Question about Asko D1716 Built-in Dishwasher
ASKO D1716 - blue tinge to stainless
The machine is about 4 years old; worked perfectly for awhile, now leaves a blue tinge (like tie die) on the stainless flatware and bowls in both upper and lower racks. We stopped using the Electrasol about 2 months ago but the problem has not subsided; remains the same. We do rinse before we wash. Thank you for your time and advice! -Deb
Use any stainless pots cleaner to gat the shine back.
Posted on Dec 11, 2007
What do we need to do when the asko dishwasher has just short circuited for the 1st time?
Depending on the age of the unit I'd say it's the heater element. Normally it happens after 4-6 years depending on usage. If your handy then to be 100% sure unplug the power to the heater (plastic clip on the side of a sausage looking tube) and turn the dishwasher back on and see if it trips the circuit then.
* Please note to unplug the unit from the wall before atempting to carry out any work on the machine. Easiest way on a Asko is to go from the back.. 4 screws from memory and you take the cover off.*
May 28, 2016 | Asko Dishwashers
Please describe where the float/float valve is on the D1716 machine
This is located in the bottom base of the machine. An isopor float, under a microswitch.
Sep 23, 2013 | Asko D1716 Built-in Dishwasher
My Asko D1716 dishwasher works fine apart from the soap dispenser. It won't open to release the soap.
Most likely it's a corroded door catch or a bad solenoid. Hopefully it's not the main control board. You'll need a repair manual or technician. A work around would be to use detergent tablets in the compartment
Mar 02, 2012 | Asko D1716 Built-in Dishwasher
Machine turns on but no water come into diswahser
Ensure there are no kinks in the water feed when you push it back into position and also ensure water is turned on.
May 10, 2009 | Asko D1716 Built-in Dishwasher
Asko d1716 door switch
Below is a link to get a PDF of your washer. Cannot say if the solution is easy to resolve, but with the manual you have numbers and sources to get more assistance. Hope this helps,
Sea Breeze
Jan 31, 2009 | Asko D1716 Built-in Dishwasher
Asko D1716 won't start
Ensure the water is turned on and the door is fully closed, make sure delay start is not set.....
if DW still won't start, I would begin by checking the door switch.
This link will download the owners manual for your unit. Click here
to download the manual.
Hope this helps.
Please take the time to rate this solution.
Viking (made by ASKO) Dishwasher Problem
You can find parts, solutions and manuals at link below. Hope this helps, Sea Breeze
Click below
Dec 18, 2008 | Asko D1716 Built-in Dishwasher
Asko Dishwasher 1473 - 262
The sound is the drain Pump I believe ,it turns on to make sure the unit is clear of problem so it can re cycle and start again.
Jun 12, 2008 | Asko D1716 Built-in Dishwasher
Asko D1716 dishwasher problem
I also have an Asko D1716 dishwasher. The water stopped flowing. I replaced the water inlet valve and I have another problem, but the replacement of the fill valve is now letting in water. You can call Asko at 1-800-898-1879 to order the parts. If you order from Asko, I'm told you have some warranty on the parts. Anyway, the screws take a star drive and there is a front plate and back plate you will need to remove. There are approx. 4 screws on the front and 4 screws on the back. Just remember to unplug it before starting any work. The fill valve is in front of the machine. There are 2 screws holding it in place from the front. You will need to remove it out the back though to replace it since the fill tube to the tub is short and it wont allow you to pull it out the front. The repair is really easy once you get started.
Hope this helps,
Jun 11, 2008 | Asko D1716 Built-in Dishwasher
Asko D1716 Built-in Dishwasher Logo
130 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
