BEKO WMA642W - when washing the machine gets to the rinse cycle it then goes to pause and wont finish the cycle? i have tried different settings and turning if off for a re-set to no avail please help.
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Machine goes into extra rinse cycle
This may seem obvious, but have you set the rinse cycle indicator switch to one or two rinse cycles? If to only one, then try move switch back and forth between one and two a couple of times to ensure that you have good contact with ONE rinse cycle.
Sep 04, 2014 | Washing Machines
My washing machine was switched off mid cycle. Now the start/pause, ready, wash & spin/end buttons are lit up. I have switched it on and off from the mains. No change. It is a beko wm6123w. Please help
Try looking in the troubleshooting section of the products user guide/instruction manual, if you have lost this, you can normally download a copy from the manufacturers (beko) website, this is normally located in the support section of the websites.
have you tried pressing the start/stop button as the cycle maybe simply paused.
WM6123 Washing Machines Beko
Jul 04, 2014 | Washing Machines
Beko washing machine stuck on rinse cycle water I drum but wont move onto spin
all you need to fix your beko
pump fault
or spin problem
i hope this helps
Buy Paul Beer
Jan 11, 2014 | Beko Washing Machines
Hello, I have a beko WM5120W Washing Machine, and when I try to use the quick wash programme, it does the washing cycle ok, but when it starts the rinse programme, it pumps the water out ok, but when water...
hi
the water level switch or sensor does not activate to tell the programmer that there is plenty water so that it can start to rinse ( what you doing is simply overriding the system .
Dec 31, 2017 | Washing Machines
How do I use the Child Lock option on Samsung WF-B1456GW?
You can use the child lock feature in 2 ways.
1. To prevent operation of the washing machine when no wash cycle is running
To set this feature, switch the machine on using the POWER button at the top-left of the control-panel. Next, press and hold both the SPIN and RINSE buttons for about 3 seconds - until the child lock light indicator on the control panel illuminates. All functions of the washing machine will now be disabled apart from POWER ON/OFF until such time as the child lock is deactivated.
To deactivate the child lock, press and hold the SPIN and RINSE buttons again until the child lock light indicator on the control panel goes out.
2. To prevent any tiny fingers from tampering with the machine while a program is running.
After pressing the START/PAUSE button to start the wash cycle, press and hold the SPIN and RINSE buttons until the child lock light indicator illuminates. All buttons on the control panel will now be disabled until the child lock has been disabled. When the wash cycle has finished, you will need to switch the child lock off again to reactivate the buttons. Once you have finished using the washer, reactivate the child lock again before switching the power off as above.
The feature can also be used when using the delayed start feature, but needs to be set after pressing the START/PAUSE button.
Hope this helps. Please let me know if I can be of further assistance.
Regards,
BElectric
Feb 09, 2011 | Washing Machines
WASHING MACHINE DOOR WONT OPEN
Call the manufacture it will be under warranty if it's only 6 months old as the machine will have to be torn down to get to the defective switch, just the top will have to come off if your lucky.
Jun 17, 2009 | Haier Washing Machines
My washing machine is tripping the circuit breaker
sorry to hear about the problem it will be your motor or module try online for recon both these parts are prone to go on bekos
Jun 14, 2008 | Washing Machines
Rinse cycle
Is the unit new or used?, or does it wait and then go ahead and finish? This would be normal if it finishes on its own. Some units let things settle between cycles. If you have to nudge the control past a point then to make it finish then it is a problem which would require that the control be replaced. If it used to work different then it too would most likely be the control unit. There are numerous contacts and combinations that change from one setting to the next. Bottom line, does it get the clothes clean?? If it does the don't fix whats not broken...
Jan 26, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Washing Machines Logo
337 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
