Question about GE WDSR2080D Top Load Washer
Another flood. GE washer
Ok I had a flood a few weeks ago, posted it here, and the solution was because i had the washer on its side the water level tube was filled and caused it too overflow, Now it has done it again.
1. Moved washer again, had to tile my floor. Was upright for the most part.
2. when I tried to move it back in, I tipped it about 30 degrees and noticed water was coming out of the drain hose at the washer.
3. Did a load, everything fine.
4. Did a big load of towels, then ,my floor was flooded. I did notice 3 things, the washer started spinning as water was still going into the drum, didn't know if this was normal? No water coming from drain hose, I checked this a few times, when load was complete I noticed when I move the drum, it seems like there is water in there? It this normal?
Please help, I am ready to buy a new washer, even though this one is only 3 years old. I am getting very frustrated. Thanks
  • 4 more comments
  • annie8866 Nov 09, 2007
    I did another 2 loads last night, everything was fine. I went in to check on the loads, every 5 mins.
  • annie8866 Nov 12, 2007
    What are you saying, I can closely watch it for months and then all of a sudden one day it will happen again?
  • annie8866 Nov 13, 2007
    I've done at least another 5 loads since, and everything is fine. Conincendently, it happened right after I moved the washer. The 1st time I moved it it was on it's side, 2nd time just tipped it slightly to carry it out of the room.
  • itabb Nov 28, 2007
    Similar problem with a GE washer top load, not sure of the exact model. I replaced the load level switch and the tube to the square thing on the outer tub. There is always soapy water in the square thing on the tub. Is there a way to pry it open and clean it out. I recall seeing a service guy do that once before years ago to a machine, but I just can't be sure and I don't want to damage it because it doesn't seem to want to come off. Do I just need to pry harder with a screw driver?
    Just a note: my washing machine model number is: WHDSR209D5WW
  • Anonymous Apr 23, 2009
    same problem
  • 248 Answers
The water sound is normal. There is a solution in the top of inner tub for balance. Is it overflowing...as in not stopping the fill cycle? If so check to make sure small hose is still attached to outer tu at bottom left front. This dome that it connects to can become filled with scum and causes the unit to not know that it's full. This causes flooding. You can try removing hose and cleaning out with thin wire. Sometime only fix is to replace outer tub. Again, this is only if overflowing!!
Another possibility is a bad break allowing outer tub to spin in agitation. This throws water up over sides of tub. Monitor unit when agitating to see if outer tub picks up speed and starts to spin. It is normal for it to index.
Posted on Nov 09, 2007
  • Gerald Griffin
    Gerald Griffin Nov 10, 2007
    Keep an eye on it. Famous for this problem.
  • Gerald Griffin
    Gerald Griffin Nov 12, 2007
    It should happen within a few loads. Something happened that caused this.
How do I increase water level?
The water level is controlled by the water level switch. If set to the highest fill level----thats all you get. The government has interfered with manufacturers to try and conserve water so very few of the new machines fill as high as they use to. There use to be a factory set screw on the water level switch for factory adjustments only but if you play with it wrong, you may end up flooding the basement with an over fill problem.
Apr 11, 2016 | GE GTWN4250DWS 3.9 cu. ft. capacity top...
I Have gsd422ox6BB Dish washer that all it does is flash the reset light.
Flashing reset light could mean the flood switch is turned on. There could be water in the motor compartment of the dishwasher. To get this water out, you will need to take the dishwasher out from the kitchen bench and turn it side to side a few times so that water comes out on the floor. Make sure the power mains connection is taken out.
If this does not help then the flood switch itself might be faulty.
Check parts on this site.
http://www.appliancepartspros.com/body-parts-for-ge-gsd4220x72bb.html
Feb 16, 2014 | GE Dishwasher Power Board - WD21X771
WATER COMING OUT FLOOD TUBE ON GE TOP LOAD WASHER MODEL WLRE4500GOWW WHATS WRONG DOES IT ON AGITATE AT HIGHEST WATER LEVEL
Take off the front panel by inserting a putty knife in the clips between the top cover and the front panel. Once the front panel is off you will see a clear box on the side of the tub with a clear tube running from it. Take off the tube and make sure the tube and where it attaches are not clogged with junk. Use a bobby pin or paper clip to clear it out. This is what makes sure the tub fills to the proper level. It is probably over-filling because that tube is clogged. Once the water level is lower, the water won't come down the flood tube.
Jun 13, 2012 | GE Washing Machines
I HAVE A BOSCH DISH WASHER SGS43A32GB/01 WHICH APEARS TO FLOOD NEAR THE END OF CYCLE
check base for leaks or holes. This is a very thin sheet of stainless steel that gets easily punched if some heave shart or pointed cutlery is falling onto it. also check proper operation of float switch underneath it.
Feb 01, 2012 | Dishwashers
The ohms read 0 when I check the inlet valve on my washer...could this be why it overflows lately? The readings on the water level switch seem OK.
Hi just read your posting.Did you disconnect the wires to your water valve coil before you tested the ohms resistance?Make sure you unplug the power before you test the valve.A low reading on the coil will not make the machine flood.Please retest the coil and get back to me and I am sure I can help .Looking forward to your reply.
Sep 19, 2010 | GE Washing Machines
Overflow
Check water valve may not be shutting off .
Check water level switch , or hose going to it from tub must be air tight may have pin hole in it.
Water level switch is the one that says small , medium or large on some washers.
Jun 10, 2009 | GE WBSE2090A Top Load Washer
Water sometimes does not shut off. flooded twice. happens intermittently.
If when the machine is flooding if you turn off power to the machine and it continues to fill: replace water inlet valve. If flooding water stops filling when power is interupted: clean out the end of the water level switch tube where it connects to the outer wash tub.
Sep 17, 2008 | GE WHRE5260E Top Load Washer
Washing machine overflowing
fill valve may be hanging open and can be very intermitant may be switch but ck valve first start water entering machine shut washer off and notice if valve takes extra time to shut off if it does would suspect valve problem
Jul 02, 2008 | Washing Machines
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE WDSR2080D Top Load Washer Logo
1,234 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
