Question about Kenmore Elite 45986 Front Load Washer
Washer won't drain and spin didn't fully drain my last load code dL then F shows
  • Anonymous Mar 19, 2014
    dl code washer does not drain
Very easy fix, My 11 year old fixed it last time.
There are coins or objects clogging the pump. It cost me $170 to get this fixed, it will cost you nothing and take less than 20 minutes.
You will need a STAR screwdriver or bit for cordless screwgun. If you need to purchase one, take a picture with you cell phone and show it to guy at hardware store. They cost about a $1 more than a regular screwdriver)
1. Take out star screws and remove bottom kick panel.
2. There is a round cylinder facing you with a scew on cap. (This is the pump.)
3. There is a wire essembly in front of pump, it snaps in. Just pull up on it and it will unsnap. (May have to use a little force, but it is made to pop out).
4. Remove the two screws for the pump.
5. Slide pump out (it is mounted on rubber gromlets and will just slide out).
6. Place mop bucket or pan under the pump.
7. Unscrew pump side cap and let water flow out. (Make sure pan is big enought to hold all water or get two).
8. After water has drained shake pump around, it is common to find change in pump. ( If you have baffels missing in the washer drum even small socks or underwear can get lodged into pump.)
9. Put pump back in and try running washer there may be more stuff in pipe hose and this will flush the rest out. (Some units have a little toggle switch that will not let unit run unless kick panel is installed, so you may have to reinstall it to try and see if it worked)
10. If it drains put cover back on, if not check the pump again to pull any new objects out.
Posted on Jul 01, 2009
Maytag Neptune washer machine won't spin or fully drain
    • 1 Open your home's breaker box and flip the circuit breaker switch to "On." If it is already set to "On," flip it to "Off" and then back to "On" to reset it. A power surge may have interrupted your wash cycle so the drain/spin cycle never actually started.
    • 2 Move the washer away from the wall and straighten the drain hose if it is twisted or turned in a way that makes it difficult for water to flow through it. Replace a kinked hose with a new hose.
    • Sponsored Links
    • 3 Push on the washer door to make sure it is fully closed. The washer will not drain or spin unless the door is closed tight. Press the "Start/Pause" button after you close the door.
    • 4 Wait for about 30 seconds after you press "Start/Pause." The washer will not operate until it has been able to fully lock the door and restart the drain process.
    • 5 Run the clothes through a complete cycle again, making sure you use cold water if there are a lot of suds in the washer. Too much soap in the washer can make it hard to drain. Use high-efficiency or low-sudsing detergents on subsequent uses.
Feb 15, 2013 | Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Why won't washer drain/spin or allow me to open the door?
Hello Micheal,
The problem is going to be bex=cause the water didn't drain. This tip i wrote explains how to make it drain http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Maytag neptune MAH5500BWW front loader didn't drain after a wash cycle. first time wife put it on spin for a few minutes and it drained, no problem. A week later that didn't work, code...
Yes you need a new control board. The fact that the motor and impeller was damaged and loosened. You should try taking your Washer in for maintenance check or call the repair man.
Jun 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
I've gotten the error code DL and then F, I tried sanding, unplugging but it still shows me the error. How can I fix it?
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Plug the washer back in and press [Power] to turn on the washer.
Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Press [Start/Pause] to begin a drain only cycle.
After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause].
This will remove excess soap suds and light residue from the drum.
Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Shane
Mar 15, 2011 | Kenmore Elite 45986 Front Load Washer
Wont spin or drain water, shows a DL symbol on the screen
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | Washing Machines
Washer is on but went i select to drain and spin
You may have something inside the pump, blocking the progress of the draining Their are screws under the bottom you remove to get the bottom plate off c1a7e9d.jpg330474c.jpg
Mar 05, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error code f and dl won't drain or spin
"Fdl" is a Door Lock error. This is usually an indication of a failed door latch mechanism. To access and/or replace the door latch, click on the following link:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
A replacement latch can be located at searspartsdirect.com. Just type in your model number in the "Search" window. You can locate it under the "Door and Latch Parts" heading as item number 7 (part #8181700). This is an easy repair job if you wish to accomplish on your own and avoid the added cost of labor.
If you do not wish to order the part online, use the part number provided and go to your nearest applaince parts retailer. I hope this helps you. Please post back if you need further assistance.
May 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F-DL problem
sounds like the control board
May 12, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
165 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
