Question about Philips VR330 VHS VCR
VCR Play Back is OK, but Recording produces Blue Screen on playback
Ok, what I'm trying to say is that my Philips VR 330 VCR will play tapes not recorded on this machine OK - However when I try to playback any tapes I've recently recorded on it, all I'm getting is a complete blue screen (Audio Muting?) - & no sound at all.
I've cleaned the heads by playing a good tape for an hour, using a Dry Type cleaner, and also with a Wet Type cleaner - None have made any difference.
Wondering if the record heads are F***** - if there are seperate rec heads to p/b on video machines!
Any help/ advise very welcome
Many thanks
  • hawkie May 11, 2008
    when i try to record vcr get blue screen ,playback with other tapes ok why r
  • 476 Answers
If the heads are TOO dirty, a head cleaner will not help. If you are cinfident enough to open up the recorder, then they can be cleaned manually.
Disconnect the VCR from the mains.
Remove the screews from the side and back (if applicable) of the lid.
Remove the lid.
Look at the large drum (set at a slight angle) If you gently rotate the drum you will see 2 or 4 small sensors set into the drum.
Tear of a clean piece of A4 paper about 1inch square.
Hold between thumb and first finger and rub the centre of the paper against each sensor in turn. Make sure the edge of the paper does not catch the sensor.
After each sensor check the paper for dirt (black marks) and change paper if need be.
Try a recording / playback.
Repeat if necessary.
Posted on Feb 22, 2008
DCR-TRV530 Digital 8 . . . Problem started with tape being caught in heads. Got a 3121 error message afterward . That stopped but in video playback mode only blue screen with play arrow at top? In...
If video head got clogged then camcorder wont read tape in playback so result comes as blue screen.
Please use video head cleaning tape and clean video head of camcorder. This will solve your problem.
Video-8 head cleaning tape is available with
Dec 03, 2010 | Sony Handycam DCR-TRV530 Digital Camcorder
Blue screen on lcd screen
The playback head is probably dirty and cannot show the picture - the screen is blue. Run a blank tape in the tape drive and execute a record all the way through the tape. Then play back a pre-recorded tape to verify it plays back ok.
Nov 11, 2010 | Sony DCR-HC30E MiniDV Camcorder
Panasonic VHS VCR Playback mode Tape Stuttering between LP and SP
This is most because the control head may be dirty, this haed picks up the pulses from the tape to regulate the speed & tracking if this is off it can produce both the faults you describe. Also it is possible the pinch roller (black roller on the right hand side of the deck mechanism, sits just in front of the control head), this may be worn especially as the machine is five years old, this will cause the tape to guided off alignment.
Jun 15, 2009 | Panasonic Televison & Video
Tape stuck in VCR
could be that you're looking at a blown cartridge for that vcr tape. You may need to cut the tape, to extract that from the unit.
The play head would usually retract when the cartridge is removed, BUT could be compromised by some tape getting into the play head mechanism, and jamming.
be particularly careful with anything pointy or sharp, as the tape head does NOT like those objects near the read surface.
Mar 02, 2008 | Philips CCC132AT 13 in. TV/VCR Combo
JVC GR-DVL120 Playback
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
Nov 20, 2007 | JVC GR-DVL120 Mini DV Camcorder
Philips dvd player 616k
have you tried to record in sp then playback on same machine if this works then your drum for recording in lp or if yours has ep mode may need replacing as pre recordings are ok you need to get it serviced. hope this goes well
May 25, 2007 | Philips DVP642 DVD Player
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
VCR won't tape and get no playback
First check how good / bad are your recordings. Take a current / recent recording done after this problem cropped up, and play it back on another VCR - maybe a friend's. If the recording plays back badly- showing the symptoms you described, then the problem is still dirty or worn out Video Heads. If the Recording plays back perfectly on the friend's machine, but plays back badly on your machine, I still suggest that you try cleaning the Heads one more time, and if the problem is not resolved, it is time to trash the VCR. One last question, you say that you have reset the channels. Are the reception channels' images clear? I may be able to give some more suggestions, based on this response.
Apr 17, 2007 | Goldstar GVR-E435 VHS VCR
Tapes wont play in palmcorder vcr mode
just clean the video head and you will get the image.
Oct 31, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Philips VR330 VHS VCR Logo
220 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
