Question about NetGear RangeMax 240 WPNT121 (WPNT121NA) 802.11g/b Wireless Adapter
Problems with netgear software or possibly worse
Hi, for about 3 months, i was able to use the netgear connection utility with no problem (netgear rangemax 240 WPNT511 PC Card). now, the only way, i could have an internet connection is using the windows software. the first time this started was i think it dropped my connection and i wasn't able to connect using the netgear software ever since. the main problem is, could this be a possible reason why my legacy 802.11g adapter and the netgear Airgo MIMO won't work together? Is my router a problem (netgear software says, connected with router but problem with router BUT then again, when i connect to windows, there's no connection problem. only when my 2 cards are accessing the router together where there seems to be a conflict-i.e. no internet connection)? or the netgear adapter because of conflict of whatever. Pls. help me. I need to know if I'll buy another netgear so there wouldn't be a conflict and what's wrong with my netgear utility software?
  • 854 Answers
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
Windows 2000/ME/Win98SE:
Note: Windows 2000 may require you to be logged on with administrator rights.
2. Insert the NETGEAR adapter resource CD into your CD-ROM drive. The setup page will then load.
3. Afterwards, click on the Install Driver & Utility link.
4. Make sure to follow the Install Shield Wizard steps, and click Finish when done to restart your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
2. Insert the NETGEAR adapter into the available expansion slot.
4. On the Found New Hardware Wizard, click on Next, then follow the prompt to proceed.
5. After the installation completes, click Finish to close the wizard. Please make sure that you can see the NETGEAR icon located at the lower right portion of your computer screen.
Note: If Windows displays Digital Signature Not Found warning, click Yes to continue.
C. Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Getting an intermittent wireless connection can be attributed to the following factors:
a. 2.4 GHz wireless interference
b. Wireless settings of your router
c. Location of the devices
d. Obstacles
You may also refer to the common causes of interference:
Window in brick wall 2dB
Metal frame, glass wall into building 6dB
Office wall 6dB
Metal door in office wall 6dB
Cinder wall 4dB
Metal door in brick wall 12.4dB
Brick wall next to metal door 3dB
In order for us to isolate the problem, please refer to the steps below:
1. Avoid obstacles.
a. Try to move the router to different locations in order to get better connectivity. We suggest placing the router on high location to avoid obstacles that may be blocking the signal.
2. Reduce wireless interference in the area.
a. Try to move the router away from devices that are operating on 2.4 GHz frequency like your cordless phones and microwave ovens.
b. Try to move the router away from windows. Windows let in interference from the outside world.
3. Adjust the wireless settings on the router.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. For security reasons, the router has its own username and password. When prompted, enter admin for the Username and password for the Password, both in lower case letters.
Note: If it doesn't take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you can't remember the password, you need to reset the router and run the Setup CD to reconfigure it.
d. Click on Wireless Settings under Setup tab.
e. Change the Network name or SSID to your preference.
f. Change the Mode to g and b only.
g. Change the Channel to 11, 1, 6 or 9.
h. Click on the Apply button.
i. Reconnect your computer to the wireless network and see if it fixes the problem.
Note: If the problem persists, you may need to upgrade the firmware of the router.
4. Upgrade the firmware.
a. Please verify the router version and model either underneath or at its side panel.
b. Go to http://kbserver.NETGEAR.com/downloads_support.asp and please select the model of the router.
c. Click the appropriate version of the router.
d. Select the link of the latest firmware. Click the button Right-click and Save to Download. Save the file to the Desktop.
Note: Please perform firmware upgrade with wired or Ethernet connection only. If your computer has wireless connection, then please disable it first.
e. Before upgrading, please write down all current settings since you need to enter them manually.
f. Using the computer hardwired on the router, please access the router’s setup page again by going to http://192.168.1.1 or http://www.routerlogin.com/basicsetting.htm
g. Click on Maintenance and then Router Upgrade.
h. Click on Browse and locate the upgraded file in your Desktop. Then click on Upload.
i. Please wait for the router to reboot.
5. After a successful firmware upgrade, you need to reset the router.
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
Note: Resetting the router will erase all the settings so it needs to be reconfigured afterwards.
The router can be reconfigured using the setup CD or by manual configuration.
Posted on Aug 16, 2009
    Scholar:
  • 124 Answers
  • check this thing that both of your computers are st on DHCP mode...
  • because if any one of your computers is seton static ip then there will be IP confliction..
  • But as u asked, there in no issue with 802.11g and MIMO technology...
  • check ur computers and then revert back to me..
Posted on Jul 13, 2009
    Sniper:
  • 127 Answers
I use to work for netgear and i can say that this is a general problem with netgear utility. if your wireless is working only with windows utility then that doesn`t mean that your adapter is faulty.that means there is bug in the netgear utility which will be fixed by netgear in the next release.see pal.if you want to check.you can disable wireless zero configuration by going to start - run - typing services.msc then try to connect with netgear utility.if it doesn`t work try disabling firewall and antivirus. you can`t upgrade the netgear software because they do not have upgraded software because it`s new so you have to wait for the new software to be out.
Posted on Jun 10, 2009
  • Faisal Ahmed
    Faisal Ahmed Jun 10, 2009
    I use to work for NETGEAR.you don`t need to buy a new netgear device.it`s a general problem with some netgear utilities please keep on using windows utility.if you have to connect everytime after you restart your comp then goto start - run type msconfig and press enter then goto startup and uncheck your netgear adapter.press apply and OK or close.there is a bug in the utility which will be fixed with the next software release.and as far as your internet problem is concerned you need to upgrade your router`s firmware.
