Question about Char-Broil CharBroil Master Flame Gas Barbecue Grill
How to assemble burner in 8000-9000 series thermos gas
How to assemble burner in 8000 series thermos gas grill with model #4619041
burzerko
  • 254 Answers
SOURCE: Thermos Gas Grill
This is caused by a bad regulator. This is the silver device that usually attaches directly to your tank. Most hardware stores carry these regulators you will need the numbers off it to match up a new regulator for size.
Posted on Jun 25, 2008
SOURCE: trying to clean the burners assembly
I found this pin. It's on the bottom of the burner on the back end. You have to slide your hand under the burner between it and the flang of the bottom of the grill. It's a messy and difficult thing to remove. Somehow I was able to wiggle and pull it out with my fingers, assisted by a screwdriver and needle-nose pliers. It was a huge pain the a$$ but I was able to get the three burners free and get a coat hanger in there to clean them.
Because of the bottom of the grill there was no clear visible access to these pins. You have to operate blind with just your fingers and the tools. Good Luck!
Posted on Aug 10, 2009
  • 57 Answers
SOURCE: Ichanged my propane tank, but I am still not
bad regulator
Posted on Aug 25, 2009
bulldogchief
  • 388 Answers
SOURCE: I have a charbroil, advantage series grill. It isn't lighting.
How rusted are the burners? It is possible there is rusted metal blocking the gas ports. I don't have enough information from you regarding the problem...do you hear the gas flowing when you turn the burner open and the gas bottle is open?
Go to your user's manual, there should be an illustrated parts list. From there you can order new burners...you can also do this at Char-Broil's website.
Burner replacement is easy: take the grills out, then remove the flame tamers (the tent looking thing that sits over the burner to prevent flame-ups), the burners are screwed in to the grill at the back, remove the screws then grab the burner, pull towards the back of the grill and then up...this will disengage it from the gas valve in the front of the grill. Putting in a new one is the exact revers of this procedure...just make sure when you put the new ones in you make sure the burner's gas intake is connected to the valve at the front of the grill. Once done, you should be good to go.
Posted on Sep 07, 2009
  • 3 Answers
SOURCE: Kenmore elite16690 gas grill - main burner replacement
Call 1-800-4MYHOME and request a brochure for that model. Then you can call the Parts line at the same number and order the parts you need.
The actual grill model number is 141-16690
Posted on Sep 08, 2009
I have thermos quick set gas grill--are the lava rocks supposed to cover the burner cover
They should cover the tray above the burner so the burner can heat them .
Apr 20, 2012 | Thermos Quick Set Gas Grill 4000
How does the burner connect to the regulator for the thermos Millennium 4000
In most grills, the burner is "seated" on the valve, the valve is attached to the manifold, and the manifold is connected to the gas hose and regulator.
Jul 02, 2010 | Thermos Quick Set Gas Grill 4000
I am not getting gas to the grill burners
Check out the reg could not be passing gas
Jul 05, 2017 | Thermos Stainless Steel Gas Grill
Cracked primary burners
yes call Flame Grill Services at 770-521-2050
Mar 18, 2010 | Thermos Stainless Steel Gas Grill
This is for the Thermos Millenium 4000: I need
Ive replaced the gas tank and make sure valve is on tight but the flame is still weak!?
Feb 01, 2010 | Thermos Quick Set Gas Grill 4000
Converting Thermos Stainless Grill to natural gas
You have to install a conversion kit for it to work the way you want. The reason is because the orifice in either the valves or the main "jet" that feeds the burner tube has to be changed. Natural gas is really not as efficient as lp gas (propane) because it takes more natural gas to create the same btu output as propane.
In short, your grill will not work if you do not do the conversion. I am including a link that lists the conversion kit for your grill, you can order it there and you can download the assembly manual as well.
Here is the link: http://www.charbroil.com/Consumer/product_detail_e.aspx?ProductID=1723&CategoryID=25
Nov 20, 2009 | Thermos Stainless Steel Gas Grill
My gas grill is not getting gas to the burners.
most likely it is regulator and hose
Jul 29, 2009 | Grilling
Grill 2 go parts
I have the same problem no reg. and no connection pipe, where can I get?
Mar 18, 2008 | Thermos Grill2Go Fire+Ice
Sideburner for Thermos Stainless Steel Gas Grill (Mod # 461262006)
It sounds like the orifice is bad. An orifice is a small metal part that has a small hole in it. This regulates the gas coming out to the burner. It is at the tip of the pipe that brings gas to the burners, before the flame. I don't know what the hell the garggley noise is. Unless the bottle is upside down, and you are getting liquid, I don't know.
Mar 02, 2008 | Thermos Stainless Steel Gas Grill
Grilling Logo
304 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
