Garden Logo
A
Anonymous Posted on Aug 04, 2014
Where are fuses located on Cub Cadet Lawn mower?
Won't start or turn over
Dennis Aanderud
Level 2:
  • Expert 45 Answers
  • Posted on Aug 09, 2014
Dennis Aanderud
Expert
Level 2:
Answers
45
Questions
0
Helped
40766
Points
123
I have a Cub Riding Mower as shown Where are fuses located on Cub Cadet Lawn mower? - dc55747e-a406-427c-8262-8b6e701cca5e.jpg
Open up the cowling and the fuse is located to the right of the battery. It is a european style (flat) fuse as shown:
The yellow fuse shown below is the Where are fuses located on Cub Cadet Lawn mower? - af3b16f1-d5c5-44d4-a230-1656ac406d5b.jpguploads/images/af3b16f1-d5c5-44d4-a230-1656ac406d5b.jpg" alt="af3b16f1-d5c5-44d4-a230-1656ac406d5b.jpg" class="h_mi" />
I have had this Cub for years and have never replaced this fuse.
Depending upon how old the mower is you may want to:
1. Check the condition of the battery. I keep mine on a trikle charge over the winter. The battery may need replacing. Using a voltmeter to check battery voltage.
2. Check the battery cables to ensure that are secure and not corroded.
3. You may want to check the starter and ensure good conntion.
4. In general check all electrical wire connections.
Anything else I can help with please advise.
5 Related Answers
jmgldsmth
Jim Goldsmith
  • 2005 Answers
  • Posted on May 20, 2009
SOURCE: belt installation for a cub cadet lawn mower
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10051
Anonymous
  • 4 Answers
  • Posted on Jun 07, 2009
SOURCE: I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Anonymous
  • 10 Answers
  • Posted on Oct 18, 2009
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
Anonymous
  • 4 Answers
  • Posted on Jul 02, 2010
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Anonymous
  • 7 Answers
  • Posted on Nov 07, 2010
SOURCE: cub cadet lawn mower won't
What have you changed?? What model lawn mower is it? Is it a riding lawn mower or a push lawn mower? Does it turn over(engine turning with the starter), or does it do nothing when you turn the key over? I have serviced cub cadets for almost 20 years, from the very first model(1959) to present, and i own 13 different tractors myself. if anyone can help you, i should be able too. i just need more info about the unit and its problems. i look forward to helping you.... -Brian-
5answers
Cub cadet LTX 1045 Has no electrical power
Hi Charles.
this is all i can find on the net.
Start at the red (+) battery post and follow the battery cable to the starter solenoid. On the same top post of the solenoid where the battery is hooked there is another smaller red wire. Follow this small red wire and it will lead you directly to the fuse.
A Cub Cadet lawn mower won't turn over when it isn't getting power to the starter motor to spin the engine. This can be due to a bad battery; loose or corroded wiring; corroded terminals; bad ignition key switch; faulty safety switch; blown fuse; bad starter solenoid; or faulty starter motor.
7 Reasons Your Cub Cadet Lawn Mower Won't Turn Over or Crank You have finally found time in your busy schedule to mow your lawn. You're happy to be able to get it done and out of the way. However, this time your mower won't turn over. I have put together a list of items to check when you run into this problem.
Make sure you are following all safety precautions as shown in your owner's manual. If you are uncomfortable working on your Cub Cadet's starting system, contact your local Cub Cadet dealer or a knowledgable mechanic.
Dead or Bad Battery in Your Cub Cadet
A dead battery won't provide the power you need to turn over your Cub Cadet. Keep your battery charged, especially during storage, to extend your battery's life. Test your battery using the steps in the article "5 Things That Are Draining the Life of Your Lawn Mower Battery".
Charging a Battery: Use a battery charger to charge your 12-volt battery. Before you continue, wear protective gear to protect your eyes and skin from electrical shock. Follow these steps to charge your lawn mower battery with a charger:
  • Access the battery and terminals. You may need to use a screwdriver to uncover the battery. Do not remove the battery from the casing.
  • Connect the charging cables beginning with the positive cable first. This is the red cable or the one with the plus sign. Place the cable on the positive battery terminal.
  • Attach the negative cable to the negative battery terminal. This is the black cable or the one with the negative sign.
  • Do not touch anything that doesn't have a rubber coating to prevent electrocution.
  • Set the charger's voltage and amperage level to the desired level. The average volt level for lawn mower batteries is usually 12 volts. More amperage charges the battery faster. Start with two camps and work up to no more than 10 amps. A slow charge is best.
