Question about Black & Decker ICR200 Iron with Auto Shut-off
I can't seem to open up my ICR-250 B&D iron
I can't seem to open up my ICR-250 Black and Decker iron. I have removed the two screws form the bottom, but it seems to be held by a point opposite them on the bottom but there is no screw. Ideas?
    President:
  • 1,723 Answers
Sometimes you can gently pry it open if you can't see any more screws.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 02, 2009
How do i remove a black smear on my sole plate icr 500
clean it with a sharp edged blade slightly ,only when it is hot
Nov 13, 2014 | Black & Decker ICR200 Iron with Auto...
I need to know how to take apart a Black & Decker Press 'n GO
Maybe a direct inquiry to Black & Decker will yield some useful information.
Feb 20, 2014 | Irons
How to open the water tank in the black and decker iron ir1375sc
Regarding the Black & Decker Iron. You all talk about how to put water in the iron but none answer the question how to do that? What part do we remove or open to change or put in the water? Please answer this as soon as possible. This will also be on my Facebook to anyone there can you too help me?
Dec 24, 2012 | Irons
I HAVE A BLACK AND DECKER IRON-DIGITAL ADVANTAGE, POWER IN THE IRON GOES ON AND OFF NEED TO KEEP ON HOLDING THE POWER WIRE INTO THE IRON, SO I TRIED TO OPEN THE WIRE SECTION,BUT IT NEED A SPECIAL TOOL TO...
Bring the iron to a Hardware store, ask for a set of tools right for the type of screws (maybe Torx, Security Torx, tri-wing, bristol and others).
Once you can open the iron and access to the cord you may change the power cord. it is easy.
Power goes on & off because the power cord is broken. This failure is very common on irons.
Good luck
Apr 19, 2011 | Black & Decker Steam Xpress AS250 Iron...
Black & Decker Quick/Easy X415 won't stay on
Like most consumer whitegoods nowadays, the cover is 'protected' by 'tamper-proof' or security bits screws that take may forms: you can get the a set of screw driver security bits at most hardware or electronic shops.
The power cord to your iron has one or more electrical lead that has just about broken off due to fatigue failure: it is a dangerous situation because of potential arcing so I would get it fixed it as soon as possible by a 'qualified' person: that said, there are only three wires to your iron and once you get the back cover off, you can easily find out where ths break is by just pulling hard on each wires. The break would normally be fairly close so you have the option of shortening the lead (which must otherwise also be in good condition ) to where the longest break is and rewiring the leads back in exactly the same screw terminals on the iron.
Please remeber that you are dealing with a potentially dangerous main voltage appliance and extreme care is required.
Hope it helps.
Feb 21, 2010 | Black & Decker Quick N Easy X415 Iron
Cleaning an iron faceplate
first you get the iron hot,
then you use a damp towel,
and rub firmly
Oct 06, 2009 | Black & Decker Irons
Cord is loose inside, strange screws prevent opening iron to tighten cords - B&D will not help if not under warranty
if the screws have a design on top , like 2 half pyramids, then they are dealer screws, so that the consumer cannot open the appliance.....if they are like introverted star shape, then these are called torx screws, can be removed by ordinary torx-bit screw driver, available at most hardware stores....
Aug 06, 2009 | Black & Decker Steam Xpress S685 Iron
Describe your Black & Decker
Please call Black & Decker customer service at 800-231-9786 so that we may determine your warranty status. Mon - Fri. 8:30 to 6:00 EST.
Jul 07, 2009 | Black & Decker AS150 Iron
Does anyone know how to open a Black and Decker digital advantage iron? - I suspect a loose connection where the power cord attaches to the iron and have taken the two screws out of the back plate but the...
I think I have the solution now!
First of all, remove the temperature knob. Than remove the temperature indicator (it's like a little disc). Theres a hidden screw under the temperature indicator! Remove that screw and continue with your fixes.
I hope it could help you.
Jardel
p.s. - Sorry for my noob english...
Sep 21, 2008 | Black & Decker D2030 Iron
Black & Decker ICR200 Iron with Auto Shut-off Logo
496 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
