Question about Nokia N95 Cellular Phone
I can not pair a particular bluetooth device to my n95 8 Gb phone, but i was able to pair nokia's model. is there any reason why other type bluetooth devices won work with n95 nokia 8 GB cell phone? How can I overcome that? The divice is car kit (universal type) and it is accepted (succesfully paired) by other phones. Regards, K
  • 31 Answers
Jus change th settings of ur bluetooth on ur device an on th other device an try to pair it.. so tat u may recover tis prob... kindly rate me.... thank you...
Posted on Jun 30, 2009
Where is sync?
Pairing a Nokia Lumia 520 to a 2013 Ford Escape
1. To Find "Bluetooth" on the Nokia Lumia 520
  • Slide your finger left on the display.
  • Press Settings.
  • Press Bluetooth.
2. Turn on Bluetooth
  • Press the indicator next to "Status" to turn on Bluetooth.
3. Pair a Bluetooth device with your phone
  • Make sure the vehicle (parked in a driveway) is turned on and engine running. Go tot he Phone Menu, System Settings, Add Bluetooth Device, Push OK, The Sync System will display a 6-digit PIN number. Use the Seek Arrows to change to Special PIN (the system will display 0000), Push OK.
  • Your phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
  • Press the required Bluetooth device (the tab should say Sync).
  • Follow the instructions on the display to pair the Bluetooth device with your phone. Enter the 4-digit PIN
  • The new device is displayed on the list of paired devices.
  • Press OK on the console screen to set as Primary Phone, set 911 Assist and Download Phonebook. Be sure to check your phone screen and check "Always Connect" and Yes to approve the phonebook download. Be sure to check to see is there is also a request to Always Connect for SMS (texting) alerts.
4. Return to the home screen
  • Press the Home key to return to the home screen.
Your phone should now be paired the Sync system. Use the Voice button on the steering wheel to start the process (say "Phone"). Use the Phone icon to answer (a quick push) or hang up (push and hold down for about five seconds).
For more info www.fordtechlane.com Ford Tech Lane Driving you on the fastlane of vehicle technology
Mar 05, 2014 | Nokia Lumia 520 Smartphone - Wireless LAN...
How do I pair a Samsung bluetooth headset model HM1000 to my Nokia C7-00 phone?
1.first on samsung bluetooth device
2.press& hold call answer button in bluetooth device now light is on ,not blinking
3.and then search your bluetooth device by your phone and pair.
Apr 11, 2012 | Samsung HM1000 Bluetooth Headset
Bluetooth in car not recognizing Droid 2 any more - worked fine but now does not
your limit would have crossed
there are a particular no of devices that could be paired
Pair your Verizon Motorola Droid 2 smartphone with a Bluetooth device using these steps:
1. From the Home screen tap Menu > Settings app.
2. Tap Wireless & networks.
3. Tap Bluetooth settings.
4. Ensure that Bluetooth is checked.
5. Turn the Bluetooth device on and set it to discoverable if required.
6. Tap Scan for devices.
7. The Droid 2 should locate any devices in the area. You may need to enter a password. Most devices have a password of 0000 (four zeros).
The Bluetooth indicator should now show in the notification area. This indicates you are paired successfully.
Feb 24, 2012 | Motorola Mobility Droid (2 GB) Cell Phone
Hi, i have bought a new Nokia bluetooth headset BH503, but it is not able to pair with my mobile phone Nokia E71, apparently my phone is not able to detect the bluetooth headset.It shows " No...
Hi ttc81,
Please make sure that your phone's bluetooth is in shown to all mode and not in hidden mode.
Also check if there are any particular instructions in your bluetooth headset's manual for pairing a device.
If the above procedure does not work , try to pair the bluetooth with another mobile phone and if it gets paired , then it means that your bluetooth is not compatible with Nokia E71.
Hope this helps ...:) Let me know in case you have any queries.
Jun 18, 2011 | Audio Players & Recorders
I have Nokia 5130c, it can not identify to pair with my Bluetooth BH-101
Try to remove all the paired deviceson your phone, then make sure bluetooth is switched on i.e on your phone, then switch of the bluetooth headset and try switching it back on when its on it should show a flashing blue light on the side o on the top, when its sflashing search for new devices on you fone, if its recongised and asks you for a key type four zeros (0000), this should work
Regards
Egroeg
Mar 24, 2011 | Nokia BH-101 BLUETOOTH HEADSET
How to configure or pair my motorola T305 car bluetooth with my mobile nokia E63
First step:From your nokia e63,scroll to bluetooth goto paired device and click on add device after that,then pick up your bluetooth and press down the power button make sure you did not remove your hand from the button until it displays on your phone.
Second step:After your phone has found the device,click on the device from your phone and you will be ask to type a password which the password is 0000.enjoy
Jan 30, 2011 | Motorola Mobility T305 Bluetooth Speaker...
Please Answer
Bluetooth, when activated on your mobile device, you get to chose to be noticed or not. If you chose NOT, then anyone with bluetooth seeking to connect with another device with bluetooth, you're device WILL NOT come up. It'll only show up when you chose YES to notice. When someone is seeking via bluetooth for another bluetooth device to connect with, they'll find your's. You'll have a personalized name or a generic name. Typically, the generic name will be the model of phone you are using. Plus, bluetooth can only connect to one thing at a time. Can't do multiple pairings. In some countries, young adults leave their bluetooths open and noticed for all to find as a dating network.
Hope that answered your question!!
Cheers!
Feb 04, 2009 | LG Prada KE850 Cellular Phone
How do I attach my universal bluetooth haedset to my nokia n70
it should go like this
menu/connections/bluetooth/paired devices/options/add new device (pair new device)/the BT will go ON tt will find new devices select one that you want to pair wait for the connection then it might ask you for some kind of code unless the other device is mobile from other user and he put some other code for himself than you will need to ask if not just type 0000 or 12345 everything is automatic and it should be easy - i dont know if that 100% accurate cos i sold mine n70 and now i have e51 but it should go as i said
Jan 06, 2009 | Nokia N70 Cellular Phone
I am trying to program my nokia 2600 phone to my motorla h700 blu
First of all, the Nokia 2600 is not a blue tooth phone.
If you should get a Nokia phone that supports blue tooth your best bet would be to make sure any previously paired devices are turned off.
Then make sure that blue tooth is enabled on your phone. For most Nokia models its as follows;
Menu > Settings > Connectivity > Bluetooth > Bluetooth On
Then attempt to put your device in pairing mode.
Return to;
... > Bluetooth > Search Audio Enhancements
If your phone supports Bluetooth the phone should and device should pair after you enter the pairing pin, usually 0000.
Johnny_Nh, to answer your question, different Models are equipped with blue tooth when they are manufactured. Also, there are different versions of bluetooth, 1.0 and 2.0. If you have an older phone supporting Bluetooth 1.0 you will not be able to use a bluetooth 2.0 headset.
Dec 26, 2008 | Motorola Mobility H700 Wireless Headset
Blackberry Itune/media player/mp3 player/bluetooth operation
alright bhavin,
all you need to do is first PAIR your both the devices using bluetooth, then in black berry on music or ringtone or picture whichever you want go to.. menu-->option-->receive using bluetooth ,,,, once you allow files to be transfer from nokia you will receive in blackberry... and for sending out from black berry... select SEND USING BLUETOOTH....
i was doing the same to transfer between my nokia and blackberry phones...!!!
but for downloading this particular files, i never this so sorry about it..!!
Sep 25, 2008 | RIM BlackBerry 8700c Cellular Phone
Nokia N95 Cellular Phone Logo
121 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
