Question about Whirlpool RBS245PDS Electric Single Oven
Stove shuts off and posts F10 on readout
My aunt has a kenmore electric stove that kept shutting off and read F10 on the screen. the model # is 79096213404. she can't find (claims she never got it from Sears) a manual/instruction book for the stove. it took a long time to cook a pizza because the stove kept shutting off! please help--with no instruction book, i can't help her but to post this. thanks!
  • 15,935 Answers
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
How do get rid of F10 which is on the window of my Kenmore stove
The F10 error means that the high temperature sensor is reporting a runaway temperature and shut down to avoid a potential fire. Try unplugging the stove or tripping the circuit breaker to reset the code.
If the error recurs, unplug the stove (or turn off the circuit breaker) again. Look at the broiler and bake elements with a flashlight. If it has any damage (breaks, char, melting), you will need to replace the element. Check where the elements connect to the oven and replace them if there is any charring on the back wall.
If the elements are undamaged, you need to check the wiring to identify if the problem is at the elements, the high temperature sensor, wiring or the control board. You will need to access the wiring from the back of the stove. Disconnect the wires to the heating elements. Then disconnect the wiring connections at the high temperature sensor and the control board. Without a model number, I can't be completely sure of the resistance that should be seen at various points. Please post a comment with the model number of the stove and I'll try to confirm the expected and faulty resistance values. Most likely, the resistance should be under 50 ohms but above zero between the left and right contacts of the elements and the violet wires in the wiring harness at the control board. The high temperature sensor should probably have a resistance between 1,000 and 1,200 ohms. If the resistance is high, you'll need to replace the appropriate parts. (Note: if the wiring at the control board gives a reading similar to the resistance of the high temperature sensor, the control board is the likely suspect.)
I hope this helps. If your stove is under warranty, contact Sears/Kenmore to fix the issue. If you aren't comfortable testing the wiring, contact Kenmore for a service call.
Feb 04, 2015 | Kenmore Ovens
Digital display is reading F10 and beeping and the oven shuts off after burning Banana Bread I also had smoke coming out the back panel of the stove top
The F10 error code means that a button on the touchpad is stuck.The error code can be cleared by pushing the cancel/off button and if the F10 returns the clock needs to be replaced since on that model the touchpad is part of the clock.
GENE
Sep 23, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
My kenmore model 970(frigidaire) electric range displays F10 fault when i use the oven shutting down the oven and beeping. Help me please
Hi
Thanks for using FixYa. F10 error indicates that the Electronic Range control (ERC) has gone bad and should be replaced. However, before replacing it you can take the screws out and then blow some air with the help of hair dryer so that if there is any moisture it blows it off. If still the issue is not resolved then replaced the ERC. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Frigidaire Ovens
Kenmore model 790.9621 electric stove error code F10. The oven heats up on bake (set at 400 degrees) then goes into f10 mode; and seems to be heating up more. Answer for problem??
it is the bake relay sticking--on the eletronic oven control board.i tried to buy the relays but,no luck.must buy the eoc board-great engineering
Jan 02, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore stove oven does not shut off
Wow, this post is going to be extremely late. Actually, I was able to get a new control unit for my Kenmore gas range from Sears Parts Dirext for $156.06. That includes shipping and tax. The burners work without it. We just cannot use the oven until the new board comes in. It's very easy to replace. Remove the panel screws on the back (just the top) and you have access to unplug the unit and remove the 4 screws holding the assembly in.
Jun 05, 2009 | Kenmore Ovens
Large burner won't shut off
This stove uses a special switch that turns one way for the large burner and the other way for the smaller burner. I was not aware that this had a seperate simmer burner on it, however. I think you using the wrong term there.
This is not computer controlled--the only computer on it should be the oven switch. I would assume that you need to replace the switch for the dual-size burner. If you take your model number in to Sears, or log onto Sears dot com, you should be able to get to the PARTS DIRECT web site on the computer, and if they ever sold that model you should be able to pull up a parts breakdown with expanded drawing and part numbers and prices. You should be able to buy the part from them. The part should be virtually the same as ANY recent model Frigidaire or Kenmore stove with the same style burner. This should be a very easy repair for you to make yourself, assuming that you know a little about working with electricity--remember, this stove USES 220 VOLTS!
Check out all of the wiring coming into the switch and going from the switch to the burner to be sure that there is not a short!
If you have one of the older smooth surface stoves, where the burners are part of the ceramic top, all bets are off, but anything you bought new in the last half-dozen years, should have a separate burner underneath a glass top, and the repair should be simple. Even with the older stove, it is still likely the switch, and should be no problem.
Feb 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Beeping F 10
Hello
Welcome to fixya.com
You r answer to the F10 code is:
The F10 error code indicates a runaway oven temperature. This would indicate that the oven temperature sensor or the electronic control has failed. According to the service manual you need to unplug the range & after restoring power the oven continues to overheat you will need to replace the electronic oven control.
This a job for a hands on tech!
Thank you for trusting us with your questions.
Please remember to leave a solved rating before you sign out!
Thank You
Dec 25, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool RBS245PDS Electric Single Oven Logo
228 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
