Question about Garmin Nuvi 660 GPS Receiver
I have a new garmin 660wt out the box and it won't stay on the backlight goes out and you cN'T SEE THE SCREEN BUT STILL GET VOICE COMMANDS. i've done the setting to stay on but its still does it, driving me mad...... its going back
    Brigadier General:
  • 4,090 Answers
I agree with that. There is a small window on this model that detects light values to alter the screen to vary intensityof brightness. It is this part that is defective
Posted on Jun 30, 2009
When driving no voice, check sound is fine
If you're just driving around and you haven't selected navigate to a destination there will not be a voice. Try navigating to a destination as that is where you will get voice navigation suggestions or commands. If you don't get a voice then, perhaps you need to download a voice or two. This can be done using the Garmin Express software and a computer connected to your Nuvi using the USB cord.
May 09, 2015 | Garmin nuvi 2555LMT
No voice command
Try going to the settings menu and look for voice options. Usually there is a box that needs to be checked for the option to work.
Apr 13, 2014 | Garmin nuvi 2555LMT
How to activate voice command 3760t
Page 19 of your manual:
Activating Voice Command
Speak your wakeup phrase. The Voice Command menu appears.
Setting your Wakeup Phrase
The wakeup phrase is a word or phrase you can say to activate voice command. The default wakeup phrase is "Voice Command".
1. From main menu, touch Tools > Voice Command > Customize Phrase.
2. Enter a new wakeup phrase.
3. Touch "Done"
If this solves your posted problem, please come back and rate our answer. Thankyou.
Nov 05, 2010 | Garmin GPS
I have a garmin 3970t and the voice command does not work
The Garmin's not very good at recognising the default set phrase to initial voice command; i.e. "Voice Command". If you bring up the Tools menu, and touch Voice Command, it will tell you what phrase it's expecting to hear and provide a button to touch to customise it. The default, as I said, is "voice command", but for some reason, it thinks it's pronounced something like "Vwuss commont". Try it. It might work!
I changed my voice command phrase to "Voys Commarnd" (I'm English - it's how my accent would be written phonetically). It now works most of the time without a problem.
Aug 12, 2010 | Garmin GPS
Garmin Nuvi 265 wt...how to get voice command to work?
this may require two sessions but - here goes:
1- turn the unit on - select the VOICE icon on the opening screen - triple check it isn't muted and change it to 90% voice volume.
If this doesn't give you sound WHILE DRIVING - it won't give you voice unless you're moving or driving.
Then - turn the unit off - Turn it back on- - as it is starting up - and blank- place your thumb in the LOWER RIGHT CORNER of the blank Screen.
this will open this window:
SELECT - YES - it will reboot and your minor settings will be lost - like saved address and favorites - not your updated maps.
This will reset you to default NEW -
When done - sound will be as it was when new if no sound - return for repair.
May 06, 2010 | Garmin n?vi 265WT Car GPS Receiver
My panasonic sat nav will not start past yhe first
try the reset button, first on it's own, then while powering on
Apr 02, 2010 | Panasonic Strada CN-NVD905U GPS Receiver
Garmin Nuvi 265w voice command stopped working. Any suggestion on what to check?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you are not receiving any sound on your Nüvi 2xx the first thing to check is that the sound is not muted. To ensure that your units sound is not muted please perform the following:
  1. Turn the device on
  2. Press the Volume button on the ‘Where To?’, ‘View Map’ screen
  3. Ensure the Mute box is not ‘checked’
If the mute button is not ‘ticked’, you will need to change the voice to ensure that the preset voice is not faulty:
  2. Touch the Tool icon
  3. Touch Settings
  4. Touch Language
  5. Touch the language voice next to Voice
  6. Scroll through and select another appropriate voice
If changing the voice is not helping you will need to ensure that you are running the latest software which can be done by installing a program called WebUpdater. WebUpdater can be installed via the link below:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Once updated please allow the unit to reboot which will ensure the software successfully installs.
If after following all the above the final steps would be to perform a master reset:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers on. After 5-10 seconds you will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Please follow the on screen prompts on the nuvi and when completed place your device in an area with a clear view of the sky until it acquires satellites.
Nov 15, 2009 | Garmin Nuvi 265W GPS Receiver
Garmin voice command not working
I am not fimiarly with tom tom, but I do know on my garmin gps, there is a mute feature on the volume. On my mine it is on the main menu screen right after you turn it on. On yours you may have to go to a menu or something to turn the mute off.
Aug 10, 2009 | Garmin nuvi 750 GPS Receiver
Garmin 660WT FM - Use in France re Speed Cameras
this is a gps navigation device. there is no radar detection with it. the only thing it has is an FM traffic service to avoid delays, which may not be available in france. in short, this device is not illeagel nor does it have any type or radar detection or even speed camera detection.
Jul 18, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
269 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