I have an apple router. Periodically, I cannot connect to Internet. I must unplug router and modem and replug. Things can be fine for days, then it happens again. My cable provider has checked all lines. I...
It's a common problem with wireless routers, especially with certain ISP's, there's several theories about why this happens including cheap parts and software on the routers but it can be much worse if it's over a cable connection. Possibly because the MTU is higher on cable networks than wireless ones. This issue doesn't seem to affect wired connections to the routers as much. ie you may still get a working wired connection even if the wireless isn't working.
Certain makes are known to behave this way, with certain ISP's. eg in england there's a cable company called virgin media, belkin routers really don't seem to like them, but netgear seem to work much better, which is probably why virgin recommend netgear and will only supply netgear routers themselves.
Try changing the channel id if it's wireless, as there may be a lot of interference around you and this may or may not have a bearing on this issue. If that doesn't help then ask your isp what make they recommend as they should have an idea of what will work best, at least the tech support dept should.
In my opinion the best makes of routers are netgear and linksys. I also like belkin although they aren't as good as they used to be, and as mentioned can suffer from this problem quite badly in some cases. As you are with a cable
You will never completely eradicate this problem, all wireless routers will need resetting now and again, but it should be weeks or preferably months between each time. Cisco routers may be more reliable but they're business routers and are very expensive, and probably a bit more complicated to setup.
ps. I used to work for virgin media as tech support.
Jan 18, 2011 | Apple Computers & Internet
Hey. :) My name is Peyton. And me and my Dad have just bought a "NetGear N150 Wireless USB Adapter", And we've looked at the intructions, and we looked it up. But we can't seem to figure out how...
Installing the Software and Adapter
To install the wireless-N USB adapter with custom setup:
1. Insert the Resource CD. If the CD main page does not display, browse the files on the CD
and double-click Autorun.exe.
2. Click Install the Software.
Select one of the following methods to configure and manage your wireless network:
Smart Wizard. Allows you to manage your wireless networks with the NETGEAR
WNA1000 software and to connect securely using Push 'N' Connect.
Figure 1-1
Figure 1-2
NETGEAR Wireless-N 150 USB Adapter WNA1000 User Manual
1-5
v1.0, August 2009
- Configure network manually. Specify the settings for your wireless-N USB adapter
in the Settings screen.
- Configure automatically. Allow the Smart Wizard to automatically configure the
settings for your wireless-N USB adapter.
Windows Utility. Connect to and manage your wireless networks using only the
Windows configuration utility. For more information about Windows utilities, see the
Windows documentation or the NETGEAR application note at:
http://documentation.netgear.com/reference/enu/winzerocfg/index.htm.
See page 1-3 of the manual:
ftp://downloads.netgear.com/files/WNA1000_UM_05AUG2009.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 19, 2010 | Computers & Internet
Netgear won`t connect to ps3
He needs to go to a local best buy radio shack, office depot type store and get a cat-5 ethernet cable from his ps3 to his router, this will solve all his problems since wireless gaming always has drop spots that can get worse depending on the router type. Also if their are other computers make sure there not downloading or eating up bandwidth, this will not allow it to connet. Make sure the router settings allow the ps3 to connect, does the ps3 see the router but wont connect? you need the wep key.
Apr 26, 2009 | Psyclone PS3 Wireless Controller for...
Unable to Get Connectivity
Windows XP:
Windows XP:
Enabling Wireless Zero Configuration Utility
1. Please click on Start, Run and type in services.msc and click on OK.
2. Scroll down and look for Wireless Zero Configuration. Right click on it and click on Start.
3. Right click on Wireless Zero Configuration again and click on Properties.
4. Under the General tab, set the Start up Type to Automatic and Service Status to Started. Then, click on Apply and OK.
Mar 24, 2009 | NetGear RangeMax NEXT WN511B...
Can't connect to Desktop PC with Dameware using Netgear Router
Hi brianaugusti,
You need to open a port in the new router to allow remote connection. The port used by dameware is 6129, and the windows remote port is 3389
Please provide the model of your router so I can assist you with the next steps and how to open the ports.
Jan 09, 2009 | DameWare NT Utilities
Netgear wg111T Wireless Adapter 2.0 connectivity issues
Windows XP:
Windows XP:
Jan 02, 2009 | NetGear WG111U 108 Mbps Wireless USB 2.0...
Cannot connect to my laptop with a built in wireless.
Windows XP:
Windows XP:
Jul 13, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
Connection error appears
You should call the isp, because it is a problem on thier end. They will help you fix the issue, and worse case scenario, they will come to your house and fix the issue.
Apr 25, 2008 | NetGear WGR614 Wireless Router
Wireeless
Windows XP:
Windows XP:
Feb 12, 2008 | NetGear Wireless
Netgear has strong connection but it doesnt connect
I think you may that the "Drivers" & OR settings for this WiFi adapter are not working correctly. What ya need to do is Install the "Drivers" & "Software" from the Netgear CD that came with ya device and set it all up per your manual. Here are a couple of links to help below.. mobileoffice.about.com/od/findingusinghotspots/l/blwificonnectio.htm www.microsoft.com/windowsxp/using/networking/expert/bowman_02april08.mspx Basically, ya install the drivers & software reboot, insert ya USB WiFi into ya USB port, if it then asks for "Drives" point it to ya CD... when finished then you should be able to "See" ya Access point etc.. and connect.. setting any protocols you wish..
Aug 23, 2007 | NetGear MA111 802.11b Wireless Adapter
NetGear RangeMax  240 WPNT121 (WPNT121NA) 802.11g/b Wireless Adapter Logo
445 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
