Question about Lanier 5235 Printer
Printer don't print, the paper come out white.
I just change the toner thinking that was the problem, but not, I tried to print and the machine worked, scanned and pull out a white paper.
Can you help me?
Why the paper come white when i print somthing
Posted on Mar 07, 2010
Color Laser Printer Pink Tint
have you tried cleaning the charging wire and the transfer belt
Feb 17, 2014 | Ricoh Aficio SP C420DN Laser Printer
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
I think i have a fuser error. When I print something the right side of the paper is very light in color. If I print multiple pages, it gets lighter by every page.
Put paper in the manual feed tray. Print. When the page gets half way into the printer, open the cover. Remove the toner. Look down at the paper. Is the right side lighter than the left? If yes, replace the toner cartridge. I don't believe that a fuser could cause your problem.
Aug 11, 2011 | HP LaserJet 4240n Printer
I have a problem of when printing out that is only white paper that take it out even I changed new toner and no change . Pls u have any solution give me the solution .
For a laser printer, printing is a few steps:
* receiving the print-data (which seems to be working fine)
* putting an electrostatic charge on the drum, by using a laser to draw the print-image onto the drum (working?)
* forcing toner into contact with the drum, but only the "charged" part of the drum holds the ink (working?)
* using heat from the fuser-unit to "melt" the toner into the paper (working?)
* ejecting the paper
If the paper is warm, then the fuser is working.
If not, then your fuser needs replacing.
Either take the printer to a qualified printer technician, for professional trouble-shooting, or buy a replacement printer, and responsibly recycle the old printer.
Jul 07, 2010 | Office Equipment & Supplies
Printing quality problem.
you might have to change the toner.
also try remove the toner from the printer and shake a little and try printing. Hope should resolve your issue.
May 26, 2010 | HP LaserJet P4014n Printer
There is a white stripe (miising writing) in the middle and in the left side of the printed paper. i have changed the toner, but the problem doesnt solve. maybe its the laser motor dirty? thnx for any help
Problem : white stripe (missing writing) in the middle and in the left side of the printed paper
Printer Laser Printer MF5650
Cause of the problem Dust
Solution Cleaning ..
There could be reasons for your problem
1) The TONER CARTRIDGE not clean - i think you replaced it
2) The Imaging Drum
3) Beam Alignment Lance (glass which reflect the rays)
1) there are toner and the drum
2) take out the Toner cartridge
3) there is a black roller on Toner Unit - clean it with the Cotton
4) Take out the Drum clean it (Don not use water or spirit to clean it )
5) Fuser Unit a Hot Unit the Red Color Roller no need to clean ..
Following Video will show you the over view of the Product
Video 1 use full video help you to understand the whole process
Jan 03, 2010 | Canon LaserBase MF5650 All-In-One Printer
Printer changing color of paper
Make sure the transfer belt is clean. Also check the magenta cartridge and see if it isn't leaking slightly. By all means DON"T blow it out with compressed air! You may use a toner vacuum or a soft cloth to clean out any residual toner. If that doesn't do the trick, you may have a contaminated fuser. By the way, do you get the same effect when printing black and white?
Apr 20, 2009 | HP Color LaserJet 2600n Printer
Looks like toner is not sealed to the paper.
the machine is only designed for 80gsm paper. you can change paper type through printer options in printer manager to card stock. it wil probably not work though as it is really only designed for 80gsm paper. the toner need to be heated to 200oC inorder to fuse to the paper cardstock absorbs less heat than normal paper.
Jan 03, 2009 | Samsung CLP 300 Laser Printer
Hp 4250 GHOSTING
Are you telling the machine that paper type is letter head or envelopes, It must be done, it changes temp of fuser to suit the paper type, no it is not a power supply problem change paper type to card stock/thick/letterhead etc to suit then machine will adjust temp to suit.. ie file, print properties paper type.
50.2 fuser error replace fuser.
Dec 06, 2007 | HP LaserJet 4250n Printer
Print
Cleaning a laser printer can solve minor problems, maintain print quality, and prolong periods between professional cleanings. Clean your printer when print quality deteriorates or when you change toner cartridges. Manually Cleaning Inside the Printer Steps: 1. Unplug the printer from the surge suppressor. 2. Remove the internal paper trays. 3. Remove the toner cartridge and place it on a piece of scrap paper. 4. Clean inside the toner cavity with a dry, lint-free cloth and brush (if a brush is supplied with the printer). 5. Clean the printer mirror gently with the brush. Don't touch the mirror if a brush isn't provided. 6. Wipe away dust and spilled toner. Remove paper fragments. 7. Clean the rollers, but don't touch the sponge roller. 8. Replace the toner cartridge. Tips: To remove unfused toner from the rollers following a paper jam, print 5 to 10 blank pages on scrap paper. Wipe toner from clothing if necessary, then immediately wash toner-soiled clothes in cold water. Go to your printer manufacturer's Web site (see Related Sites) for detailed cleaning instructions. Warnings: Don't use any liquid cleaners inside the printer. Initiating Automatic Cleaning Through Printer Software Steps: 1. Open the printer software by double-clicking on a printer icon or specific printer utility program, or opening a document and then selecting Print from the File menu. 2. In the printer software, look for a button labeled Options, Troubleshooting, Toolbox, Printer Utilities or something similar. (This varies by manufacturer.) 3. Follow the instructions on the screen. 4. Repeat the cleaning process if the results aren't satisfactory.
Jan 15, 2006 | Panasonic KX-FL501 Plain Paper Laser Fax
188 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
