Question about Bosch Axxis WTA 3510 Electric Dryer
My dryer is taking up to five hours to dry a load of washing. I have just moved into this house and have been told it takes a long time because it's being energy efficient. That's nuts!
  • 441 Answers
Check on the back of the dryer, if it has no vent then it is a condensate dry and it takes forever to dry with those, if it has venting it just needs to be cleaned out from the dryer to the outside of the home
Posted on Jul 17, 2009
    Problem Solver:
  • 8 Answers
Check your vent for restrictions. It may be blocked or maybe just restricted.
Posted on Jun 30, 2009
How long does it take in a full cycle of wash to dry
Depends on several things. How big the drum is eg 6 kg or 7kg .the spin speed... The material ie. cotton drys faster than woollen items.is it a washer dryer or do you have a separate dryer.normal full load 6kg on a 1200 rpm spin of mixed fibres takes 1 hours 30 mins at 40 c then the dry time can take roughly 1 hour to 90 mins.
Dec 23, 2014 | Washing Machines
Dryer takes a long time to dry?
disconnect the vent pipe behind dryer,dry a load and if it after an hour clothes are dry then you may have a house venting blockage. also check all seals(door,drum,blower hosing).
Feb 14, 2011 | Estate TEDX640JQ Electric Dryer
My new whirlpool dryer model WED5300VW0 Ser MO3398130 does not dry properly. It takes 2 hours for a load of towels to dry and even light loads do not dry properly. I just had my vent under the house...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 31, 2010 | Whirlpool LER5636P Electric Dryer
Maytag MDE8600AYW takes way too long drying clthes
either your house vent is plugged, or the vent in the dryer by the blower is plugged. when the vent is plugged, even partially, the moisture is not leaving the dryer. It will take a long time to dry, and the top of the dryer will get hot when the vent is plugged. Clean the house vent and check down below the lint trap by the blower, then it will dry fine again.
Oct 09, 2009 | Maytag MDE8600AY Electric Dryer
Takes 3 hours to dry a small load, dryer is 3 1/2 yrs old
You need to clean vent hose and vent line in wall of house.
May 08, 2009 | Dryers
Dryer not drying clothes anymore!!
Get the power company to send a repairman out there. The power surge mess up the controls.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Whirlpool ET8CHEXSQ Dryer
Dryer taking too long to dry clothes
Hello :)
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Apr 03, 2009 | GE Profile DPSB620ECWW Electric Dryer
Dryer takes hours to dry ever since I converted to propane.
check for obstuction such as lint build up in the exhaust tube all the way out the house. Sounds like poor air flow
Mar 01, 2009 | LG DLG7188 Gas Dryer
Back & top of dryer get hot, clothes take long time to dry.
First thing to check for is blocked airflow. Check the dryer as well as the venting from the back of the dryer to the outside of the house good airflow is neccessary. You could remove the venting from the back of the dryer and run a load to see if that helps. Do not leave it off as it is exhausting lint and if a gas dryer spent fuel.
Jan 08, 2009 | Maytag MDE2600 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
349 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
