Question about Samsung ML-2510 Laser Printer
Labels got stuck in printer. Removed all labels but no go.
Labels got stuck in printer. Removed all labels but printer still acts jammed.
    President:
  • 2,777 Answers
Unplug the power from the printer, leave it unplugged for a good 90 seconds, replug it in. If it still shows being jammed you may need to call Samsung for support / repair.
Posted on Jun 30, 2009
How can i avoid label sheets getting stuck in phaser 8560
1. Make sure you are feeding the labels from the bypass tray, not from the cassette.-
2. Make sure the labels are for Laser printers, not Inkjet printers.
3. Do not try and re-use a label sheet that only was half printed on.
4. When you put the labels in the bypass tray, set the paper type to labels...this slows down the print process so they won't get jammed.
Jun 02, 2014 | Xerox Phaser 8550DP Printer
Paper continues to jam even though previous jam is cleared
was the origianl due to labels? It is likely that there is a very small piece of paper or some glue off some labels stuck in a corner or on the rollers which is causing it to mis align on the way through and therfore jam
Good luck
Jul 11, 2010 | Brother DCP-7040 Laser Printer
My dymo label printer is printing 2 labels at a time. One has the label I want. The other is blank. Can you help me?
There are a few common reasons this is problem can exist.
1.) the incorrect template is used when creating the label
2.) the labels are installed incorrectly - the labels must be loaded and pushed against the left side of the printer and lid closed when printing to ensure the labels don't "wander" out of the sensor's view.
3.) the label sensor is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view.
4.) The labels are defective - if you have another roll of the same size, try it to see if it has the samme issue.
Mar 24, 2010 | Dymo LabelWriter 400 Thermal Printer
Dymo labelwriter 400 Turbo -We replaced the roll of labels and it keeps feeding with no stop
3.) the label sensor is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view. Use quality Dymo labels.
Oct 17, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
My dymo label writer twin turbo stopped printing on left side!
3.) the label sensor is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view. 4.) the print head is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view.
5.) The labels are defective - if you have another roll of the same size, try it to see if it has the same issue. If not, make sure you purchase quality labels like Dymo name brand or Labelvalue brand Dymo labels.
6.) The printer is defective. Labelwriter 400s have a 2 year warranty, so you can contact Dymo customer support to determine if the printer is defective and return to the retailer you purchased it from.
Oct 08, 2009 | Dymo LabelWriter Thermal Printer
Dymo 400 was working fine, then I had to unjam
You probably didn't damage it, it sounds like you may have knocked loose the thermal printing portion (which is the most important part). There is no easy way for you to repair this but Dymo will usually do it for free under warranty. Their phone number is:
(203) 588-2500
Jun 25, 2009 | Dymo LabelWriter 400 Thermal Printer
Label stuck on a roller?
Looks like label stuck on the toner cartridge. Easiest solution would be to replace toner cartridge or if you can slowly spin the OPC drum on toner cartridge till you find label NOTE: damage to the OPC drum with affect print quality as well as oil from fingers will affect PQ( print quality)
Jan 13, 2009 | HP LaserJet 5000n Printer
Printing blank labels
I am having the same problem! Printing blank labels. Don't know what's wrong now. It was working fine yesterday.
Jul 22, 2008 | Dymo LabelWriter 400 Thermal Printer
Labels jamming
Check the entire paper processing path as it sound like either the roller gear is not engaging properly to push the paper out of the top, or the output paper path is somehow blocked, like from a label or something else stuck at the top, the roller gear is damaged, or other obstruction.
Nov 16, 2007 | Konica Minolta magicolor 2300DL Laser...
Plastic labels jammed inside of printer.
they are stuck in the fuser unit, try to take out the toner cartridge to see if you can get it from their. if not you may have to call for service help. you have to take the back of the machine apart and take out the fuser unit to get out the lables. sorry that i didnt have better help.
Nov 02, 2007 | Brother HL 1440 Laser Printer
Samsung ML-2510 Laser Printer Logo
111 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
