Question about Sony Playstation 3 (PS3) Console
When the console is switched on the fanstarts up and indicator led turns from red to green but then turns to flashing red and the fan stops.
  • 38 Answers
What it is,is that u have fried ur system some how then is no way to fix it :(. but try this hold down the power button until u grt 2 beeps and see if a screen pops up follow what it says and if nothing happens then there is no way to fix it.
Posted on Jun 30, 2009
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
    May 04, 2012 | 1994 Nissan Maxima
    Nissan pulsar 1987 n13 the ECM light came one and the car cut out and won't start again and I need to know where the ECM is
    Hi, the computer is under the passenger's seat. Code extraction procedure is pasted below.
    READING CODES Modes will not switch while the engine is running. The ECM automatically switches to MODE I when the ignition is switchedOFF.
    1984-90 Vehicles With Dual LED System
    The self-diagnostic system has 5 modes. To switch modes, switch the ignition ON and use a screwdriver to turn the mode select switch through the access port on the ECM. The inspection lights will begin to flash. When the desired mode has been entered, turn the screwdriver fully counterclockwise. The red LED and green LED perform different functions in different modes.
    Mode I-
    This is the normal vehicle operating mode. The green LED will indicate loop status. If the green LED is not blinking when the engine is running, the vehicle is in open loop, or the HO 2 S, O 2 S, or sensor circuit has a malfunction. If the green LED is blinking, the vehicle is in closed loop. If a malfunction takes place, the red LED and the MIL will glow, indicating a malfunction has occurred.
    Mode II-
    Both the red LED and green LED are used to monitor mixture ratio feedback control. The green LED will function as described in MODE I. If vehicle is in open loop, the red LED and green LED will remain on or off. In order for results to be valid, vehicle must be in closed loop. In closed loop, the red LED remains off if the system is running rich, comes on if the system is running lean, and blinks at the same time with the green LED if system is within 5% of the exact air/fuel ratio.
    Mode III
    -When this mode is accessed, the codes stored in the ECM's memory will be flashed by the green LED and red LED on the side of the ECM. The red LED will light first. This is the first digit of the trouble code; the green LED will flash next, showing the second digit of the code. For example: 2 flashes of the red LED followed by 1 flash of the green LED corresponds to Code 21.
    Mode IV-
    This mode is used for checking the throttle plate (TP) switch, starter, and vehicle speed switch status. When the TP switch or starter switch is activated, the red LED will briefly flash as the status changes. For VSS status, the green LED will remain off when vehicle speed is less than 12 mph (19 km/h) and come on when vehicle speed is greater than 12 mph (19 km/h).
    Mode V-
    This mode represents a real-time diagnostic test of the crank angle sensor, ignition signal and the mass airflow signal. The malfunction code will be displayed only when the malfunction occurs and will not be stored in memory. The output code will appear as a single or short string of pulses. Count the number of pulses for the malfunction code.
    1 pulse-CMP sensor signal lost or noise in signal 2 pulses-MAF Sensor signal abnormal 3 pulses-Fuel pump circuit shorted or open 4 pulses-Ignition signal lost
    Apr 19, 2011 | 1987 Nissan Pulsar
    Tv desn't turn on,power light just flashes ten times and then stops and then again
    Error Indication Information
    Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
    (Note 3) (Note 4)
    POWER LED TEMP LED
    Note:
    1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
    2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
    change to another every 5 seconds in turn.
    3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
    or accumulated operation time of the Air Filter reaches 400 hours.
    4.LAMP OFF: The LED will flash right after the Lamp goes off.
    5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
    6.IC6001 is mounted on TV Main C.B.A.
    Clogged air filter
    more than 90%
    15)
    16)
    17)
    18)
    1)
    2)
    3)
    4)
    5)
    6)
    7)
    11)
    8)
    9)
    10)
    12)
    13)
    14)
    - flashes 5 times -
    every 5 seconds
    IC2301(pin82) detects the clogged air filter, then indicates the
    error when the air filter is clogged 90%.
    Front Fan stop or
    Lamp Fan stop
    flashes orange
    once every
    5 seconds
    IC2301(pin12) detects the Front FAN stop or Lamp
    FAN stop, then indicates the error when the Front FAN
    or Lamp FAN is stopped.
    Lamp Cover open
    Temperature Sensor
    short or open
    flashes orange
    twice every
    5 seconds
    flashes orange
    3 times every
    5 seconds
    flashes green for
    140 seconds.
    flashing red for
    60 seconds.
    light up red.
    flashes once
    every 5 seconds
    flashes once
    every 5 seconds
    flashes red for
    10 minutes
    flashes once
    every 5 seconds
    Abnormal
    Temperature
    flashes twice
    every 5 seconds
    flashes twice
    every 5 seconds
    Request for Lamp
    Replacement - - lights up
    Power Ballast Error
    (abnormal
    Lamp voltage)
    flashes 3 times
    every 5 seconds
    Power Ballast Error
    (abnormal
    temperature)
    flashes 4 times
    every 5 seconds
    Power Ballast Error
    (other causes) - -
    Request for Filter
    Cleaning -
    Abnormal Voltage
    on 16 V line of
    LCD Main C.B.A.
