
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    To enter the charge mode, slide and hold the power switch to the left until the unit goes to a black screen and says "Charging battery", then release it right away. The text will then go dark. if you tap the screen, the text will come back. When the screen says "Battery Charge Complete", that is when your Nuvi will be fully charged. - Jim SHARCNET-USA
    Brigadier General:
  • 4,090 Answers
From dead flat it takes about 9-10 hours
do not leave on charger for more than that otherwise you will overheat and burn it out.
After each use recharge for about 3-4 hours depending on whether the unit has been used for that lengthyof time
Posted on Jun 30, 2009
I have charged the Garmin Nuvi 255 for about 24 hrs and it still doesn't say "Battery Charge Complete". So I'd recommend to follow the procedure as written in Best Solution above!
Posted on Jul 09, 2009
Garmin 255w i replaced the battery, symptons of charging
Hello
There sill be a battery symbol in the forner of the screen which sill indicate advancing the charging signal [very like battery signal of a cellphone] in green color. You can see it on its manu page. To increase the accuracy of the battery guage, gully discharge the battery and then fully charge it. Do not unplug the Nuvi, until it is totally charged. Connect the vehicle power cable to the mini USB connector on your Nuvi and to a power outlet in your vehicle. The vehicle key may need to be turned ON/ACC for Nuvi to charge.
Connect an AC adapter [optional accessory] to the nuvi and a wall outlet.
Connect your Nuvi to a computer using a USB cable. The computer must be ON for the nuvi to charge. OK.
Jan 12, 2012 | Garmin nuvi 255W GPS Receiver
What do I use to hook my gps to the pc, to update it
You will need a USB cable to make this connection.
Any USB generic charger will work. I used on my Garmin the Motorola cellphone USB cable.
The procedure is like this:
Connect, start Garmin Nuvi and disconnect; then reinsert the USB plug when your Nuvi model number is displayed at the bottom of the screen. You can even charge your Garmin this way. To reduce the charging time follow these steps:
# change the display brightness to less than 25%
# turn off the Garmin device.
Mar 04, 2011 | Garmin nuvi 255W GPS Receiver
My garmin nuvi 255W does not charge in the car with the car charger. It freezes at the first screen and I can't get past that screen. I found my home charger and plugged it in and now the battery is...
You need a genuine Garmin car charger to both charge and see directions at the same time. If it is a non - Garmin lead you can't charge and use at the same time. the Garmin at the same time. Otherwise the unit just goes into sleep/pc mode. It took a long time to get to the bottom of this, so I thought I'd pass the information on...
Nov 13, 2010 | Garmin nuvi 255W GPS Receiver
My garmin ran out of charge and when it was plugged in to the car charger it says loading maps then stays on the garmin page and goes no further...
Disconnect the nuvi from the car charger and connect it to your computer's USB port with the supplied cable (or any USB cable you have that fits it), and leave connected overnight (8 + hours).
You should be able to get the GPS to start up as expected after charging via USB port. if this happens again, simply repeat.
Jul 15, 2010 | Garmin nuvi 255W GPS Receiver
I received a Garmin Nuvi 255w as a gift back in October 2009. I am a Realtor and use this almost every day. Yesterday I was driving around, and I did have the Garmin charging with the car charger. In the...
The unit should still operate and turn on even with a dead battery when connected to an external power source such as the DC car charger, AC wall charger or USB cable (connected to a PC).
Please try the reset procedure listed here:
http://www.sharc.net/discus/messages/6/313.html?1269314749
- Jim
Mar 26, 2010 | Garmin nuvi 255W GPS Receiver
Charging my nuvi 250 with a USB cable from my apple
When the GPS is hooked up to charge the battery it will say charging,try turning it on when hooked up and see if it is in fact charging,otherwise have you thought of purchasing a wall charger,I got mine on Ebay,very reasonable and works great,saves the hassle of hooking up to my comuter.Hope this helps with the problem.
Sep 29, 2009 | Garmin nuvi 255W GPS Receiver
How long does it take to charge a garmin 255W gps?
Are you charging through the computer or wall charge,I charge my Garmin 255w with a wall charger for about 3 hours and I have all the bars.There are different strengths of chargers but even so,overnight is excessive,try a different charger.
Aug 08, 2009 | Garmin nuvi 255W GPS Receiver
My new garmin 255w is not charging
I had the same problem. The plug wasn't sitting right in the charger hole.
Jun 25, 2009 | Garmin nuvi 255W GPS Receiver
How long do I need to charge it for initial use
6-7 hrs is the recommended charging time from flat via car charger.
Apr 28, 2009 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi 255W
No, it may take a little longer if you are charging through the USB port. I normally have mine plugged in while driving, it charges and is in use too. To use GPS with USB. First turn the GPS on (without USB plugged in). Press Battery symbol on screen for about 10 seconds, a test screen will come on. Plug in the USB (bottom of screen shows USB connected). Tap EXIT to return to maps. You can now use it while USB is charging Make sure you turn GPS off before removing the USB cable
Apr 08, 2009 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
3,194 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
