Hi try with fuel starter can if start it's mean fuel not enough turn the fuel mixture screw half turn until get idel start located under throttle gate keep on try
check the plugs......there probably fowled.....then check for fire......if you got that, then make sure your fuel valve is in the ON position (I know it sounds stupid).....if it is then you may want to give the carburetor a little tap.....I had an 800, car pulled out in front of me... hit em..... got it to crank up but the float was hung in the carb
the battery will build up calcium and wont hold enough kick charge to start bike thou the battery will test ok in this instance,, this happens when a bike sits for a while without a start
