Question about HP LaserJet 4100 Printer
Error code 55.0 - HP LaserJet 4100 Printer
    Novelist:
  • 125 Answers
Hi dcarlson580:
Here is your problem.
55.xx PRINTER ERROR
alternates with
CYCLE POWER TO CONTINUE
An internal communications error occurred.
The page containing the error will automatically be reprinted.
1. Check the power at the printer location.
2. Replace the formatter and/or firmware DIMM.
4. Replace the engine controller board
Hope this helps
Posted on Jun 30, 2009
Error 55 on daikin ducyed system
No make, model, or year shown, but on many pre-OBDII models (before 1995), the code 55 (or five blinks, five blinks) meant NO trouble codes. It was a method to let you know your request was received, but it had nothing to report.
Feb 16, 2017 | Cars & Trucks
1995 dodge Dakota code 55? Code 12?
Code 12 means that the battery input to the PCM was disconnected within the last 50 key cycles (this is a normal condition).
Code 55 means that you have reached the end of the codes. This is also normal
So if you have a 12, 55 code readout, you basically have no error codes stored.
Here is a link that lists the code sand what they mean.
OBD 1 Codes DodgeForum com
Oct 22, 2015 | Dodge Cars & Trucks
My dryer turns off within few minutes of turning on. i get error code 55. what does that mean?
google: frigidaire dryer "put model here" error code 55. I couldn't find anything. So there's more to the error code than 55, or it is model perhaps year dependant.
Feb 25, 2015 | Frigidaire Dryers
Error code 55
Hi Ronnie Penley,
I understand that you are receiving an Error code 55. Typically the best way to try and clear this would be to reset the appliance for at least 3 minutes. You would do this by either unplugging the washer or cutting the power off at the circuit breaker. When you return the power, try and start another wash and if you are still receiving the error 55 code I would call the manufacturer for further help.
-Best Regards-
Jan 04, 2014 | Frigidaire Affinity ATF7000E Front Load...
94/95 jeep 4 lt. Seem to have error code 12 followed by 55. Manual we have doesn't show 12 as an error code - any clues, please?
12 indicates that the battery has been disconnected recently. 55 shows the end of the code sequence.
Therefore, whatever problem you are having, it isn't generating a code.
Apr 21, 2011 | Jeep Cherokee Cars & Trucks
Ihave an error code 55 what is that??
Did you get this code by cycling the key 3 times? Code 55 is just end of codes.
Feb 12, 2011 | 1995 Dodge Dakota
95 dodge intrep. wtith error 12 55
code 12= battery has been disconnected at some point of time, code 12 should be there then others but when you see code 55 then you know theres no more codes stored bec code 55=end of cycle so try to reset the codes by detatching your battery terminal for at least three minutes and reattch. Check and see if you are getting anymore codes
May 14, 2009 | 1995 Dodge Intrepid
Error code 55 on 2007 subaru outback
car threw a CEL at me with ER 55 and blinking cruse. the error code went away after a 5-6 restarts,dont worry it´s not a serious proplem.
Jan 01, 2009 | 2007 Subaru Impreza Outback Sport Wagon
Abs light on, cruise control and engine light 2007 subaru outback
55 EGR Temperature Sensor or Circuit
ABS light is nothing to do with code 55 separate fault circuits.
Under dash there are two wires with mini spades at the end, connect one of them to the single black multiplug in position 2. Thats RHS plug inlet when you hold plug with tab lock on top.
ABS sensor should then flash up error coded. Ignore code 11 thats a initial flash to let you nknow the difference between a fast and slow flash.
Let me know what code flashes up and I will tell you the symptom,
Dan
Jan 01, 2009 | 2002 Subaru Outback
2007 OUTBACK /ERROR CODE 55
Dec 21, 2008 | 2002 Subaru Outback
HP LaserJet 4100 Printer Logo
324 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
