Question about Rockford Fosgate Punch 600a4 Car Audio Amplifier
I HAVE A PUNCH 600a4 IT WORKS AND BANG BUT IT GETS HOT IN 5 MIN
Make sure it is grounding right and dont use it on its peak power
Posted on Jul 01, 2009
    Problem Solver:
  • 5 Answers
The impedance levels are different between your amp and subs...I have the exact same amp and problem, if you figure out how to fix it let me know...
Posted on Aug 06, 2009
McQuay PTAC stops working after short time
Sounds like you need a new control board with thermistors. you probably have a relay that is getting hot and quitting.
Sep 19, 2014 | Heating & Cooling
My car laguna 2000 modeel stop after 5-10 min run.and start working after 10 to 15 min wait.
Behind your harmonic balancer there is a cranshaft position sensor. When its getting hot its loosing calibration. Have that checked out.
Nov 18, 2013 | 2000 Renault Laguna Estate
93 gmc , wipers work in the begining, but after about 5 mins, they stop.... wait about 5 min and they will start again for another 5 min.. any suggestions ,
Wiper motor might be wore out and becoming to hot. Next time feel near it and check if its hot. DON'T touch it, just reach close enough to check.
Jan 13, 2012 | GMC Vehicle Parts & Accessories
Do not know how to remove blade
Take knife cover off.unplug.get a tapered punch about 12" long rotate the blade where as the nut in the middle of the blade has a flat side horizontal.right is tight left is loose.counterclockwise to loosen.Put the punch on the left side of thre flat and hit the punch with a hammer sounds odd but it works well yes it will bang up the side of the nut but it will not hurt anything.If done right it will loosen nut easily.I work on slicers all the time this is the only method I use.It may take a couple of good wacks but it will come loose as you already noticed a socket or wrench will not stay on the nut .good luck.
Mar 15, 2011 | Hobart Slicer Manual 12"
Problem(s) Description(s): Initially intermittent output with good audio quality on all four speakers/channels,( five minutes of output then maybe two minutes of silence) then no output at all on all four...
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Jan 16, 2010 | Rockford Fosgate Punch 600a4 Car Audio...
Stihl bg 55 blower runs good for 5 min. then loses power
1) carburetor gaskets/diaphragms may need to be replaced
2) ignition coil may be breaking down when hot
3) check compression when cold, then after it stops, when hot
4) could have a vacuum/pressure leak
*I would investigate carb first
Nov 08, 2009 | Garden
Ryobi SS30 starts great, runs fine, quits
the engine is getting to hot & shutting down either not the right fuel mix or not enough oil in engine sometimes the mixture screws need to be adjusted
Jun 14, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Amp gets very hot in as little as 5-10 min.
Whats the omh load and how old is amp??? The old Rf amps always got hot that how they worked.... No ventilation????
Nov 05, 2008 | Rockford Fosgate Punch 700S Car Audio...
Rockford fosgate punch 700s gets very hot
Disconnect the speaker wires from speaker terminals on the amp and turn the amp on (turn the head unit on). Set the volume to zero on the head unit.
Does the amp get hot?
If it does, either the bias is set to high or the amp has other problems. If it does not, you may have the speakers wired to the wrong ohm load.
Nov 03, 2008 | Rockford Fosgate Punch 700S Car Audio...
Rockford Fosgate Punch 600a4 Car Audio Amplifier Logo
298 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