If the battery fails to hold a charge it must be replaced with a new battery. You can purchase a new battery at your location lawn mower dealership, hardware store or automotive store. Bring your old battery with you. Most places will charge you a core fee unless you provide them with your old battery.
Loose or Wires and Connections in Your Cub Cadet
Wires and connections can become loose with the constant vibration of your Cub Cadet. Make sure they are secure. While checking the connections and verifying the continuity is good, make sure the terminals are free of corrosion.
The outdoor elements can cause moisture around the connections causing corrosions. Try to remove this corrosion using a wire brush and a baking sold solution (2 cups water to 3 heaping tablespoons of baking soda). Replace the terminals if the corrosion is too severe.
Bad Fuse on Your Cub Cadet Lawn Mower
A fuse is installed to protect your Cub Cadet's electrical system. Check your mower to make sure you don't have a blown fuse. If you're unsure if the fuse is blown, you can check it by placing a multimeter probe on each prong of the fuse to measure resistance.
A resistance reading near 0 means your fuse is good. An infinity resistance reading indicates a bad fuse.
Replace a blown fuse with a fuse with the same amperage of the fuse you are replacing. If you continue to blow fuses, you should bring your Cub Cadet to your lawn mower dealership or lawn mower repair shop to troubleshoot the root cause.
Bad Ignition Switch on Your Cub Cadet Lawn Mower
The ignition key switch can be the culprit if you insert the key and turn it to find nothing happens. Your Cub Cadet will fail to turn over and start.
Check the switch using a multimeter to check continuity to determine if the ignition switch is the problem. To do this, look for the prongs mark B for Battery and S for Starter Solenoid.
Insert the key and turn it to the start position. With the multimeter set to measure resistance, touch one probe to the B prong and the other probe to the S prong.
A good ignition key switch will measure resistance near 0 ohms. A bad ignition key switch will measure infinite resistance and will need to be replaced.
Bad Safety Switch on Your Cub Cadet Lawn Mower
Your Cub Cadet has an operator presence control system installed to keep you safe. A safety switch can be defective and cause your Cub Cadet to fail to turn over.
Test your switch using a multimeter. You can also temporarily bypass the safety switch to identify a bad switch, but only do this for troubleshooting purposes.
Never operate a mower without the safety switch. Never run a mower when a safety switch is bypassed. A safety switch can save you from serious injury and you never know when you're going to need it.
Bad Starter Solenoid in Your Cub Cadet Lawn Mower
A starter solenoid is an electromagnetic switch that, when engaged, initiates the starter motor to turn over your Cub Cadet's engine.
The starter solenoid can go bad when the spring becomes weak or the copper plate begins to corrode. A weak starter, bad battery or bad ground can also cause the solenoid to fail.
Before you test your starter solenoid, you must have a fully charged battery. Continue testing the solenoid by using the steps to diagnose a bad starter solenoid in "How to Tell Your Lawn Mower Solenoid is Bad".
Bad Starter Motor on Your Cub Cadet Lawn Mower
Once you have ruled out the battery, cables, wiring, ground and starter solenoid as being the reason for your Cub Cadet won't turn over, it's time to look at the starter. The starter can be removed and tested.
I recommend having your local repair shop that specializes in starter and alternator repairs test your starter and rebuild it if possible before just throwing a pricey new starter at your Cub Cadet mower.
Still Having Problems with Your Cub Cadet Mower? If the above list did not resolve your problems, I put together a guide of common mower problems and solutions. You will find links to more in depth articles for each of these common issues. You can find the article at "Common Cub Cadet Lawn Mower Problems".
If none of this helps you out i dont know what you are going to do.
Keeps blowing fuse
There are several things that can cause the fuse to blow. PTO stands for Power Take Off and most likely this will not be the problem unless it blows the fuse when it is turned on. What you are saying is the fuse is blowing by just turning on the switch will be a short which can be anything from a pinched wire, shorted diode, short in the stator. bad voltage regulator.etc
My cub cadet zero turn won't run. Changed pluggs
Try cleaning the carburetor that might mean that it is not getting gas
Apr 17, 2013 • Garden
1helpful
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
4helpful
2answers
Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
3helpful
2answers
I need a wiring diagram for a 3165 Cub Cadet Lawn tractor. I need to know where the 2 green wires in the wiring harness go.
My name is Dane and I am going to try to help you solve your problem. Here is a link to where you can find your 3000 series manual. The wiring schematics start in chapter 13.
http://www.mymowerparts.com/pdf/Cub_Cadet/Cub_Cadet_Service_and_Repair_Manuals/
I hope I've helped. If you found this information useful, please leave me some THUMBS UP as deserved. Thank you! Dane
Top Cub Cadet Garden Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