    flashes twice
    every 5 seconds
    flashes twice
    every 5 seconds
    Abnormal Voltage
    on 14 V line of
    LCD Main C.B.A.
    flashes 3 times
    every 5 seconds
    flashes 3 times
    every 5 seconds
    Abnormal Voltage
    on 7 V line of
    LCD Main C.B.A.
    flashes 4 times
    every 5 seconds
    flashes 4 times
    every 5 seconds
    IC2301(pin76) detects the Lamp Cover Unit condition
    (open or close), then indicates the error when the
    Lamp Cover Unit is open.
    IC6001(pin85) detects the Duct FAN stop, then
    indicates the error when the Duct FAN is stopped.
    IC2301(pin74 and 75) detects open or short of the Temperature
    Sensor (R2911) on Front Thermistor C.B.A., then indicates the
    error when Temperature Sensor is open or shorted.
    (The error is not detected for 1 minute after Lamp ON.)
    IC2301(pin74 and 75) detects the temperature attached near
    the Front FAN by the Temperature Sensor (R2911) on Front
    Thermistor C.B.A., then indicates the error when the
    temperature becomes more than 43 C (109 F).
    IC6001(pin86 and 87) detects open or short of the
    Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
    then indicates the error when Temperature Sensor is open or
    shorted.
    (The error is not detected for 4 minutes after Lamp ON.)
    the Lamp by the Temperature Sensor (R2901) on Lamp
    temperature becomes more than 60 C (140 F).
    IC2301(pin11) detects the error of LCD Power C.B.A.,
    then indicates the error when the temperature fuse
    (117 C)(243 F) in LCD Power C.B.A. is open.
    IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
    then indicates the error when an inner malfunction of LCD Power
    C.B.A. occurs, the Lamp voltage becomes more than 130V or
    less than 30V, Lamp current becomes more than 5A, or the Lamp
    is cracked.
    IC2301(pin11) detects the error of the Lamp, then indicates the
    error when the Lamp is short-circuit.
    IC2301(pin48) detects +16V line voltage on LCD Main
    C.B.A., then indicates the error when the voltage
    becomes less than +13V.
    IC2301(pin47) detects +14V line voltage on LCD Main
    becomes less than +11V.
    IC2301(pin45) detects +7V line voltage on LCD Main
    becomes less than +5.7V.
    IC2301(pin44) detects +3.3V line voltage on LCD Main
    becomes less than +2.5V.
    flashes 3 times
    every 5 seconds
    flashes 4 times
    every 5 seconds
    Abnormal Voltage
    on 3.3 V line of
    LCD Main C.B.A.
    - flashes 5 times
    every 5 seconds
    Forced cooling
    The failure of Lamp
    light up
    Temperature Sensor
    short or open
    Abnormal
    Temperature
    Duct Fan stop -
    When accumulated operation time of the the Lamp reaches
    5000 hours, OSD (replacing the Lamp) appears on the screen.
    Note: The Lamp time is stored in EEPROM (IC2305).
    When accumulated operation time of the Air Filter reaches 400
    hours, OSD (cleaning the Air Filter) appears on the screen.
    Note: The Filter time is stored in EEPROM (IC2305).
    During forced cooling, this indication is indicated.
    IC2301 (pin11) detects the failure of light up processing of
    the Lamp, then the POWER LED is changed as follows.
    1) POWER LED flashes green for 140 seconds (while turning on).
    2) POWER LED flashes red for 60 seconds (while cooling).
    3) POWER LED lights up red (standby).
    Note: If the Lamp will not light after attempting turning on the
    power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
    LCD Main C.B.A. may be defective.
    Error Symptom Problem Possible Solutio
    May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
    No sound or picture, 2004 pt50dl54j
    remove back panel. blow out all the dust from all the components except the fan on the right.
    Vacuum out all the dust.
    Have you replaced the lamp? that would help too.
    There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
    Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
    Furnace blows cold air, ignitor won't glow.
    ok this is going to sound funny but it seems as though the polarity is reversed going into your furnance. to correct this proiblem you first need to unplug the unit and where the cord goes into the furnance at that connection disconnect the two wires. Once theses are disconnected switch the wires .All you are doing is reversing the way the electricity flows into the circut board. I would wager that is the problem
    Apr 13, 2009 | Heating & Cooling
    Red flashing light on ps3
    When the light flashes red and you ALSO see the green light on too this indicates that the system is getting hot and you need to switch off and let it cool down.
    if you switch on get the beeps see yellow light briefly then flashing red only this indicates failure.
    The system has shut itself off to stop further damage ..... supposedly caused by getting hot .. maybe fan failed .... only thing that can be done is to contact Sony for repair or replacement.
    I know this post is old but thought the info could help others ...... I hope you returned your PS3.
    Sep 27, 2008 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    106 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
