Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
My Canon MP140 has a paper jam. How to open and remove paper?
This is my first use of the copy function. The manual has no troubleshooting guide, no diagram of innards or how to open. Paper feed also pulls paper in crooked, though i lined it all up with the paper guides.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 84 Answers
Click here. This will take you to the Canon support page for your MP140 printer. Click on the 'Support and Service' tab.
Where it says ask a question type in 'paper jam'.
Next click on the required link, which should give you detailed instructions or a link to help you with your paper jam.
If this helps, click YES below.
Posted on Jun 30, 2009
How do I fix a canon mp190 series with a papper jam, I have removed all the paper?
Restart your printer.if then even your canon printer is showing paper jam.
  1. Open the paper output cover. ...
  2. Make sure that the jammed paper is not under the FINE cartridge holder. ...
  3. Hold the jammed paper with your hands.
  4. Pull the paper slowly not to tear it, then pull the paper out.
Get any kind of canon printer troubleshooting call us :+1-866-641-8283
CANON PRINTER TROUBLESHOOTING
Apr 19, 2018 | Canon Office Equipment & Supplies
I REMOVE THE JAMMED COPY. PRINTER STARTS AGAIN AND JAMS UP AGAIN ON THE VERY NEXT COPY. COPY SEEMS TO BE MADE BUT CAN'T GET OUT OF THE EXIT
Jam may not be completely cleared or paper is not suitable for your printer.
You can find your User Guide, an Educational Guide on the paper which is compatible with your printer and updated Drivers here:
http://my.okidata.com/PP-B4350.nsf?opendatabase
In the Troubleshooting section of the User Guide (page 74 of the English version) there is a section on dealing with Paper Jams. Make sure you have cleared all areas and that your paper is compatible.
Trust this is helpful. Please vote.
Dec 25, 2010 | OKI B4350 Laser Printer
The paper wont come out
Possible that the roller is jammed , the mechanism is jammed.If the printer is responding then remove off the jammed paper as it will reset automatically.
If not there can be failure of the mechanism( being struck) or possible motor drive failure.
Remove motor and manually turn to see if the mechanism turns over. Once confirmed set backmotor to test.
Sep 17, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
After a paper jam, my canon mp140 does not print at all. It says to clear paper jam, but i have remove paper. Is there a solution?
Is is possible that bits of paper is lodged into the roller or into the sensor area that is showing it as a detect.
The rollers may be jammed and so it will be good to release the motor drive with a manual twist.
So disconnect printer, then open panel and remove motor to turn the rollers.
Once it is free , reset to test
Sep 13, 2010 | Canon PIXMA MP150 All-In-One InkJet...
3 yellow flashes, then 1 green on a Canon PIXMA Ip4000
3 flashes is a GREAT symptom report. We need some more than that, but it does give us a direction.
If this is a "Service Call Error", it will be accompanied by an on screen message that includes a "6000" error code.
Here are the possible solutions....
- Timing sensor unit (QM2-1213)
- Timing **** disk film (QC1-4833)
- Feed roller ***'y (QL2-0598)
- Platen unit (QM2-1215)
- Logic board ***'y (QM2-1548)*1
- PAPER FEED MOTOR (QK1-0550)
These solutions are not for the novice, but are user servicible for many out there.
If this is a "Operator Call Error", it will also be accompanied by on screen error codes
Paper jam. [1300]
Paper jam in the under guide. [1304]
Paper jam in the rear guide. [1303]
Solution: Remove the jammed paper, and press the Resume/Cancel
button.
OR
Front door closed. [1250] Open the paper output tray.
Get a free copy of the service manual by contacting me at www.Equipmentcity.net
Sep 29, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
I have a new cannon pixma mp140, paper feed problem
it is problem paper prasser guide adjust or paper feed sensor is missing check it and service it
Jul 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My canon mp140 keep on flashing E and then 2 whats the problem
e2 is no paper, E3 is paper jam, E4 is no ink, E5, wrong ink, E8 waste ink absorber full
Jun 24, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Clear paper jam light flashing
Please follow the instructions given :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Mar 20, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Canon MP140 paper jam error with no paper jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Oct 04, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
1,881 people viewed this question
old marine
old marine
